Hello
Kernel: 5.16.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=52aeb3a0-22fe-4451-80e5-9ea6601b2df4 rw [email protected]
Desktop: KDE Plasma 5.24.3 tk: Qt 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Alienware product: Alienware X51 R2 v: 00
serial: <superuser required> Chassis: type: 3 v: 00
Mobo: Alienware model: 0PGRP5 v: A01 serial: <superuser required>
UEFI: Alienware v: A12 date: 03/20/2017
ID-1: steam-controller-FC626237EE-battery charge: 100% condition: N/A
volts: 3.1 min: N/A model: N/A type: N/A serial: N/A status: N/A
Device-1: ps-controller-battery-d0:bc:c1:c5:c9:0e model: N/A serial: N/A
charge: N/A status: Full
Info: model: Intel Core i7-4770 bits: 64 type: MT MCP arch: Haswell
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3709 high: 3835 min/max: 800/3900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3835 2: 3669 3: 3743
4: 3797 5: 3720 6: 3507 7: 3718 8: 3686 bogomips: 54400
Type: l1tf
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Dell Alienware X51 R2 driver: i915 v: kernel ports: active: none
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0412 class-ID: 0380
Device-2: NVIDIA GM204 [GeForce GTX 970] vendor: eVga.com. driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
loaded: intel,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: i915,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 39 s-size: 1250x686mm (49.2x27.0")
s-diag: 1426mm (56.1")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 40
size: 1218x685mm (48.0x27.0") diag: 1397mm (55")
OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 510.54
direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Dell Alienware X51 R2 driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GM204 High Definition Audio vendor: eVga.com.
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-4: Sony DualSense wireless controller (PS5) type: USB
driver: playstation,snd-usb-audio,usbhid bus-ID: 3-12:6 chip-ID: 054c:0ce6
Sound Server-1: ALSA v: k5.16.15-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.48 running: no
Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter vendor: Dell
bus-ID: 02:00.0 chip-ID: 14e4:43b1 class-ID: 0280
vendor: Dell Alienware X51 R2 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-3: Sony DualSense wireless controller (PS5) type: USB
Device-1: Dell Broadcom BCM20702A0 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-2:2 chip-ID: 413c:8143 class-ID: fe01 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 581.39 GiB used: 84.92 GiB (14.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: A-Data
model: USB Flash Drive size: 115.62 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 435.03 GiB size: 435.03 GiB (100.00%)
used: 84.92 GiB (19.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 435.03 GiB size: 435.03 GiB (100.00%)
ID-4: /var/log raw-size: 435.03 GiB size: 435.03 GiB (100.00%)
ID-5: /var/tmp raw-size: 435.03 GiB size: 435.03 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 61.0 C mobo: N/A gpu: nvidia temp: 41 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Processes: 302 Uptime: 1h 59m wakeups: 7114 Memory: 15.54 GiB
used: 5.5 GiB (35.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1394 lib: 447 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-01-02
Last full system update: 2022-03-20
Failed units: systemd-guest-user.service
[[email protected] ~]$
Hello, firstly allow me to thanks all devs of this wonderful OS. You saved lot of money when WIN10 start to make lot of trouble to me. I do not want be long. My question is, i would like to make certain folders to be case insensitive. For modding purpose i would have to manually renaming all files from game that expect opposite behavior. I was searching the net and found out, than i need to create EXT4 partition. I did that, but have problem probadly with permissions, because in Steam i wanted to add this new partition as game library, but it not showing up.
Help will be very welcomed, i would also give this informations to discord for other ppl too.
Regards, F
