: Synchronizing package databases...
garuda 83.7 KiB 6.85 KiB/s 00:12 [------------------------------------] 100%
core 132.2 KiB 13.1 KiB/s 00:10 [------------------------------------] 100%
extra 8.4 MiB 720 KiB/s 00:12 [------------------------------------] 100%
multilib 142.5 KiB 28.1 KiB/s 00:05 [------------------------------------] 100%
chaotic-aur 2.5 MiB 195 KiB/s 00:13 [------------------------------------] 100%
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
:: Replace baloo5 with extra/baloo? [Y/n] y
:: Replace bluez-plugins with extra/bluez-utils? [Y/n] y
:: Replace breeze with extra/breeze5? [Y/n] y
:: Replace kde-servicemenus-rootactions with chaotic-aur/kf6-servicemenus-rootactions? [Y/n] y
:: Replace ksysguard with extra/plasma-systemmonitor? [Y/n] y
:: Replace kuserfeedback5 with extra/kuserfeedback? [Y/n] y
:: Replace libblockdev-utils with extra/libblockdev? [Y/n] y
:: Replace plasma-integration with extra/plasma5-integration? [Y/n] y
:: Replace plasma-wayland-session with extra/plasma-workspace? [Y/n] y
:: Replace plasma5-applets-window-buttons with extra/plasma-applet-window-buttons? [Y/n] y
resolving dependencies...
:: There are 2 providers available for qt6-multimedia-backend:
:: Repository extra
1) qt6-multimedia-ffmpeg 2) qt6-multimedia-gstreamer
Enter a number (default=1): 1
:: garuda-dr460nized and plasma5-applets-window-appmenu are in conflict. Remove plasma5-applets-window-appmenu? [y/N] y
:: garuda-dr460nized and plasma5-applets-window-title are in conflict. Remove plasma5-applets-window-title? [y/N] y
:: garuda-dr460nized and plasma5-applets-betterinlineclock-git are in conflict. Remove plasma5-applets-betterinlineclock-git? [y/N] y
:: garuda-dr460nized and plasma5-wallpapers-blurredwallpaper are in conflict. Remove plasma5-wallpapers-blurredwallpaper? [y/N] y
:: removing ksysguard breaks dependency 'ksysguard' required by plasma5-applets-thermal-monitor
Press enter to exit
Please try:
sudo pacman -R plasma5-applets-thermal-monitor
Then
garuda-update
Please always provide your garuda-inxi, as required in the template.
Welcome ![]()
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
Please follow the template!
Missing information requested in the template may result in not receiving assistance
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
garuda-inxiin the body of the post (not linked externally, or collapsed with the “hide details” feature)
Please format your post.
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Without garuda-inxi this request will be moved to 412 Precondition Failed
thank you for fixing the issue
