Hello Users,
Issue: I cannot see the wifi icon after i installed garuda gnome in my system, hence i am not able to connect to my WiFi. I guess it's a driver problem, but I don't know i'm new at this. I have pasted the 'garuda-inxi' output below
Output(garuda-inxi):
Kernel: 5.17.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=d03e7f7a-bf2e-4e42-954b-c47e7ce6f178 rw rootflags=subvol=@
resume=UUID=fbf3c9cf-5180-4824-affd-d2ffc50f6dd6 loglevel=3
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Microsoft product: Surface Laptop 2
v: 124000000000000000000000D:F B: F:U C: P:C1 S:
serial: <superuser required> Chassis: type: 9
Mobo: Microsoft model: Surface Laptop 2 serial: <superuser required>
UEFI: Microsoft v: 139.3982.768 date: 12.14.2021
ID-1: BAT1 charge: 35.0 Wh (98.9%) condition: 35.4/45.2 Wh (78.2%)
volts: 8.8 min: 7.6 model: DYN M1005922 type: Li-ion serial: <filter>
status: charging cycles: 938
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 400/3400 scaling: driver: intel_pstate
8: 800 bogomips: 28800
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Microsoft driver: i915 v: kernel
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
compositor: gnome-shell driver: X: loaded: modesetting
Screen-1: 0 s-res: 2256x1504 s-dpi: 96 s-size: 596x397mm (23.46x15.63")
s-diag: 716mm (28.19")
Monitor-1: eDP-1 model: Panasonic VVX14T092N00 serial: <filter>
built: 2018 res: 2256x1504 hz: 60 dpi: 198 gamma: 1.2
size: 290x190mm (11.42x7.48") diag: 343mm (13.5") ratio: 3:2
modes: 2256x1504
Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
Unit
driver: ipu3-imgu alternate: ipu3_imgu bus-ID: 00:05.0 chip-ID: 8086:1919
class-ID: 0480
Device-2: Intel CSI-2 Host driver: ipu3-cio2 alternate: ipu3_cio2
bus-ID: 00:14.3 chip-ID: 8086:9d32 class-ID: 0480
Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.17.4-zen1-1-zen running: yes
Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless driver: mwifiex_pcie
v: 1.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 11ab:2b38 class-ID: 0200
IF-ID-1: enp0s20f0u1 state: unknown speed: -1 duplex: half mac: <filter>
Local Storage: total: 119.24 GiB used: 11.29 GiB (9.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC501 NVMe 128GB size: 119.24 GiB block-size: physical: 512 B
rev: 80000C00 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 110.15 GiB size: 110.15 GiB (100.00%)
used: 11.28 GiB (10.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 110.15 GiB size: 110.15 GiB (100.00%)
ID-4: /var/log raw-size: 110.15 GiB size: 110.15 GiB (100.00%)
ID-5: /var/tmp raw-size: 110.15 GiB size: 110.15 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.68 GiB used: 60 MiB (0.8%) priority: 100
System Temperatures: cpu: 49.0 C pch: 45.0 C mobo: N/A
Processes: 287 Uptime: 23m wakeups: 6 Memory: 7.68 GiB
used: 3.68 GiB (47.9%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1074 lib: 300 flatpak: 0 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-25
Last full system update: 2022-05-25
