As mentioned in the headline, I’m trying to install Garuda, however, when I try to flash the iso I downloaded to my usb drive, it turns the flash drive into MBR. My all SSDs are GPT, and I also convert the flash drive to GPT before starting the process. However, in the end, it is still becoming MBR. Any suggestions?
Provide garuda-inxi.
What are you flashing with?, Its highly recommended you use rufus.
Thanks for your reply. Will provide the file soon as I get home, but could you please also let me know where do I find this file? And about the soft, I have already tried rufus, but no success
Rufus is not regularly recommended. It is on that sometimes works. They need to use Ventory. Then under Option select Partition Style, the select GPT, then flash the drive, and when done add their ISO, During boot into the ISO from Ventoy select Grub2.
Thanks, will try that now
It worked, thanks. But I got a quick question, it would be great if the solution would be simple. I installed Garuda but I can’t boot into windows. I still have some work to do on windows, so how do I boot back there?
Depends on how you have installed Garuda. Reboot your system and press the appropriate key for the BIOS boot menu and select windows there.
Sadly, it’s not there. I can’t find it in bios. Only windows is there
- ONE issue per topic.
Please.
