about one year ago I made a mistake and removed the partition table of hard disk....
I mentioned the problem in a forum and got a good help to use testdisk. and problem solved.
but the process take a long time and I forgot about this option.
if there is a short way to fix the problem I prefer to do that.
It looks like it is designed for exactly the situation you are in. Once you repair the drive you can resize it with this software as well. Also, it looks like you can make a bootable USB with it too so you donāt need to run Windows if you donāt want to.
I'm not sure how likely you are to to find someone who can help you with your TestDisk software here in the Garuda Linux forum. I personally have zero experience with it.
