Can't Use Nvidia proprietary driver 575 to load RTX 5070Ti Mobile
[   38.916395] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  575.57.08  Sat May 24 07:21:16 UTC 2025
[   39.015960] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
               NVRM: installed in this system requires use of the NVIDIA open kernel modules.
[   39.015978] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   39.017278] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   43.676784] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   43.676805] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   43.678142] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   43.719041] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   43.719063] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   43.720650] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   43.760986] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   43.761011] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   43.762602] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   43.803515] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   43.803618] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   43.805489] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   51.316900] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   51.316920] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   51.318516] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   51.358813] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   51.358834] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   51.360247] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   51.403419] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   51.403460] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   51.404818] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   51.442439] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   51.442461] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   51.443858] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   51.492584] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   51.492604] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   51.493770] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   51.534432] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   51.534459] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   51.536036] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   56.369437] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   56.369486] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   56.371227] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   56.428168] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   56.428215] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   56.430127] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   56.481844] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   56.481885] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   56.483816] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   56.536831] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   56.536873] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   56.538645] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   57.146344] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   57.146382] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   57.147863] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   57.978092] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   57.978117] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   57.979866] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   58.395940] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   58.395961] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   58.397447] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.162150] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.162173] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.163731] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.210901] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.210929] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.212308] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.268925] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.268949] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.270536] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.314500] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.314531] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.316011] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.364101] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.364125] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.365370] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.408775] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.408807] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.410177] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.558151] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.558183] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.559962] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.608543] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.608573] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.610802] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.656920] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.656944] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.658696] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.701729] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.701758] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.703245] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.827536] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.827562] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.828872] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.872089] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.872130] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.873724] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.915109] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.915133] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.916578] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   86.958491] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   86.958519] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   86.959760] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   87.099969] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   87.099996] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   87.101381] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   87.141776] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   87.141802] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   87.142970] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   87.187144] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   87.187167] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   87.188718] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   87.232740] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   87.232770] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   87.234106] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   87.342317] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   87.342339] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   87.344088] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   87.386546] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   87.386570] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   87.388274] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   87.431453] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   87.431477] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   87.433476] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   87.476946] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   87.477088] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   87.478916] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   95.506174] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   95.506206] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   95.510012] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[   96.997416] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2f58)
[   96.997445] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:884)
[   97.000812] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
You need the open source drivers:
sudo pacman -S nvidia-open-dkms
But first of all, please post your garuda-inxi and the output of:
pacman -Qs nvidia
to see what you have now.
