first things first!
─michael@Archangel in ~
╰─λ garuda-inxi
Kernel: 5.15.90-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=63f3c83e-5747-44de-974f-c89d4101bd95 rw rootflags=subvol=@
resume=UUID=c0d4fb48-27bb-458a-9d32-db4bea9d7420 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: MSI model: Z77A-GD55 (MS-7751) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.11
date: 11/20/2013
Info: model: Intel Core i7-3770K bits: 64 type: MT MCP arch: Ivy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3039 high: 3901 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3900 2: 3901 3: 1741
4: 1984 5: 3823 6: 2116 7: 2960 8: 3894 bogomips: 55999
Device-1: NVIDIA GK106 [GeForce GTX 660] vendor: Micro-Star MSI
driver: nvidia v: 470.161.03 alternate: nouveau,nvidia_drm non-free:
series: 470.xx+ status: legacy-active (EOL~2023/24) arch: Kepler
code: GKxxx process: TSMC 28nm built: 2012-18 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:11c0
Device-2: NVIDIA GK106 [GeForce GTX 660] vendor: Micro-Star MSI
code: GKxxx process: TSMC 28nm built: 2012-18 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.0
chip-ID: 10de:11c0 class-ID: 0300
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 94 s-size: 518x291mm (20.39x11.46")
s-diag: 594mm (23.39")
Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 96
size: 510x290mm (20.08x11.42") diag: 587mm (23.1") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 470.161.03 renderer: NVIDIA GeForce GTX
660/PCIe/SSE2 direct render: Yes
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GK106 HDMI Audio vendor: Micro-Star MSI
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e0b class-ID: 0403
Device-3: NVIDIA GK106 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.1
Sound API: ALSA v: k5.15.90-1-lts running: yes
Device-1: Intel 82579V Gigabit Network vendor: Micro-Star MSI driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503 class-ID: 0200
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 2.91 TiB used: 558.05 GiB (18.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SH103S3120G
type: SSD serial: <filter> rev: BBF0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G
type: SSD serial: <filter> rev: 0107 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
ID-4: /dev/sdd maj-min: 8:48 vendor: Kingston model: SH103S3120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD20EZRX-00D8PB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 0A80
scheme: MBR
ID-1: / raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
used: 29.82 GiB (75.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 608 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 71.04 GiB size: 71.04 GiB (100.00%)
used: 36.49 GiB (51.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
ID-5: /var/tmp raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.43 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 512 MiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 34%
Processes: 308 Uptime: 3h 59m wakeups: 0 Memory: 23.43 GiB
used: 2.36 GiB (10.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1971
libs: 546 tools: octopi,paru Shell: fish v: 3.6.0 running-in: konsole
inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-15
Last full system update: 2023-01-31 ↻
╭─michael@Archangel in ~ took 2s
╰─λ
okay!
so i've been having issues accessing certain system settings apps/applets, this started in early December and the number of system settings applets that are affected seems to be increasing over time. exactly why this is happening i do not know. i do not mess with the OS because it works and if it ain't broke i don't fix it.
i tried resetting all configs to no avail, i tried using Stacer to clear up logs and cache files, no effect.
i tried reinstalling all packages and that left me with other errors like Grub not displaying in the specified resolution so i rolled back to my earliest snapshot from Dec 18 and ran a full update.
still not working correctly.
i have also tried creating a new user and attempting to open the certain settings apps from there, and nope. side note - i had to create a new user via terminal and then use the 'users' page in Garuda Assistant to provide it a password, i also modified the 'sudoers' file to provide admin privileges to that new user following these instructions precisely, with the exception of using "/bin/fish" instead of "/bin/bash":
one effect of this glitch is that when i log in, my desktop background is missing and i cannot make it appear even if i select an image and choose 'Set as Wallpaper' from the right-click context menu. i am forced to log out and then back in repeatedly until it loads the background image (and who knows what else) properly.
another effect is that my second GPU is no longer seen by the system settings 'About this system' screen although it is clearly listed in the Nvidia Xserver settings page - GPU0 and GPU1 are both there.
primarily i am get similar errors in terminal when using that to open 'systemsettings5' and then using the GUI to click the chosen app/applet.
i went through them all to collect the errors in the terminal and they are as follows:
systemsettings5
file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
QQmlEngine::setContextForObject(): Object already has a QQmlContext
QLayout::removeWidget: Cannot remove a null widget.
file:///usr/share/kpackage/kcms/kcm_lookandfeel/contents/ui/main.qml:84:9: QML StackView: Binding loop detected for property "implicitHeight"
qml: The item SubCategoryPage_QMLTYPE_76(0x562467616840) is already in the PageRow
file:///usr/share/kpackage/kcms/kcm_desktoptheme/contents/ui/main.qml:58:14: QML RowLayout: Cannot anchor to an item that isn't a parent or sibling.
fish: Job 1, 'systemsettings5' terminated by signal SIGSEGV (Address boundary error)
╭─michael@Archangel in ~ took 17s
[⚡] × systemsettings5
qml: The item SubCategoryPage_QMLTYPE_115(0x55a41de32560) is already in the PageRow
file:///usr/share/kpackage/kcms/kcm_colors/contents/ui/main.qml:78:13: QML ColumnLayout: Cannot anchor to an item that isn't a parent or sibling.
