Can someone help me with virsh
So i decided to try QEMU/KVM
I setup up windows 10.
Now i have an issue with the resolution, i need to edit the XML.
I am trying to follow this:
It is probably not hard to do but i do not get how it works.
I enter the command sudo virsh edit Windows10 in terminal.
I get the domain stuff and the section but i have no idea how to edit it, it is being very difficult.
I already searched around the web but it gets even more confusing.
Kernel: 6.11.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=34819b7f-d663-441b-bdcc-f1157c3768e0 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.1 tk: Qt v: N/A info: frameworks v: 6.7.0
Type: Desktop Mobo: Gigabyte model: B660M DS3H DDR4 v: x.x
Megatrends LLC. v: F6 date: 08/08/2022
Info: model: 12th Gen Intel Core i3-12100F bits: 64 type: MT MCP
microcode: 0x36
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4300 min/max: 800/4300 scaling: driver: intel_pstate
governor: performance cores: 1: 4300 2: 4300 3: 4300 4: 4300 5: 4300 6: 4300
7: 4300 8: 4300 bogomips: 52838
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: Gigabyte driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,
HDMI-A-1, HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73df
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.3
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-2 mapped: DisplayPort-1 model: MSI MAG342CQR
serial: <filter> built: 2021 res: 3440x1440 dpi: 110 gamma: 1.2
size: 797x333mm (31.38x13.11") diag: 864mm (34") modes: max: 3440x1440
min: 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.1
navi22 LLVM 18.1.8 DRM 3.59 6.11.3-zen1-1-zen) device-ID: 1002:73df
memory: 11.72 GiB unified: no
API: Vulkan v: 1.3.295 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.2.4-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.4-arch1.1 (LLVM
Device-2: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
API: ALSA v: k6.11.3-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
wpa_supplicant
Local Storage: total: 931.51 GiB used: 706.64 GiB (75.9%)
model: WD Blue SN570 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 234110WD temp: 35.9 C scheme: GPT
used: 706.64 GiB (75.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.46 GiB used: 1.76 GiB (11.4%)
System Temperatures: cpu: 35.0 C mobo: 32.0 C gpu: amdgpu temp: 54.0 C
mem: 48.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 988
Memory: total: 16 GiB available: 15.46 GiB used: 7.49 GiB (48.5%)
Processes: 361 Power: uptime: 3h 51m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
Packages: 1977 pm: pacman pkgs: 1976 libs: 545 tools: aura,
gnome-software, octopi, pamac, paru pm: rpm pkgs: 1 Compilers: gcc: 14.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date:     2024-07-22
Last full system update: 2024-10-17 ↻
