Hello.
Kernel: 5.16.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=03da7a37-4ea3-4808-b057-6f1ef916effa rw rootflags=subvol=@
resume=UUID=6b5e9134-5814-43fa-a3ec-627a454e7d9c loglevel=3
Type: Desktop Mobo: Micro-Star
model: MPG X570 GAMING PRO CARBON WIFI (MS-7B93) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.E0
date: 12/17/2021
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4131 high: 4132 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4131 2: 4131
3: 4132 4: 4132 5: 4132 6: 4132 7: 4132 8: 4132 9: 4132 10: 4132 11: 4130
12: 4132 13: 4131 14: 4132 15: 4130 16: 4131 17: 4131 18: 4132 19: 4132
20: 4132 21: 4132 22: 4131 23: 4132 24: 4130 25: 4132 26: 4132 27: 4132
28: 4132 29: 4132 30: 4132 31: 4132 32: 4132 bogomips: 217581
IBRS_FW, STIBP: always-on, RSB filling
Device-1: AMD Vega 10 XL/XT [Radeon RX Vega 56/64] vendor: ASUSTeK
driver: amdgpu v: kernel bus-ID: 2f:00.0 chip-ID: 1002:687f class-ID: 0300
Device-2: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-5.2:7 chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
Device-3: ET13R type: USB driver: snd-usb-audio,uvcvideo bus-ID: 5-4:4
chip-ID: 1e4f:1301 class-ID: 0102 serial: <filter>
loaded: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: DisplayPort-0 res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
OpenGL: renderer: AMD Radeon RX Vega (VEGA10 DRM 3.44.0 5.16.5-zen1-1-zen
LLVM 13.0.0)
v: 4.6 Mesa 21.3.5 direct render: Yes
Device-1: AMD Vega 10 HDMI Audio [Radeon Vega 56/64] driver: snd_hda_intel
v: kernel bus-ID: 2f:00.1 chip-ID: 1002:aaf8 class-ID: 0403
driver: snd_hda_intel v: kernel bus-ID: 31:00.4 chip-ID: 1022:1487
Device-3: Razer USA Nari Ultimate type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:2 chip-ID: 1532:051a
Device-4: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
Device-5: ET13R type: USB driver: snd-usb-audio,uvcvideo bus-ID: 5-4:4
Sound Server-1: ALSA v: k5.16.5-zen1-1-zen running: yes
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel port: d000 bus-ID: 26:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 1-4:4 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 0 state: down
bt-service: disabled rfk-block: hardware: no software: no address: N/A
Local Storage: total: 7.02 TiB used: 2.03 TiB (28.9%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
rev: 2B2QEXM7 temp: 54.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 44.9 C
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Samsung
rev: 3B2QEXM7 temp: 37.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Mushkin model: MKNSSDRE1TB
type: SSD serial: <filter> rev: 7C scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Mushkin model: MKNSSDCR480GB
type: SSD serial: <filter> rev: BBF0 scheme: MBR
ID-6: /dev/sdc maj-min: 8:32 vendor: OCZ model: AGILITY3 size: 223.57 GiB
serial: <filter> rev: 2.15 scheme: MBR
ID-1: / raw-size: 1.75 TiB size: 3.57 TiB (203.87%) used: 1.31 TiB (36.6%)
fs: btrfs dev: /dev/nvme2n1p2 maj-min: 259:3
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme2n1p1 maj-min: 259:2
ID-3: /home raw-size: 1.75 TiB size: 3.57 TiB (203.87%)
used: 1.31 TiB (36.6%) fs: btrfs dev: /dev/nvme2n1p2 maj-min: 259:3
ID-4: /var/log raw-size: 1.75 TiB size: 3.57 TiB (203.87%)
ID-5: /var/tmp raw-size: 1.75 TiB size: 3.57 TiB (203.87%)
ID-1: swap-1 type: partition size: 69.06 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme2n1p3 maj-min: 259:4
ID-2: swap-2 type: zram size: 62.78 GiB used: 14.16 GiB (22.6%)
System Temperatures: cpu: 75.0 C mobo: 41.0 C gpu: amdgpu temp: 64.0 C
mem: 54.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1829 fan-3: 0 fan-4: 740 fan-5: 0
fan-6: 0 fan-7: 1501 gpu: amdgpu fan: 1414
Processes: 886 Uptime: 6d 4h 33m wakeups: 0 Memory: 62.78 GiB
used: 45.25 GiB (72.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 2172 pacman: 2158 lib: 589 flatpak: 6
snap: 8 Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-01-09
Last full system update: 2022-02-09
Is partially upgraded: Yes
Failed units: anbox-container-manager.service foldingathome.service shadow.service
Currently I can not completely update my system, running sudo pacman -Suy or sudo update yields this error:
Fehler: wine-tkg-fsync-git: Signatur von "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" ist ungĂĽltig
:: Datei /var/cache/pacman/pkg/wine-tkg-fsync-git-7.1.r412.g576cdea0d75-326-x86_64.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes Paket (PGP-Signatur)).
(which sadly is in German... not sure how to configure that, I wanted to have language english and format strings and stuff in german, but somehow everything is quite mixed up now
another issue... ) which means that for the package wine-tkg-fsync-git-7.1.r412.g576cdea0d75-326-x86_64.pkg.tar.zst the PGP Signuature is "damaged" (my translation, might be inaccurate).
I found related topics here, one said to run sudo update, which I tried but got the same problem still another is more elaborate and I did what is written there (update of keyring packages and refresh-keys).. but it does not resolve the current error.
I know that the wine-tkg-fsync-git package is fairly experimental. So, if that issue is not easily to be solved, what can I do to tell pacman to install all other updates and leave wine as is for the time being? (for example until I decide to got for back to a more stable package)?
