Can not reply to previous post (issue updating system)
pacman: error while loading shared libraries: libgpgme.so.11: cannot open shared obj
ect file: No such file or directory
Press enter to exit
Kernel: 6.14.9-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 15.1.1 clocksource: tsc avail: hpet,acpi_pm parameters: pti=on
root=UUID=90bad688-87c2-4fa2-a41d-19c0de4179f2 rw rootflags=subvol=@
quiet rd.luks.uuid=55e381a9-1da2-4774-9917-9126737d9ffd loglevel=3
wm: kwin_wayland vt: 1 dm: SDDM Distro: Arch Linux
Mobo: ASUSTeK model: ROG STRIX B850-I GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 0825 date: 11/29/2024
Device-1: ps-controller-battery-14:3a:9a:84:09:6f model: N/A serial: N/A
charge: N/A status: full
Device-2: ps-controller-battery-41:42:ae:08:af:9c model: N/A serial: N/A
Info: model: AMD Ryzen 7 8700G w/ Radeon 780M Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA705206
Speed (MHz): avg: 2403 min/max: 400/5177 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2403 2: 2403 3: 2403
4: 2403 5: 2403 6: 2403 7: 2403 8: 2403 9: 2403 10: 2403 11: 2403 12: 2403
13: 2403 14: 2403 15: 2403 16: 2403 bogomips: 134146
Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
7800 XT] vendor: XFX driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,DP-3 empty: DP-2,HDMI-A-1,Writeback-1 bus-ID: 03:00.0
chip-ID: 1002:747e class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-4, DP-5, DP-6, DP-7, DP-8, HDMI-A-2, Writeback-2 bus-ID: 0d:00.0
chip-ID: 1002:15bf class-ID: 0300 temp: 35.0 C
gpu: amdgpu d-rect: 3440x2880 display-ID: 0
Monitor-1: DP-1 pos: bottom model: Samsung S34CG50 serial: <filter>
built: 2024 res: mode: 3440x1440 hz: 100 scale: 114% (1.15) to: 2991x1252
dpi: 109 gamma: 1.2 size: 798x334mm (31.42x13.15") diag: 869mm (34.2")
modes: max: 3440x1440 min: 720x400
Monitor-2: DP-3 pos: primary,top model: Samsung S34CG50 serial: <filter>
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 19.1.7 DRM 3.61 6.14.9-hardened1-1-hardened)
device-ID: 1002:747e memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 25.1.2-arch1.1
device-ID: 1002:747e surfaces: N/A device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV PHOENIX) driver: mesa radv v: 25.1.2-arch1.1
device-ID: 1002:15bf surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.1.2-arch1.1 (LLVM
[Rembrandt/Strix] vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:1640
Device-3: Sony DualSense wireless controller (PS5)
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 054c:0ce6 class-ID: 0300
Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4
chip-ID: 0b05:1be1 class-ID: 0300
Device-5: Sony DualShock 4 [CUH-ZCT2x]
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 9-1.4.3:4 chip-ID: 054c:09cc class-ID: 0300
API: ALSA v: k6.14.9-hardened1-1-hardened status: kernel-api tools: N/A
Device-1: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0 chip-ID: 8086:125c
Device-2: Sony DualSense wireless controller (PS5)
Local Storage: total: 2.05 TiB used: 231.23 GiB (11.0%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 37.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: Flash Drive
size: 239.02 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 1100 scheme: MBR
ID-1: / raw-size: 71.28 GiB size: 71.28 GiB (100.00%)
used: 57.25 GiB (80.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-55e381a9-1da2-4774-9917-9126737d9ffd
used: 31.4 MiB (32.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 71.28 GiB size: 71.28 GiB (100.00%)
ID-4: /var/log raw-size: 71.28 GiB size: 71.28 GiB (100.00%)
ID-5: /var/tmp raw-size: 71.28 GiB size: 71.28 GiB (100.00%)
ID-1: swap-1 type: zram size: 60.48 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.6 C mobo: 34.5 C
GPU: device: amdgpu temp: 35.0 C watts: 26.18 device: amdgpu temp: 49.0 C
mem: 48.0 C fan: 123 watts: 42.00
Memory: total: 64 GiB note: est. available: 60.48 GiB used: 5.81 GiB (9.6%)
Processes: 400 Power: uptime: 8m states: freeze,mem suspend: deep
avail: s2idle wakeups: 0 services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 0 tools: octopi,paru Compilers: gcc: 15.1.1
Shell: garuda-inxi default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
pacman: error while loading shared libraries: libgpgme.so.11: cannot open shared object file: No such file or directory
Garuda ():
System install date:     2025-02-05
Last full system update: 2025-06-05
Relevant software:       snapper NetworkManager
Fascinating.
