“I’m trying to set up Timeshift to back up my Garuda Linux system onto a secondary BTRFS drive, but I’m encountering an error: Cannot create Timeshift Backup on BTRFS: system disk with root subvolume (@). My /etc/fstab file is configured with multiple BTRFS subvolumes for /, /home, /root, etc., but Timeshift doesn’t seem to recognize them properly. I’ve already tried creating a specific @timeshift subvolume on the backup drive and editing the fstab entry to match, but the error persists. I would appreciate any guidance on how to correctly set up Timeshift with BTRFS subvolumes for backup. Thank you!”
Kernel: 6.11.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=400c2f0d-8924-468c-8c78-7fcabce37e16 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: ASUSTeK model: TUF Z370-PLUS GAMING v: Rev X.0x
UEFI: American Megatrends v: 3004 date: 07/12/2021
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF8
Speed (MHz): avg: 800 min/max: 800/4700 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88796
Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: Micro-Star MSI
driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3
bus-ID: 01:00.0 chip-ID: 10de:1f02 class-ID: 0300
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 046d:0825
alternate: fbdev,nouveau,nv,vesa gpu: nvidia d-rect: 4480x2520
display-ID: 0
Monitor-1: DP-1 pos: primary,top-left res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 565.57.01
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2070 driver: nvidia v: 565.57.01
device-ID: 10de:1f02 surfaces: xcb,xlib,wayland
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
Device-4: HP HyperX QuadCast driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3
chip-ID: 03f0:0491 class-ID: 0300 serial: <filter>
Device-5: SteelSeries ApS Arctis 7
lanes: 1 mode: 1.1 bus-ID: 5-2.4:4 chip-ID: 1038:12ad class-ID: 0300
API: ALSA v: k6.11.6-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2.3.3:8 chip-ID: 2357:0604
rfk-block: hardware: no software: no address: <filter> bt-v: 5.1 lmp-v: 10
Local Storage: total: 2.28 TiB used: 526.14 GiB (22.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000S1024G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK51.2 temp: 29.9 C
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 30.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: KIOXIA model: EXCERIA SATA SSD
tech: SSD serial: <filter> fw-rev: 15.5 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: OCZ model: TRION100 size: 223.57 GiB
serial: <filter> fw-rev: 11.2 scheme: GPT
used: 17.3 GiB (7.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 46.98 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 33.0 C mobo: N/A
Memory: total: 48 GiB available: 46.98 GiB used: 4.74 GiB (10.1%)
Processes: 371 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.74 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1422 libs: 388 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.36
System install date: 2024-11-04
Last full system update: 2024-11-09
Relevant software: timeshift NetworkManager dracut nvidia-dkms
❯ cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=F95B-D5C5 /boot/efi vfat umask=0077 0 2
UUID=400c2f0d-8924-468c-8c78-7fcabce37e16 / btrfs subvol=/@,noatime,compress=zstd 0 0
UUID=400c2f0d-8924-468c-8c78-7fcabce37e16 /home btrfs subvol=/@home,noatime,compress=zstd 0 0
UUID=400c2f0d-8924-468c-8c78-7fcabce37e16 /root btrfs subvol=/@root,noatime,compress=zstd 0 0
UUID=400c2f0d-8924-468c-8c78-7fcabce37e16 /srv btrfs subvol=/@srv,noatime,compress=zstd 0 0
UUID=400c2f0d-8924-468c-8c78-7fcabce37e16 /var/cache btrfs subvol=/@cache,noatime,compress=zstd 0 0
UUID=400c2f0d-8924-468c-8c78-7fcabce37e16 /var/log btrfs subvol=/@log,noatime,compress=zstd 0 0
UUID=400c2f0d-8924-468c-8c78-7fcabce37e16 /var/tmp btrfs subvol=/@tmp,noatime,compress=zstd 0 0
tmpfs /tmp tmpfs noatime,mode=1777 0 0
/dev/nvme1n1p1 /home/shyuuhei/Game ntfs nofail 0 0
/dev/nvme0n1p1 /home/shyuuhei/Backup btrfs subvol=/@timeshift,noatime,nodiratime,nofail 0 0
