I did, it’s at the bottom of the config.
The snapshot was one I’d just had generated after doing this yes. I’ll try the script you suggested.
Okay ran the commands.
sudo /etc/grub.d/41_snapshots-btrfs
Detecting snapshots ...
Found snapshot: 2024-07-09 11:12:18 | @/.snapshots/1038/snapshot | post | botan botan2 corectrl discord dxvk-mingw-git gdb gdb-common keepassxc li |
Found snapshot: 2024-07-09 11:11:52 | @/.snapshots/1037/snapshot | pre | pacman -Su |
Found snapshot: 2024-07-08 10:36:13 | @/.snapshots/1036/snapshot | post | abaddon-git b43-fwcutter blender btrfsmaintenance ca-certificates-mozill |
Found snapshot: 2024-07-08 10:35:18 | @/.snapshots/1035/snapshot | pre | pacman -Su |
Found snapshot: 2024-07-04 13:58:15 | @/.snapshots/1034/snapshot | post | abaddon-git adobe-source-code-pro-fonts aha akonadi akonadi-calendar ako |
Found snapshot: 2024-07-04 13:57:04 | @/.snapshots/1033/snapshot | pre | pacman -Su |
Found snapshot: 2024-06-26 17:33:53 | @/.snapshots/1032/snapshot | post | abaddon-git balena-etcher blender boost boost-libs bullet-dp electron31 |
Found snapshot: 2024-06-26 17:33:43 | @/.snapshots/1031/snapshot | pre | pacman -Su |
if [ ! -e "${prefix}/grub-btrfs.cfg" ]; then
echo ""
else
submenu 'Garuda Linux snapshots' {
configfile "${prefix}/grub-btrfs.cfg"
fi
Found 8 snapshot(s)
Unmount /tmp/grub-btrfs.AMK67m9AGQ .. Success
sudo update-grub
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: initramfs-linux-zen-fallback.img
Found Windows Boot Manager on /dev/sdd1@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings ...
Found 8 snapshot(s)
Unmount /tmp/grub-btrfs.1CkpMCiAKa .. Success
done
I also clouldn’t boot into snapshots a week or two ago and managed to fix it by running “Garuda Boot Repair” in the “Garuda Welcome” app using a live ISO, I don’t know if it’s the same problem you are having but if nonthing else works it might be worth a try.
I don’t remember if it also reset the /etc/default/grub file but if you have some custom configuration you might want to make a backup.