I think I’m losing my faith!
Can not run updates at all; otherwise somewhat functional; after being advised to overwrite packages on a possibly exploited system.
Oh yes, I see…
Without the circular arrow.
If I were you, I’d back up relevant data and perform a clean install.
Great idea to follow such advices. Don“t know what you did but libgpgme.so.11 is very old. Current pacman is using libgpgme.so.45
Another advice? Reinstall whole system.
You can try temporarily symlinking the missing library against the version you currently have installed. It’s a little hacky, but it may allow you to properly update and get out of this mess. It worked recently for a couple folks in this thread from another forum: How to fix pgpme not found on pacman - Pacman - EndeavourOS
After you are able to update the system, be sure to remove the symlink, otherwise you may run into issues down the line.
You should be able to run garuda-update remote fix. Running this command should download a static linked version of pacman that should be capable of updating your system into a working state.
╰─λ garuda-update remote fix
[sudo] password for jiofejfje:
This will reset a few configuration files like pacman.conf šŸ›‘
Are you sure? (y/n)
y
--2025-06-24 10:45:54--  https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Resolving pkgbuild.com (pkgbuild.com)... 78.46.178.133, 2a01:4f8:c2c:51e2::1
Connecting to pkgbuild.com (pkgbuild.com)|78.46.178.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 4606712 (4.4M) [application/octet-stream]
Saving to: ā€˜/tmp/tmp.8QqC8qMF1B’
/tmp/tmp.8QqC8qMF1B  100%[======================>]   4.39M  3.54MB/s    in 1.2s
2025-06-24 10:45:56 (3.54 MB/s) - ā€˜/tmp/tmp.8QqC8qMF1B’ saved [4606712/4606712]
.--.                  Pacman v6.0.1 - libalpm v13.0.1
/ _.-' .-.  .-.  .-.   Copyright (C) 2006-2021 Pacman Development Team
\  '-. '-'  '-'  '-'   Copyright (C) 2002-2006 Judd Vinet
This program may be freely redistributed under
the terms of the GNU General Public License.
--2025-06-24 10:45:56--  https://gitlab.com/garuda-linux/tools/garuda-tools/-/raw/master/data/pacman-default.conf
Resolving gitlab.com (gitlab.com)... 172.65.251.78, 2606:4700:90:0:f22e:fbec:5bed:a9b9
Connecting to gitlab.com (gitlab.com)|172.65.251.78|:443... connected.
Length: 2502 (2.4K) [text/plain]
Saving to: ā€˜/etc/pacman.conf’
/etc/pacman.conf     100%[======================>]   2.44K  --.-KB/s    in 0s
2025-06-24 10:45:57 (39.8 MB/s) - ā€˜/etc/pacman.conf’ saved [2502/2502]
--2025-06-24 10:45:57--  https://archlinux.org/mirrorlist/all/
Resolving archlinux.org (archlinux.org)... 95.217.163.246, 2a01:4f9:c010:6b1f::1
Connecting to archlinux.org (archlinux.org)|95.217.163.246|:443... connected.
Length: 52116 (51K) [text/plain]
Saving to: ā€˜/etc/pacman.d/mirrorlist’
/etc/pacman.d/mirror 100%[======================>]  50.89K   314KB/s    in 0.2s
2025-06-24 10:45:58 (314 KB/s) - ā€˜/etc/pacman.d/mirrorlist’ saved [52116/52116]
--2025-06-24 10:45:58--  https://aur.chaotic.cx/mirrorlist.txt
Resolving aur.chaotic.cx (aur.chaotic.cx)... 104.26.4.205, 104.26.5.205, 172.67.71.42, ...
