Hello.
If I start garuda gamer with the command, garuda-gamer (or any other related Garuda app which can install some package) or from the Cinnamon menu entry, it opens Alacritty, asking for the password. Then it inmediatly closes, doing nothing.
I have searched the Garuda forums, trying to look online if there where some Alacritty related issue (I would like to replace Alacritty also for Garuda related apps, to be honest, but it seems it’s not possible, as it’s a dependency…). Also ran the command from gnome-terminal, but given that these apps just run Alacritty later, that’s really useless for triage.
So I’m forced to run from terminal sudo garuda-gamer or whatever other Garuda related app to be able to install anything via these wizards or it just won’t work.
This is my first post here, I’m sorry if I’m asking this in the wrong place or doing something wrong
Thanks for your time :).
Kernel: 5.16.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e634c912-f629-4f19-9b3c-c09c1a0c39f6 rw rootflags=subvol=@
resume=UUID=83b8d84f-5b94-4963-8e19-1ff094f49829 loglevel=3
Desktop: Cinnamon 5.2.7 tk: GTK 3.24.33 wm: muffin vt: 8
dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Intel product: SLIMBOOK v: 0.1
Mobo: N/A model: SLIMBOOK v: RVP7 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: 5.12 date: 12/22/2017
ID-1: BAT0 charge: 29.0 Wh (98.0%) condition: 29.6/48.8 Wh (60.7%)
volts: 12.4 min: 11.1 model: TPS S10 type: Li-ion serial: N/A status: N/A
Info: model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 0x8E (142)
stepping: 9 microcode: 0xEA
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 700 min/max: 400/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 700 2: 700 3: 700 4: 700 bogomips: 23199
Type: l1tf
Device-1: Intel HD Graphics 620 driver: i915 v: kernel ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940MX] driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134d
class-ID: 0302
Device-3: Alcor Micro HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 058f:d102 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 driver: X:
loaded: modesetting,nvidia gpu: i915 display-ID: :1 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: BOE Display built: 2015 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.16.4-zen1-1-zen running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-6:2 chip-ID: 8087:0a2b class-ID: e001
address: <filter>
Local Storage: total: 1.93 TiB used: 18.62 GiB (0.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
size: 1.82 TiB block-size: physical: 4096 B
Juan Riquelme, [6/3/22 16:23]
logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
model: WDS120G1G0B-00RC30 size: 111.79 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1000
scheme: MBR
ID-1: / raw-size: 94.69 GiB size: 94.69 GiB (100.00%)
used: 18.62 GiB (19.7%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 94.69 GiB size: 94.69 GiB (100.00%)
ID-3: /var/log raw-size: 94.69 GiB size: 94.69 GiB (100.00%)
ID-4: /var/tmp raw-size: 94.69 GiB size: 94.69 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.1 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18
ID-2: swap-2 type: zram size: 15.54 GiB used: 16.4 MiB (0.1%)
System Temperatures: cpu: 37.0 C pch: 27.0 C mobo: N/A
Processes: 294 Uptime: 22h 13m wakeups: 7 Memory: 15.55 GiB
used: 2.86 GiB (18.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1541 lib: 463 Shell: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-03-05
Last full system update: 2022-03-06
