root=UUID=49b5427d-58bc-4336-9d69-23fc2048638f rw rootflags=subvol=@
Type: Desktop Mobo: N/A model: N/A serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: 5.12 date: 11/10/2018
Info: model: Intel Core i5-8350U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 400/3600 scaling: driver: intel_pstate
8: 800 bogomips: 30399
Device-1: Intel UHD Graphics 620 driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1 empty: DP-1
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Microdia USB 2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 0c45:64a1
class-ID: 0e02
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Samsung C32F391 serial: <filter>
built: 2019 res: 1920x1080 hz: 60 dpi: 70 gamma: 1.2
size: 698x393mm (27.48x15.47") diag: 801mm (31.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) device-ID: 8086:5917 memory: 15.05 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (KBL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:5917 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 168c:0034 class-ID: 0280
Device-1: Toshiba Atheros AR3012 Bluetooth driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:7 chip-ID: 0930:021c
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.1
lmp-v: 7 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.96 TiB used: 115.03 GiB (3.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S250G
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK0S.6 temp: 56.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Backup+ SL
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 0143 scheme: MBR
model: WD20NMVW-11EDZS2 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5200 serial: <filter> fw-rev: 1012 scheme: MBR
ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
used: 115.03 GiB (49.4%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
ID-3: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
ID-4: /var/tmp raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 52.0 C pch: 47.0 C mobo: N/A
Processes: 242 Uptime: 10h 8m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.41 GiB used: 3.72 GiB (24.1%) Init: systemd v: 254
pm: pacman pkgs: 1624 libs: 442 tools: gnome-software,octopi,pamac,paru
Shell: fish v: 3.6.1 default: Bash v: 5.2.15 running-in: konsole
inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-07-21
Last full system update: 2023-11-17
Is partially upgraded: Yes
I did a full update on 17 Nov. Somewhere I installed audio-recorder and now will not allow me to update. See process below:
: Synchronizing package databases...
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
:: Replace appstream-qt with extra/appstream-qt5? [Y/n] y
:: Replace libkdcraw with extra/libkdcraw5? [Y/n] y
resolving dependencies...
:: removing appstream-qt breaks dependency 'appstream-qt' required by apper
I tried updating from console and Garuda system maintenance notification.
I have uninstalled audio-recorder, rebooted my system and tried both updates again with the same results.
Please advise. Thanks