Connecting to aur.chaotic.cx (aur.chaotic.cx)|104.26.4.205|:443... connected.
Length: unspecified [text/plain]
Saving to: ā€˜/etc/pacman.d/chaotic-mirrorlist’
/etc/pacman.d/chaoti     [ <=>                   ]   2.04K  --.-KB/s    in 0s
2025-06-24 10:45:58 (8.22 MB/s) - ā€˜/etc/pacman.d/chaotic-mirrorlist’ saved [2087]
pacman-conf: error while loading shared libraries: libgpgme.so.11: cannot open shared object file: No such file or directory
mkdir: cannot create directory ā€˜ā€™: No such file or directory
gpg: keybox '/root/.gnupg/pubring.kbx' created
gpg: /root/.gnupg/trustdb.gpg: trustdb created
gpg: no ultimately trusted keys found
chmod: cannot access '/trustdb.gpg': No such file or directory
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
gpg: directory '/root/.gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/root/.gnupg/openpgp-revocs.d/1624C862735E094C7810A924232F4FA92F248DF2.rev'
gpg: Done
==> Updating trust database...
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:   0  trust: 0-, 0q, 0n, 0m, 0f, 1u
==> ERROR: You do not have sufficient permissions to read the pacman keyring.
==> Use 'pacman-key --init' to correct the keyring permissions.
Failed to populate keyrings
Failed to install some keys
Failed to ensure some keys are up to date
warning: config file /etc/pacman.conf, line 39: directive 'DownloadUser' in section 'options' not recognized.
garuda                 53.0 KiB  88.6 KiB/s 00:01 [--------------------------] 100%
core                  116.5 KiB   195 KiB/s 00:01 [--------------------------] 100%
extra                   7.8 MiB  7.42 MiB/s 00:01 [--------------------------] 100%
multilib              134.9 KiB   225 KiB/s 00:01 [--------------------------] 100%
chaotic-aur           629.9 KiB   869 KiB/s 00:01 [--------------------------] 100%
warning: archlinux-keyring-20250430.1-1 is up to date -- reinstalling
resolving dependencies...
Package (2)                  Old Version   New Version   Net Change  Download Size
core/archlinux-keyring       20250430.1-1  20250430.1-1    0.00 MiB       1.18 MiB
chaotic-aur/chaotic-keyring  20230616-1    20250614-1     -0.01 MiB       0.02 MiB
Total Download Size:    1.20 MiB
Total Installed Size:   1.70 MiB
Net Upgrade Size:      -0.01 MiB
:: Retrieving packages...
chaotic-keyring-...    20.1 KiB  49.4 KiB/s 00:00 [--------------------------] 100%
archlinux-keyrin...  1208.4 KiB  1921 KiB/s 00:01 [--------------------------] 100%
Total (2/2)          1228.5 KiB  1730 KiB/s 00:01 [--------------------------] 100%
(2/2) checking keys in keyring                     [--------------------------] 100%
warning: Public keyring not found; have you run 'pacman-key --init'?
downloading required keys...
error: keyring is not writable
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
What in the…?
How did you manage this
Like, genuinely, how?
This seems like a severe case of partial upgrades. Did you make use of any kind of ignore statements in your pacman.conf?
These commands should fix your issues. Please post the output regardless of outcome so we can confirm it worked:
wget https://london.mirror.pkgbuild.com/core/os/x86_64/pacman-7.0.0.r6.gc685ae6-6-x86_64.pkg.tar.zst -O /tmp/pacman.pkg.tar.zst
pacman -U /tmp/pacman.pkg.tar.zst
Updates were not downloading over a period of months from US mirrors; seemed like strategic packages that allowed for manipulation of Dolphin, Firedragon, Librewolf, Kwallet, and various other packages guessing for payloads; those packages then installed somehow after.