╭─michael@Archangel in ~ took 5s
qml: The item SubCategoryPage_QMLTYPE_76(0x56167c5be8f0) is already in the PageRow
file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:257:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
qml: The item SubCategoryPage_QMLTYPE_107(0x55e0dfadd970) is already in the PageRow
╭─michael@Archangel in ~ took 8s
file:///usr/share/kpackage/kcms/kcm_workspace/contents/ui/main.qml:18:5: QML FormLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredHeight"
qml: The item SubCategoryPage_QMLTYPE_115(0x55ecaa28fbe0) is already in the PageRow
file:///usr/share/kpackage/kcms/kcm_kwin_virtualdesktops/contents/ui/main.qml:117:13: QML ColumnLayout: Cannot anchor to an item that isn't a parent or sibling.
╭─michael@Archangel in ~ took 6s
file:///usr/share/kpackage/kcms/kcm_sddm/contents/ui/main.qml:22:13: QML InlineMessage: Cannot anchor to an item that isn't a parent or sibling.
qml: The item SubCategoryPage_QMLTYPE_76(0x55674ad07f90) is already in the PageRow
file:///usr/share/kpackage/kcms/kcm5_kded/contents/ui/main.qml:35:13: QML ColumnLayout: Cannot anchor to an item that isn't a parent or sibling.
╭─michael@Archangel in ~ took 7s
file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "height"
"No devices available"
file:///usr/share/kpackage/kcms/kcm_users/contents/ui/main.qml:50:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:246:38: QML FocusScope: Binding loop detected for property "contentItemMaximumWidth"
Both point size and pixel size set. Using pixel size.
Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
libpng warning: iCCP: known incorrect sRGB profile
file:///usr/share/kpackage/kcms/kcm_users/contents/ui/UserDetailsPage.qml:257:9: QML SwipeView: Binding loop detected for property "implicitWidth"
file:///usr/share/kpackage/kcms/kcm_users/contents/ui/UserDetailsPage.qml:345: ReferenceError: modelData is not defined
file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "implicitHeight"
file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:601:17: QML ColumnLayout: Binding loop detected for property "width"
╭─michael@Archangel in ~ took 4s
qml: The item SubCategoryPage_QMLTYPE_115(0x56041b788710) is already in the PageRow
╭─michael@Archangel in ~ took 9s
firewalld.client: Firewalld is loaded? 4
ufw.client: Ufw is loaded? false
qml: services available: []
QQmlExpression: Expression file:///usr/share/kpackage/kcms/kcm_firewall/contents/ui/About.qml:22:13 depends on non-NOTIFYable properties:
FirewallClient::name
QQmlExpression: Expression file:///usr/share/kpackage/kcms/kcm_firewall/contents/ui/SimpleRuleEdit.qml:39:9 depends on non-NOTIFYable properties:
QQmlExpression: Expression file:///usr/share/kpackage/kcms/kcm_firewall/contents/ui/SimpleRuleEdit.qml:34:9 depends on non-NOTIFYable properties:
QQmlExpression: Expression file:///usr/share/kpackage/kcms/kcm_firewall/contents/ui/SimpleRuleEdit.qml:22:9 depends on non-NOTIFYable properties:
ufw.client: Status query starting
ufw.client: Starting the Status Query
file:///usr/share/kpackage/kcms/kcm_firewall/contents/ui/main.qml:139:13: QML ColumnLayout: Cannot anchor to an item that isn't a parent or sibling.
qml: The item SubCategoryPage_QMLTYPE_115(0x56451f08b3c0) is already in the PageRow
org.kde.plasma.pulseaudio: Settings schema org.freedesktop.pulseaudio.module-group is not installed
i've been searching around off and on for a few weeks now and come up with sites with details regarding issues as far back as 2014, they all seem to be application specific errors with a generic error message - app "terminated by signal SIGSEGV (Address boundary error)".
i have no idea how to fix this, much of the stuff i come across may as well be chinese to me >.>
i have thought about how to set XDG_RUNTIME_DIR and found some possible fixes but i have not tried this because there is no ".bashrc" file, it has a slightly different name and there are 2 of them in different locations on my root drive. (exact file locations unknown to me atm)
any help with fixing this/these issues would be greatly appreciated.
Thanks a bunch Garuda Team!
