Can only mount drive with command
I have a SSD which previously contained a windows install that no matter what i do i cant mount without a command but works perfectly fine on Windows and even then it is read-only, I have it re-formatted it several times to various file systems but to no effect, after trying to mount it through thunar file manager i got the error “no object for dbus interface” which led to me trying to change the UUID of the drive but to no progress, I should also mention that when i boot my pc GRUB shows it as a windows install.
Hre are the commands i have tried running so far.
╭─j@J in ~ took 8ms
[🔴] × sudo tune2fs -U random /dev/sdd1
[sudo] password for j:
tune2fs 1.47.0 (5-Feb-2023)
tune2fs: Bad magic number in super-block while trying to open /dev/sdd1
/dev/sdd1 contains a exfat file system labelled '480'
╭─j@J in ~ as 🧙 took 2s
[🔴] × dumpe2fs /dev/sdd1 | grep superblock
dumpe2fs 1.47.0 (5-Feb-2023)
dumpe2fs: Permission denied while trying to open /dev/sdd1
Couldn't find valid filesystem superblock.
╭─j@J in ~ as 🧙 took 7ms
[[🔴]|[]] =>  ╰─λ sudo dumpe2fs /dev/sdd1 | grep superblock
dumpe2fs: Bad magic number in super-block while trying to open /dev/sdd1
╭─j@J in ~ as 🧙 took 25ms
[[🔴]|[]] =>  ╰─λ fsck /dev/sdd1
fsck from util-linux 2.39.3
fsck.fat 4.2 (2021-01-31)
open: Permission denied
╭─j@J in ~ as 🧙 took 3ms
[🔴] × sudo fsck /dev/sdd1
Logical sector size is zero.
Kernel: 6.7.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f343e266-2bba-4823-826a-311cb6319709 rw rootflags=subvol=@
resume=UUID=29f15791-f1dd-436f-902e-804af7e61bb0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A info: frameworks v: 6.0.0
wm: kwin_x11 tools: avail: xscreensaver vt: 2 dm: SDDM Distro: Garuda
Type: Desktop System: Gigabyte product: B650M AORUS ELITE v: N/A
Mobo: Gigabyte model: B650M AORUS ELITE serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F8c
date: 08/16/2023
Device-1: ps-controller-battery-e8:47:3a:d3:8e:51 model: N/A serial: N/A
charge: N/A status: charging
Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4880 high: 5240 min/max: 400/5453 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 5175 2: 5203 3: 3561
4: 5233 5: 5240 6: 5133 7: 5239 8: 5175 9: 4635 10: 3531 11: 5222 12: 5224
bogomips: 112589
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2 off: DP-3 empty: DP-1,HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 39.0 C
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1015x571mm (39.96x22.48")
s-diag: 1165mm (45.85")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary model: LG (GoldStar)
ULTRAGEAR+ serial: <filter> built: 2023 res: 3840x2160 dpi: 93 gamma: 1.2
size: 1050x590mm (41.34x23.23") diag: 1204mm (47.4") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
Monitor-2: DP-3 mapped: DisplayPort-2 note: disabled model: Samsung
built: 2010 res: 3840x2160 dpi: 55 gamma: 1.2 size: 160x90mm (6.3x3.54")
diag: 1021mm (40.2") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6750 XT (radeonsi
navi22 LLVM 17.0.6 DRM 3.57 6.7.8-zen1-1-zen) device-ID: 1002:73df
memory: 11.72 GiB unified: no
API: Vulkan v: 1.3.279 layers: 17 device: 0 type: discrete-gpu name: AMD
Radeon RX 6750 XT (RADV NAVI22) driver: mesa radv v: 24.0.2-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 24.0.2-arch1.2 device-ID: 1002:164e surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.0.2-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Realtek LG Monitor HP MIC driver: hid-generic,usbhid type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.4.4:8
chip-ID: 0bda:4027 class-ID: 0300 serial: <filter>
API: ALSA v: k6.7.8-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-2: virbr1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0bda:8771
Local Storage: total: 18.67 TiB used: 16.81 TiB (90.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000D2048G
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 31.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000AS0002-1NA17Z
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5980 serial: <filter> fw-rev: AR15 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST8000AS0002-1NA17Z
tech: HDD rpm: 5980 serial: <filter> fw-rev: RT18 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SDSSDXPS480G
tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
ID-1: / raw-size: 1.83 TiB size: 1.83 TiB (100.00%) used: 1.67 TiB (91.4%)
used: 25.8 MiB (8.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
used: 1.67 TiB (91.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-1: swap-1 type: zram size: 30.5 GiB used: 1.2 GiB (3.9%) priority: 100
System Temperatures: cpu: 52.4 C mobo: 34.0 C
GPU: device: amdgpu temp: 38.0 C device: amdgpu temp: 45.0 C mem: 42.0 C
fan: 0 watts: 9.00
Memory: total: 32 GiB note: est. available: 30.5 GiB used: 11 GiB (36.1%)
Processes: 424 Power: uptime: 1h 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,
Packages: 2506 pm: pacman pkgs: 2446 libs: 589 tools: gnome-software,
octopi, pamac, paru, yay pm: flatpak pkgs: 60 Compilers: clang: 17.0.6
gcc: 13.2.1 alt: 12 Shell: garuda-inxi default: Bash v: 5.2.26
running-in: yakuake inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2023-07-10
Last full system update: 2024-03-08
Failed units:            minidlna.service preload.service syncthing.service systemd-vconsole-setup.service dev-disk-by-uuid-29f15791-f1dd-436f-902e-804af7e61bb0.swap
Have you tried,
https://www.linode.com/community/questions/20599/how-do-i-fix-a-bad-magic-number-in-super-block-error
You can skip the linode’s enter into rescue mode step. The rest should be relevant for you.
You have a lot of failed systemd services. I’m thinking you have messed your system up by excessive uninformed tinkering.
That’s how everyone learns Linux (I’m not being critical), so fix it till it breaks. :smile:
