After trying to install drivers the arch wiki way, I realized that there is an option in settings for it. But when I try to use it installation fails and I get:
Starting
> Using config 'video-chaotic-nvidia-dkms-tkg' for device: 0000:01:00.0 (0300:10de:1402) Display controller nVidia Corporation GM206 [GeForce GTX 950]
> Installing video-chaotic-nvidia-dkms-tkg...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/chaotic-nvidia-dkms-tkg/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
warning: paleofetch-garuda: local (r196.aaaae08-1) is newer than chaotic-aur (r2.c6a22b0-1)
resolving dependencies...
Packages (21) gobject-introspection-1.66.1-3 libappindicator-gtk3-12.10.0.r296-1 libdazzle-3.38.0-1 libindicator-gtk3-12.10.1-9 minigalaxy-1.0.2-1 python-beaker-1.11.0-6 python-injector-0.18.4-1 python-mako-1.1.3-3 python-markdown-3.3.3-2 python-peewee-3.14.0-3 python-py3nvml-0.2.6-1 python-rx-3.1.1-3 python-typing_extensions-3.7.4.3-3 python-xlib-0.29-1 rare-git-0.1.5.r3.g88e8022-1 chaotic-nvidia-dkms-tkg-460.32.03-1 chaotic-nvidia-egl-wayland-tkg-460.32.03-1 chaotic-nvidia-settings-tkg-460.32.03-1 chaotic-nvidia-utils-tkg-460.32.03-1 gwe-0.15.2-1 lib32-chaotic-nvidia-utils-tkg-460.32.03-1
Total Installed Size: 494.47 MiB
Net Upgrade Size: 493.86 MiB
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
(1/1) Creating Timeshift snapshot before upgrade...
E: Commands listed below are not available on this system:
* rsync
* /sbin/blkid
* df
* mount
* umount
* fuser
* crontab
* cp
* rm
* touch
* ln
* sync
Please install required packages and try running TimeShift again
** (process:145241): CRITICAL **: 13:47:35.903: app_lock_remove: assertion 'self != NULL' failed
Unable to run timeshift-autosnap! Please close Timeshift and try again. Script will now exit...
error: failed to commit transaction (failed to run transaction hooks)
Error: pacman failed!
Error: script failed!
Done ...
Rsync and /sbin/blkid are definitively installed, yet still show up
Other problems:
-Cannot acces Firewall Configuration (I type in password but nothing comes up afterwards)
-Cannot remove preinstalled programs, keep getting (using Minetest game as example):
Failed to prepare transaction
target not found: mine
Something is wrong (ultimate gaming edition). I cannot acces the Firewall Configuration and Garuda keeps bricking after installing the drivers, even after fresh installation and getting things up to date.
Restoring snapshots also doesn't do anything at long run, garuda keeps freezing on first loading screen on normal boot
Garuda is not responsible for bricking anything. Perhaps you need to educate yourself on what that term actually means. Here is the common definition easily found online:
Bricking is when an electronic device becomes unusable, often from a failed software or firmware update. If an update error causes system-level damage, the device may not start up or function at all. In other words, the electronic device becomes a paperweight or a “brick.”
An electronic device that has actually been bricked is only fit for the refuse heap.
Choose your terms more carefully when you claim Garuda has damaged your system, or perhaps you’ll wake up and find your Garuda forum account has been bricked one day.
language difference, Polish doesn’t distinguish difference between whole device and software. Everything is fixed here by a solid kick and some vodka
Boi, you’re talking to MacGyver of screwing things up. I recently tried using Tor and everyone called it DDoS, you’re lucky that I still haven’t overloaded whole internet by sheer use of stupidity
