Hi again,
Can someone help me install this driver?
https://aur.archlinux.org/packages/brscan3
I tried but i’m probably just doing it wrong.
Kernel: 6.10.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=34819b7f-d663-441b-bdcc-f1157c3768e0 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Desktop Mobo: Gigabyte model: B660M DS3H DDR4 v: x.x
Megatrends LLC. v: F6 date: 08/08/2022
Info: model: 12th Gen Intel Core i3-12100F bits: 64 type: MT MCP
microcode: 0x35
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 high: 802 min/max: 800/4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 802 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 52838
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2 empty: DP-1, HDMI-A-1, HDMI-A-2, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 res: 2752x1152 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
navi22 LLVM 18.1.8 DRM 3.57 6.10.6-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.1.6-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.6-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
API: ALSA v: k6.10.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
Local Storage: total: 931.51 GiB used: 540.12 GiB (58.0%)
model: WD Blue SN570 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 234110WD temp: 35.9 C scheme: GPT
used: 540.12 GiB (58.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.0 C mobo: 30.0 C gpu: amdgpu temp: 59.0 C
mem: 52.0 C
Memory: total: 16 GiB available: 15.46 GiB used: 7.89 GiB (51.0%)
Processes: 345 Power: uptime: 1h 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
Packages: 1751 pm: pacman pkgs: 1750 libs: 505 tools: aura,
gnome-software, octopi, pamac, paru pm: rpm pkgs: 1 Compilers: gcc: 14.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2024-07-22
Last full system update: 2024-09-13
