systemctl status bluetooth;
╭─[email protected] in ~ as 🧙 took 2m13s
[🔴] × systemctl status bluetooth
○ bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: inactive (dead)
Docs: man:bluetoothd(8)
feb 11 12:31:01 0111010101011 systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
feb 11 12:31:43 0111010101011 systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
garuda-inxi;
╭─[email protected] in ~ as 🧙 took 4s
╰─λ sudo garuda-inxi --help
Kernel: 6.1.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=4cb2ec4b-dcc0-401a-9b17-00e2420e854e rw [email protected]
quiet
cryptdevice=UUID=f60b5a45-88c2-4b96-a9fc-44b34879b241:luks-f60b5a45-88c2-4b96-a9fc-44b34879b241
root=/dev/mapper/luks-f60b5a45-88c2-4b96-a9fc-44b34879b241 quiet splash
resume=/dev/mapper/luks-54ea68d6-4688-4450-8538-97a886e39679 loglevel=3
wm: kwin_x11 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop System: LENOVO product: 90N9000BMW v: IdeaCentre G5 14IMB05
serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: LENOVO model: 370A v: SDK0J40700 WIN 3258175487150 serial: N/A
UEFI: LENOVO v: O4HKT22A date: 06/08/2020
Info: model: Intel Core i5-10400F socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 3
microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3895 high: 4001 min/max: 800/4300 base/boost: 2871/8300
scaling: driver: intel_pstate governor: performance volts: 0.8 V
ext-clock: 100 MHz cores: 1: 4000 2: 4000 3: 2838 4: 3901 5: 4001 6: 4000
7: 4000 8: 4000 9: 4000 10: 4000 11: 4000 12: 4000 bogomips: 69597
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ZOTAC
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f08 class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.7
Screen-1: 0 s-res: 4080x2160 s-dpi: 94 s-size: 1103x584mm (43.43x22.99")
s-diag: 1248mm (49.14")
Monitor-1: DP-0 pos: primary,bottom-c res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.04x11.26") diag: 584mm (22.99") modes: N/A
Monitor-2: DP-3 pos: middle-r res: 1080x1920 hz: 60 dpi: 96
size: 286x509mm (11.26x20.04") diag: 584mm (22.99") modes: N/A
Monitor-3: DP-4 pos: middle-l res: 1080x1920 hz: 60 dpi: 96
Monitor-4: HDMI-0 pos: top-center res: 1920x1080 hz: 60 dpi: 96
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: Intel Comet Lake PCH-V cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound API: ALSA v: k6.1.10-zen1-1-zen running: yes
port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:c822
Local Storage: total: 1.38 TiB used: 37.55 GiB (2.7%)
model: MZVLB512HBJQ-000L7 size: 476.94 GiB block-size: physical: 512 B
rev: 5M2QEXF7 temp: 41.9 C scheme: GPT
SMART: yes health: PASSED on: 164d 22h cycles: 997
read-units: 94,770,593 [48.5 TB] written-units: 70,106,823 [35.8 TB]
model: WD10EZEX-08WN4A0 family: Blue size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: 1A02 temp: 42 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 158d 5h cycles: 933
ID-1: / raw-size: 459.65 GiB size: 459.65 GiB (100.00%)
used: 37.55 GiB (8.2%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-f60b5a45-88c2-4b96-a9fc-44b34879b241
used: 752 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 459.65 GiB size: 459.65 GiB (100.00%)
ID-4: /var/log raw-size: 459.65 GiB size: 459.65 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.65 GiB size: 459.65 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.45 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.99 GiB used: 0 KiB (0.0%)
mapped: luks-54ea68d6-4688-4450-8538-97a886e39679
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 362 Uptime: 53m wakeups: 0 Memory: 15.45 GiB
used: 7.01 GiB (45.4%) Init: systemd v: 252 default: graphical
pkgs: 2023 libs: 557 tools: gnome-software,octopi,pamac,paru
inxi: 3.3.25
Garuda (2.6.14-1):
System install date: 2023-01-16
Last full system update: 2023-02-11
In addition;
╭─[email protected] in ~ as 🧙 took 14s
╰─λ systemctl start bluetooth
╭─[email protected] in ~ as 🧙 took 1s
╰─λ systemctl status bluetooth
feb 11 13:30:47 0111010101011 systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
