Greeting all,
My capslock and numlock lights do not work when logged into hyprland. The keys do work, just not the indicator lights. It’s like the lights are frozen.
If I use them before I log in they work just fine.
I also installed Sway to see if the issue persisted but they worked fine.
Really not sure what is going on here.
My hyrpland config has numlock_by_default = 1.
In the past I have used utilities that would open a small popup window or show a red icon in the systray when either key was active. Obviously, not a fix but a relatively satisfactory workaround.
Sorry, but I can’t remember the names of these small utilities. A bit of searching should turn something up, if you’re inclined to try that sort of workaround.
Did some more research and I think it might be a Hyprland bug.
Found issue with similar problem where using a Razer Naga mmo mouse can cause numlock and caps lock to flake out. Just so happens that’s the exact mouse I use lol.
Thanks for the reply!
