Hello, I have the following issue with my new i3 installation. When trying to connect my 1TB external drive, I encounter the following error: “error mounting /dev/sda at /run/media/DriveName: wrong fs type, bad option, bad superblock on /dev/sda missing codepage or helper program, or other error”. I initially thought it might be a dependency issue and found on some forums that it could possibly be due to not having “ntfs-3g” installed. However, this wasn’t the case because I did have it installed, and I reinstalled it to make sure it wasn’t the problem. I also considered that the external drive might be faulty, but upon checking it with another device, it works correctly. Initially, I could mount it from the terminal, but now when I try that, I get the same error. Do you know how I could resolve this? I keep all my backups on this drive and need access to the files.
Inxi:
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=dff22d3d-b43d-46f1-ae2a-0783aa03e2a1 rw rootflags=subvol=@
Desktop: i3 v: 4.23 with: i3bar tools: avail: i3lock,xautolock vt: 7
Type: Desktop Mobo: ASUSTeK model: H110M-E/M.2 v: Rev X.0x
UEFI: American Megatrends v: 3401 date: 03/16/2017
Info: model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 24000
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: ASUSTeK driver: nvidia
v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4
ports: active: none off: HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0
chip-ID: 10de:1d01 class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 compositor: Picom v: git-89c2c
driver: X: loaded: nvidia unloaded: modesetting
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.63x11.50")
s-diag: 600mm (23.62")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Samsung C24F390
serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GT 1030 driver: nvidia v: 550.54.14
device-ID: 10de:1d01 surfaces: xcb,xlib
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
Device-2: NVIDIA GP108 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:0fb8 class-ID: 0403
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8192EE PCIe Wireless Network Adapter
driver: rtl8192ee v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000
bus-ID: 05:00.0 chip-ID: 10ec:818b class-ID: 0280
Local Storage: total: 465.76 GiB used: 61.44 GiB (13.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 27.9 C
used: 61.44 GiB (13.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 30.0 C mobo: N/A gpu: nvidia temp: 37 C
Memory: total: 8 GiB available: 7.68 GiB used: 2.7 GiB (35.2%)
Processes: 243 Power: uptime: 25m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.03 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1428 libs: 397 tools: octopi,pacseek,paru
Compilers: gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-24
Last full system update: 2024-03-19
