Kernel: 6.1.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=fee12699-5d85-4ddb-bae0-daf333cf53d5 rw rootflags=subvol=@
loglevel=3 quiet
Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16U5IMS.102 date: 03/17/2020
ID-1: BAT1 charge: 39.9 Wh (96.8%) condition: 41.2/51.6 Wh (79.9%)
volts: 11.9 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1250 high: 2600 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 801
5: 801 6: 800 7: 2600 8: 2600 9: 801 10: 800 11: 800 12: 2600
bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:3
chip-ID: 04f2:b695 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.7
Monitor-1: eDP-1 model: AU Optronics 0xd0ed built: 2019 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound API: ALSA v: k6.1.9-zen1-2-zen running: yes
vendor: Micro-Star MSI driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.38 TiB used: 337.1 GiB (23.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1032 size: 476.94 GiB block-size: physical: 512 B
rev: 20140000 temp: 42.9 C scheme: GPT
model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
used: 96.73 GiB (66.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-4: /var/log raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-5: /var/tmp raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C pch: 49.0 C mobo: N/A
Processes: 346 Uptime: 5m wakeups: 32297 Memory: 15.47 GiB
used: 4.99 GiB (32.3%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1608
libs: 437 tools: octopi,paru Shell: fish v: 3.6.0 running-in: konsole
inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-07-14
Last full system update: 2023-02-07
cat /etc/fstab
error: Invalid value "rules" for '--style <components>': Unknown style, 'rules'en'
For more information try --help
How can I fix this? I have been looking through the ~/.config/fish
there is an alias:
# Replace some more things with better alternatives
alias cat='bat --style header --style rules --style snip --style changes --style header'
[ ! -x /usr/bin/yay ] && [ -x /usr/bin/paru ] && alias yay='paru'
Not sure if this is correct. Any assistance? I haven't been able to find a config file for bat.
filo
February 7, 2023, 5:09pm
2
Hi, I think you could either reset fish to default config with Garuda Assistant or manually apply this fix to your ~/.config/fish/config.fish
Careful: I think it should be:
alias cat='bat --style header --style snip --style changes --style header'
instead of
alias cat='bat --style header--style snip --style changes --style header'
erics
February 7, 2023, 6:20pm
3
Fish ate the cat?
Lol sorry, this thought made me laugh!
Thanks filo, that fixed it. like waeking, i too had that "--style rules" bit in mine that prevented me from using cat. thanks to waeking though, i didn't know i had that problem.
root=UUID=db37640e-243e-401b-9117-5ab4e247db2f rw rootflags=subvol=@
resume=UUID=26f9424d-c98e-4028-849c-9edad2ba726d loglevel=3
initcall_blacklist=acpi_cpufreq_init amd_pstate.shared_mem=1 options
amdgpu ppfeaturemask=0xffffffff ibt=off
Type: Laptop System: Acer product: Aspire A515-45 v: V1.07
Mobo: LN model: Calla_LC v: V1.07 serial: <superuser required>
UEFI: INSYDE v: 1.07 date: 07/27/2021
ID-1: BAT1 charge: 46.1 Wh (100.0%) condition: 46.1/53.2 Wh (86.6%)
volts: 12.8 min: 11.6 model: COSMX AP20CBL type: Li-ion serial: <filter>
status: full
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608102
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2130 high: 4340 min/max: N/A cores: 1: 1988 2: 1797
3: 2583 4: 2341 5: 1797 6: 1797 7: 1797 8: 1797 9: 1797 10: 1797 11: 4340
12: 1797 13: 2011 14: 1797 15: 1595 16: 3055 bogomips: 57495
Device-1: AMD Lucienne vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 46.0 C
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 3-4:2
chip-ID: 04f2:b72b class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x4999 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.9-zen1-2-zen) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: N/A alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-3:2
chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 4.1 TiB used: 1.56 TiB (38.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
lanes: 4 type: SSD serial: <filter> rev: P6MA000 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT4000MX500SSD1
type: SSD serial: <filter> rev: 044 scheme: GPT
ID-1: / raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
used: 73.43 GiB (16.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-4: /var/log raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.98 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.48 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 58.6 C mobo: N/A gpu: amdgpu temp: 47.0 C
Processes: 364 Uptime: 0m wakeups: 1 Memory: 14.98 GiB
used: 2.11 GiB (14.1%) Init: systemd v: 252 default: graphical
pkgs: 2248 libs: 574 tools: octopi,pamac,paru Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-06-28
system
Closed
February 9, 2023, 7:40pm
5
