Kernel: 6.2.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=b5d503f4-6af8-4fad-afdb-a829dc8d8588 rw [email protected]
loglevel=3 ibt=off
Desktop: MATE v: 1.26.1 info: mate-panel wm: marco v: 1.26.1 vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Acer product: Nitro AN515-42 v: V1.13
Mobo: RR model: Freed_RRS v: V1.13 serial: <superuser required>
UEFI: Insyde v: 1.13 date: 02/11/2019
ID-1: BAT1 charge: 36.1 Wh (100.0%) condition: 36.1/48.9 Wh (73.8%)
volts: 16.3 min: 15.2 model: LG 0x41,0x43,0x31,0x34,0x42,0x38,0 type: Li-ion
serial: <filter> status: full
Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2394 high: 2794 min/max: 1600/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2059 2: 2381
3: 2048 4: 2376 5: 2793 6: 2794 7: 2703 8: 2000 bogomips: 31941
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: Acer Incorporated ALI
built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 1002:67ef class-ID: 0380
temp: 39.0 C
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:15dd class-ID: 0300 temp: 42.0 C
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 0408:a060 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: marco v: 1.26.1 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x05d8 built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
missing.
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
API: ALSA v: k6.2.12-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.1 chip-ID: 10ec:8168
IF: enp2s0f1 state: down mac: <filter>
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 35.0 C
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
chip-ID: 04ca:3016 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 6 state: up address: <filter>
Local Storage: total: 1.02 TiB used: 772.13 GiB (74.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
type: SSD serial: <filter> rev: 023 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400M8120G
type: SSD serial: <filter> rev: 61E1 scheme: MBR
ID-1: / raw-size: 96 GiB size: 96 GiB (100.00%) used: 18.15 GiB (18.9%)
fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%)
used: 859 KiB (0.9%) fs: vfat dev: /dev/sdb2 maj-min: 8:18
ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 753.98 GiB (82.3%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 96 GiB size: 96 GiB (100.00%)
used: 18.15 GiB (18.9%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-5: /var/tmp raw-size: 96 GiB size: 96 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.26 GiB used: 1.99 GiB (6.6%)
System Temperatures: cpu: 42.1 C mobo: N/A
GPU: device: amdgpu temp: 42.0 C device: amdgpu temp: 39.0 C watts: 9.11
Processes: 325 Uptime: 2d 16h 14m wakeups: 7 Memory: 30.26 GiB
used: 6.89 GiB (22.8%) Init: systemd v: 253 default: graphical
pkgs: 1573 libs: 508 tools: octopi,pamac,paru,yay Shell: Bash v: 5.1.16
running-in: mate-terminal inxi: 3.3.26
System install date: 2023-03-29
Last full system update: 2023-04-24 ↻
I am able, using MATE, to add most of the applets to the upper panel. However, the Battery Monitor, important for a laptop, will not install. The icon in the Add To Panel's list looks different from the other icons, and it will not install.
Any ideas?
