system:
Kernel: 6.16.8-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=11f6b677-8d8b-4ef1-ba29-cc2a7e64e042 rw rootflags=subvol=@
quiet loglevel=3
Type: Desktop System: ASRock product: Z790 LiveMixer v: N/A
serial:
Mobo: ASRock model: Z790 LiveMixer serial:
uuid: UEFI: American Megatrends LLC. v: 22.02
date: 05/05/2025
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
serial: charge: 55% (should be ignored) rechargeable: yes
Info: model: Intel Core i9-14900KF bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x12F
Topology: cpus: 1x dies: 1 clusters: 12 cores: 24 threads: 32 mt: 8 tpc: 2
st: 16 smt: enabled cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32
KiB, 16x64 KiB L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 800 min/max: 800/5700:6000:4400 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800
23: 800 24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800
32: 800 bogomips: 203980
Device-1: NVIDIA AD103 \[GeForce RTX 4080\] vendor: Gigabyte driver: nvidia
v: 580.82.09 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 01:00.0 chip-ID: 10de:2704 class-ID: 0300
gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-1 model: MSI G321CU built: 2022 res: mode: 3840x2160
hz: 120 scale: 100% (1) dpi: 140 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 3840x2160 min: 640x480
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4080/PCIe/SSE2
memory: 15.62 GiB display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 16 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4080 driver: nvidia v: 580.82.09
device-ID: 10de:2704 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.3-arch1.2 (LLVM
de: kscreen-console,kscreen-doctor gpu: corectrl, lact, nvidia-settings,
Device-1: Intel Raptor Lake High Definition Audio vendor: ASRock
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:22bb class-ID: 0403
API: ALSA v: k6.16.8-zen3-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 5000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtl8821ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 05:00.0 chip-ID: 10ec:8821 class-ID: 0280
IF: wlp5s0 state: down mac:
Device-1: Realtek RTL8821A Bluetooth driver: btusb v: 0.8 type: USB rev: 2.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:14 chip-ID: 0bda:0821
class-ID: e001 serial:
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 4.0
Supported mdraid levels: raid1
Device-1: md0 maj-min: 9:0 type: mdraid level: mirror status: active
Info: report: 2/2 UU blocks: 2930134464 chunk-size: N/A super-blocks: 1.2
Components: Online:
0: sdc maj-min: 8:32 size: 2.73 TiB
1: sdd maj-min: 8:48 size: 2.73 TiB
Local Storage: total: 24.67 TiB used: 13.36 TiB (54.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Fanxiang model: S880 2TB
lanes: 4 tech: SSD serial: fw-rev: SN17171 temp: 45.9 C
ID-2: /dev/nvme1n1 maj-min: 259:9 vendor: Crucial model: CT500P3PSSD8
lanes: 4 tech: SSD serial: fw-rev: P9CR40D temp: 44.9 C
ID-3: /dev/nvme2n1 maj-min: 259:1 vendor: TeamGroup
model: T-FORCE TM8FPZ004T size: 3.64 TiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial:
fw-rev: EIFM51.3 temp: 44.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: fw-rev: CC38 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST12000NM0127
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: fw-rev: G006 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3000NM0025
size: 2.73 TiB block-size: physical: 512 B logical: 512 B tech: N/A
serial: N/A fw-rev: N003
ID-7: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST3000NM0025
ID-8: /dev/sde maj-min: 8:64 vendor: SanDisk model: SanDisk 3.2 Gen1
size: 116.57 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial:
fw-rev: DL17 scheme: GPT
ID-9: /dev/sdf maj-min: 8:80 vendor: Toshiba model: MQ03UBB200
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5400 serial:
fw-rev: 5438 scheme: MBR
ID-1: / raw-size: 159.18 GiB size: 159.18 GiB (100.00%)
used: 60.03 GiB (37.7%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:4
used: 2.3 MiB (0.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 159.18 GiB size: 159.18 GiB (100.00%)
ID-4: /var/log raw-size: 159.18 GiB size: 159.18 GiB (100.00%)
ID-5: /var/tmp raw-size: 159.18 GiB size: 159.18 GiB (100.00%)
ID-1: swap-1 type: zram size: 46.86 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.5 C mobo: N/A
Memory: total: 48 GiB available: 46.86 GiB used: 3.85 GiB (8.2%)
Processes: 604 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.68 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2158 libs: 569 tools: gnome-software, octopi,
pacseek, paru, trizen, yay Compilers: clang: 20.1.8 gcc: 15.2.1
Shell: Bash v: 5.3.3 running-in: geany inxi: 3.3.39
Garuda (2.8.3-2):
System install date: 2025-09-21
Garuda release: 250916
Last full system update: 2025-09-27
Failed units: mdmonitor.service
— System Health Check Report —
23/24 checks run in 0.82 seconds ⌛
Powered by garuda-health 🦅
ever since i installed my bluetooth speakers i cannot see if sound is running using fuser -v /dev/snd/pcmC0D0p (or any other device in the dev/snd directory)
how best to get around this?
