Can't edit primary monitor desktop
Garuda-inxi:
sudo garuda-inxi
[sudo] password for steamrex25:
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=84c2d676-7cb0-47ef-a50a-f71fbbc1a646 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
serial: <filter> UEFI: American Megatrends v: 2.30 date: 08/31/2020
Info: model: AMD Ryzen 5 3600 socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3600 min/max: 2200/4208 boost: enabled
base/boost: 3600/4200 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3600 2: 3600 3: 3600 4: 3600
5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600 12: 3600
bogomips: 86393
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Gigabyte driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2,HDMI-A-2 empty: DP-1,HDMI-A-1
bus-ID: 2b:00.0 chip-ID: 10de:2484 class-ID: 0300
Display: server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
s-diag: 1102mm (43.38")
Monitor-1: DP-2 mapped: DP-3 note: disabled pos: primary,right
model: Samsung LF24T35 serial: <filter> built: 2021 res: 1920x1080 dpi: 92
gamma: 1.2 size: 528x297mm (20.79x11.69") diag: 606mm (23.9") ratio: 16:9
Monitor-2: HDMI-A-2 mapped: HDMI-1 note: disabled pos: left
model: Dell SE2417HG serial: <filter> built: 2019 res: 1920x1080 hz: 60
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.269 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: nvidia v: 545.29.06
device-ID: 10de:2484 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
bus-ID: 2b:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 5
lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 1038:1250 class-ID: 0300
Device-4: HP HyperX SoloCast driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
chip-ID: 03f0:078b class-ID: 0300
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.85 status: n/a (root, process) with:
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
IF: enp42s0 state: down mac: <filter>
Device-3: TP-Link 802.11ac NIC driver: rtl88x2bu type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 2357:0138
IF: wlp2s0f0u6 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0aa7
Local Storage: total: 1.14 TiB used: 105.92 GiB (9.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kikwot model: FS810 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: A25D temp: 45 C
SMART: yes state: enabled health: PASSED on: 63d 23h cycles: 489
read: 4.4 MiB written: 7.8 MiB
model: WDS100T2B0B-00YS70 family: WD Blue / Red / Green SSDs
size: 931.51 GiB block-size: physical: 512 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 00WD temp: 34 C
SMART: yes state: enabled health: PASSED on: 291d 2h cycles: 1867
used: 105.92 GiB (45.5%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
maj-min: 8:2
maj-min: 8:2
maj-min: 8:2
System Temperatures: cpu: 56.0 C mobo: N/A gpu: nvidia temp: 44 C
Processes: 424 Uptime: 4m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 6.31 GiB (20.2%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1860
pm: pacman pkgs: 1847 libs: 534 tools: octopi,pamac,paru pm: flatpak
pkgs: 13 Shell: garuda-inxi (sudo) default: Bash v: 5.2.21
Garuda (2.6.19-2):
System install date:     2023-11-17
Last full system update: 2023-11-25
Windows dual boot:       Yes
I can only edit my second monitor’s desktop and my primary monitor’s desktop is blank
