Can't Connect to WPA2 Enterprise networks
Hello ,
All wifi available at my university is WPA2 Enterprise secured and we login with our credentials, we have a couple of internal ones as well as eduroam and none of them work on my laptop with garuda despite working a couple of months ago and still working on other devices, i also have no trouble connecting to my home wifi.
here is a snapshot of network manager logs when attempting to connect to eduroam as an example:
Aug 23 17:10:11 katana NetworkManager[606]: <info>  [1692825011.6568] device (wlo1): supplicant interface state: disconnected -> inactive
Aug 23 17:10:11 katana NetworkManager[606]: <info>  [1692825011.6570] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> inactive
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9676] device (wlo1): Activation: starting connection 'eduroam' (a79e3719-300d-460e-8ab5-1cc61f98ed23)
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9677] audit: op="connection-add-activate" uuid="a79e3719-300d-460e-8ab5-1cc61f98ed23" name="eduroam" pid=3743 uid=1000 result="success"
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9679] device (wlo1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9680] manager: NetworkManager state is now CONNECTING
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9792] device (wlo1): set-hw-addr: reset MAC address to 28:11:A8:31:B8:2F (preserve)
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9813] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9815] device (wlo1): Activation: (wifi) access point 'eduroam' has security, but secrets are required.
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9815] device (wlo1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9899] device (wlo1): supplicant interface state: inactive -> disconnected
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9900] device (p2p-dev-wlo1): supplicant management interface state: inactive -> disconnected
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9907] device (wlo1): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9910] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9914] device (wlo1): Activation: (wifi) connection 'eduroam' has security, and secrets exist.  No new secrets needed.
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9914] Config: added 'ssid' value 'eduroam'
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9914] Config: added 'scan_ssid' value '1'
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9914] Config: added 'bgscan' value 'simple:30:-65:300'
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9914] Config: added 'key_mgmt' value 'WPA-EAP FT-EAP FT-EAP-SHA384 WPA-EAP-SHA256'
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9914] Config: added 'auth_alg' value 'OPEN'
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9914] Config: added 'password' value '<hidden>'
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9915] Config: added 'eap' value 'PEAP'
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9915] Config: added 'fragment_size' value '1266'
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9915] Config: added 'phase2' value 'auth=MSCHAPV2'
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9915] Config: added 'identity' value 'USERNAME@UNIVERSITYDOMAIN'
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9915] Config: added 'proactive_key_caching' value '1'
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9922] device (wlo1): supplicant interface state: disconnected -> inactive
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9923] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> inactive
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9994] device (wlo1): supplicant interface state: inactive -> scanning
Aug 23 17:11:38 katana NetworkManager[606]: <info>  [1692825098.9994] device (p2p-dev-wlo1): supplicant management interface state: inactive -> scanning
Aug 23 17:11:39 katana NetworkManager[606]: <info>  [1692825099.9732] device (wlo1): supplicant interface state: scanning -> authenticating
Aug 23 17:11:39 katana NetworkManager[606]: <info>  [1692825099.9732] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
Aug 23 17:11:40 katana NetworkManager[606]: <info>  [1692825100.0009] device (wlo1): supplicant interface state: authenticating -> associating
Aug 23 17:11:40 katana NetworkManager[606]: <info>  [1692825100.0010] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
Aug 23 17:11:40 katana NetworkManager[606]: <info>  [1692825100.0154] device (wlo1): supplicant interface state: associating -> associated
Aug 23 17:11:40 katana NetworkManager[606]: <info>  [1692825100.0155] device (p2p-dev-wlo1): supplicant management interface state: associating -> associated
Aug 23 17:11:42 katana NetworkManager[606]: <info>  [1692825102.2590] device (wlo1): supplicant interface state: associated -> disconnected
Aug 23 17:11:42 katana NetworkManager[606]: <info>  [1692825102.2591] device (p2p-dev-wlo1): supplicant management interface state: associated -> disconnected
Aug 23 17:11:42 katana NetworkManager[606]: <info>  [1692825102.3593] device (wlo1): supplicant interface state: disconnected -> scanning
Aug 23 17:11:42 katana NetworkManager[606]: <info>  [1692825102.3593] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
Aug 23 17:12:04 katana NetworkManager[606]: <warn>  [1692825124.6327] device (wlo1): Activation: (wifi) association took too long
Aug 23 17:12:04 katana NetworkManager[606]: <info>  [1692825124.6328] device (wlo1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Aug 23 17:12:04 katana NetworkManager[606]: <warn>  [1692825124.6331] device (wlo1): Activation: (wifi) asking for new secrets
Aug 23 17:12:07 katana NetworkManager[606]: <warn>  [1692825127.1334] device (wlo1): no secrets: User canceled the secrets request.
