I initially got the unreachable error until I set my ethernet to trusted under the firewall settings, then I get the connection refused error on my Tab S8 Ultra
I didn’t install it from the AUR, but apparently it’s in there and I didn’t know prior to looking for answers to my issue, the version I’m using is the same as from the AUR though.
It has worked prior, to some latency, but not now, not even after rebooting both my PC and tablet. I even tried a hotspot and changing the port, from 1701 to 7500, to the same issue.
searching up the issue brings up this but it’s not the issue I’m having, it makes the port no issue but my tablet and phone can’t connect to it, even after setting my ethernet to trusted.
here’s the inxi output btw
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=31696cac-739a-4545-a3bb-ed2e2bb3545b rw rootflags=subvol=@
quiet rd.luks.uuid=e8e18018-efc9-450f-a3ba-551cac0048a9
rd.luks.uuid=fe72d3aa-be26-4a5a-9b85-8f382c8a601d
resume=/dev/mapper/luks-fe72d3aa-be26-4a5a-9b85-8f382c8a601d loglevel=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop Mobo: Micro-Star model: B450-A PRO MAX (MS-7B86) v: 4.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: M.70
date: 06/17/2020
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3621 high: 3834 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3620
3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3834
12: 3600 bogomips: 86402
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 2c:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: MACROSILICON ShadowCast
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-1:2 chip-ID: 298f:1996
Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-5:5 chip-ID: 046d:0825
gpu: amdgpu d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-2 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5600 XT (navi10 LLVM
16.0.6 DRM 3.54 6.6.7-zen1-1-zen) device-ID: 1002:731f memory: 5.86 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 5600 XT (RADV NAVI10) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:731f surfaces: xcb,xlib,wayland device: 1 type: cpu
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2c:00.1 chip-ID: 1002:ab38
bus-ID: 2e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: MACROSILICON ShadowCast
Device-4: Smartlink USB2.0 Device
driver: hid-generic,snd-usb-audio,usb-storage,usbhid type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-10.2:10 chip-ID: 301a:5602
Device-5: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
Device-6: Razer USA Kraken V3 HyperSense
lanes: 1 mode: 1.1 bus-ID: 6-1:2 chip-ID: 1532:0533 class-ID: 0300
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-2: Ralink RT5370 Wireless Adapter driver: rt2800usb type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-4:4 chip-ID: 148f:5370
IF: wlp3s0f0u4 state: down mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-3:3
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.75 TiB used: 214.2 GiB (7.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: TEAM T253X2001T
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4A0 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
ID-1: / raw-size: 936.74 GiB size: 936.74 GiB (100.00%)
used: 214.2 GiB (22.9%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-e8e18018-efc9-450f-a3ba-551cac0048a9
ID-2: /home raw-size: 936.74 GiB size: 936.74 GiB (100.00%)
ID-3: /var/log raw-size: 936.74 GiB size: 936.74 GiB (100.00%)
ID-4: /var/tmp raw-size: 936.74 GiB size: 936.74 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.12 GiB used: 0 KiB (0.0%)
mapped: luks-fe72d3aa-be26-4a5a-9b85-8f382c8a601d
ID-2: swap-2 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 64.5 C mobo: N/A gpu: amdgpu temp: 43.0 C
mem: 42.0 C
Processes: 355 Uptime: 17m wakeups: 0 Memory: total: 16 GiB
available: 15.56 GiB used: 3.6 GiB (23.2%) Init: systemd v: 255
Packages: 1460 pm: pacman pkgs: 1414 libs: 395 tools: octopi,paru,yay
pm: flatpak pkgs: 46 Shell: fish v: 3.6.4 running-in: konsole inxi: 3.3.31
Garuda (2.6.21-1):
System install date: 2023-12-14
Last full system update: 2023-12-22
Failed units:```
I do have deckboard and iriun webcam server installed, which I didn't prior to it breaking, so no clue if it's that or not.