Aug 23 17:12:07 katana NetworkManager[606]: <info>  [1692825127.1334] device (wlo1): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Aug 23 17:12:07 katana NetworkManager[606]: <info>  [1692825127.1339] manager: NetworkManager state is now CONNECTED_LOCAL
Aug 23 17:12:07 katana NetworkManager[606]: <info>  [1692825127.1469] device (wlo1): set-hw-addr: set MAC address to 6A:99:E2:4A:DE:CA (scanning)
Aug 23 17:12:07 katana NetworkManager[606]: <warn>  [1692825127.1500] device (wlo1): Activation: failed for connection 'eduroam'
Aug 23 17:12:07 katana NetworkManager[606]: <info>  [1692825127.1502] device (wlo1): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Aug 23 17:12:07 katana NetworkManager[606]: <info>  [1692825127.1682] device (wlo1): supplicant interface state: scanning -> disconnected
Aug 23 17:12:07 katana NetworkManager[606]: <info>  [1692825127.1682] device (p2p-dev-wlo1): supplicant management interface state: scanning -> disconnected
Aug 23 17:12:07 katana NetworkManager[606]: <info>  [1692825127.1733] device (wlo1): supplicant interface state: disconnected -> inactive
Aug 23 17:12:07 katana NetworkManager[606]: <info>  [1692825127.1734] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> inactive
Here is the output of garuda-inxi
>System:
  Kernel: 6.4.11-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=1ff06791-3783-4094-b0dd-898c4b519967 rw rootflags=subvol=@
    resume=UUID=f1f58c16-f4e6-4587-b7db-88c32ef6457f loglevel=3 ibt=off
  Type: Laptop System: Micro-Star product: Katana GF66 11SC v: REV:1.0
  Mobo: Micro-Star model: MS-1582 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: E1582IMS.30A date: 07/22/2021
  ID-1: BAT1 charge: 2.8 Wh (6.0%) condition: 46.7/52.0 Wh (89.8%) volts: 12.2
    min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A status: charging
  Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP
    microcode: 0x46
    L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 2388 high: 3500 min/max: 800/4500 scaling:
    driver: intel_pstate governor: performance cores: 1: 1956 2: 2700 3: 2700
    4: 2700 5: 801 6: 2700 7: 2700 8: 2700 9: 801 10: 2700 11: 2700 12: 3500
    bogomips: 64512
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Micro-Star MSI
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a68
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
    vendor: Micro-Star MSI driver: nouveau v: kernel non-free: 535.xx+
    status: current (as of 2023-08) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f9d class-ID: 0302
    temp: 29.0 C
  Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10:2 chip-ID: 5986:211b
    class-ID: 0e02
    compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
    alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: :0
  Monitor-1: eDP-1 model: AU Optronics 0xaf90 built: 2020 res: 1920x1080
    hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.6 renderer: Mesa Intel UHD Graphics (TGL GT1)
    direct-render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
    chip-ID: 8086:43c8 class-ID: 0401
  API: ALSA v: k6.4.11-zen2-1-zen status: kernel-api with: aoss
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:3 chip-ID: 8087:0026
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
  Local Storage: total: 476.94 GiB used: 141.43 GiB (29.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
    lanes: 4 tech: SSD serial: <filter> fw-rev: ECFK52.8 temp: 41.9 C
    used: 141.43 GiB (30.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
  ID-2: swap-2 type: zram size: 7.47 GiB used: 401 MiB (5.2%) priority: 100
  System Temperatures: cpu: 35.0 C mobo: N/A gpu: nouveau temp: 29.0 C
  Processes: 326 Uptime: 4m wakeups: 1 Memory: total: 8 GiB note: est.
  available: 7.47 GiB used: 3.88 GiB (52.0%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
  Packages: 2481 pm: pacman pkgs: 2475 libs: 587 tools: pamac,paru pm: flatpak
  pkgs: 6 Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.29
  System install date:     2022-08-03
  Last full system update: 2023-08-24
Check if this helps
https://wiki.archlinux.org/title/Network_configuration/Wireless#eduroam
After a lot of wiki and forum posts reading it seems this issue is caused by openssl 3.10 onwards moving old TLS protocol versions 1.0 and 1.1 to a deprecated status, requiring a lower security level to be enabled, this is somewhat confirmed by being able to now access the WPE2 Enterprise networks i couldn't before, after downgrading openssl to a 3.9 version i had in the cache.
From what i read the proper way to solve this issue is to lower the security setting used by wpa_supplicant (or more specifically the settings that NetworkManager uses for wpa_supplicant) but after a lot of searching i still don't know how to do that exactly and I've kind of given up.
If someone more knowledgeable can point out the proper fix I'd appreciate it
Is this one your issue?
https://wiki.archlinux.org/title/NetworkManager#WPA_Enterprise_connections_fail_to_authenticate_with_OpenSSL_"unsupported_protocol"_error
If so, maybe you could try the suggested solution (I think in the Arch forum thread or the nmcli one).