╰─λ wget https://london.mirror.pkgbuild.com/core/os/x86_64/pacman-7.0.0.r6.gc685ae6-6-x86_64.pkg.tar.zst -O /tmp/pacman.pkg.tar.zst
--2025-06-24 11:29:33--  https://london.mirror.pkgbuild.com/core/os/x86_64/pacman-7.0.0.r6.gc685ae6-6-x86_64.pkg.tar.zst
Resolving london.mirror.pkgbuild.com (london.mirror.pkgbuild.com)... 185.73.44.89, 2001:ba8:0:4030::2
Connecting to london.mirror.pkgbuild.com (london.mirror.pkgbuild.com)|185.73.44.89|:443... connected.
Length: 946731 (925K) [application/zstd]
Saving to: ā€˜/tmp/pacman.pkg.tar.zst’
/tmp/pacman.pkg.tar. 100%[======================>] 924.54K  90.3KB/s    in 9.4s
2025-06-24 11:29:43 (98.8 KB/s) - ā€˜/tmp/pacman.pkg.tar.zst’ saved [946731/946731]
Are you sure? (y/n)
y
--2025-06-24 11:30:45--  https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
Saving to: ā€˜/tmp/tmp.QOk3xmBDTz’
/tmp/tmp.QOk3xmBDTz  100%[======================>]   4.39M  3.33MB/s    in 1.3s
2025-06-24 11:30:47 (3.33 MB/s) - ā€˜/tmp/tmp.QOk3xmBDTz’ saved [4606712/4606712]
--2025-06-24 11:30:47--  https://gitlab.com/garuda-linux/tools/garuda-tools/-/raw/master/data/pacman-default.conf
2025-06-24 11:30:47 (32.4 MB/s) - ā€˜/etc/pacman.conf’ saved [2502/2502]
--2025-06-24 11:30:47--  https://archlinux.org/mirrorlist/all/
/etc/pacman.d/mirror 100%[======================>]  50.89K   197KB/s    in 0.3s
2025-06-24 11:30:49 (197 KB/s) - ā€˜/etc/pacman.d/mirrorlist’ saved [52116/52116]
--2025-06-24 11:30:49--  https://aur.chaotic.cx/mirrorlist.txt
Resolving aur.chaotic.cx (aur.chaotic.cx)... 104.26.5.205, 104.26.4.205, 172.67.71.42, ...
Connecting to aur.chaotic.cx (aur.chaotic.cx)|104.26.5.205|:443... connected.
2025-06-24 11:30:49 (6.16 MB/s) - ā€˜/etc/pacman.d/chaotic-mirrorlist’ saved [2087]
garuda                 53.0 KiB  37.2 KiB/s 00:01 [--------------------------] 100%
core                  116.5 KiB   177 KiB/s 00:01 [--------------------------] 100%
extra                   7.8 MiB  5.85 MiB/s 00:01 [--------------------------] 100%
multilib              134.9 KiB   180 KiB/s 00:01 [--------------------------] 100%
chaotic-aur           629.9 KiB   617 KiB/s 00:01 [--------------------------] 100%
archlinux-keyrin...  1208.4 KiB  3.38 MiB/s 00:00 [--------------------------] 100%
chaotic-keyring-...    20.1 KiB  46.7 KiB/s 00:00 [--------------------------] 100%
Total (2/2)          1228.5 KiB  1963 KiB/s 00:01 [--------------------------] 100%
I see okay.
Let’s try that again.
wget https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static -O /tmp/pacman-static
chmod +x /tmp/pacman-static
/tmp/pacman-static -U /tmp/pacman.pkg.tar.zst
╰─λ wget https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static -O /tmp/pacman-static
--2025-06-24 14:40:25--  https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
Saving to: ā€˜/tmp/pacman-static’
/tmp/pacman-static    100%[========================>]   4.39M  3.56MB/s    in 1.2s
2025-06-24 14:40:28 (3.56 MB/s) - ā€˜/tmp/pacman-static’ saved [4606712/4606712]
--2025-06-24 14:40:28--  https://london.mirror.pkgbuild.com/core/os/x86_64/pacman-7.0.0.r6.gc685ae6-6-x86_64.pkg.tar.zst
/tmp/pacman.pkg.tar.z 100%[========================>] 924.54K  1.26MB/s    in 0.7s
2025-06-24 14:40:30 (1.26 MB/s) - ā€˜/tmp/pacman.pkg.tar.zst’ saved [946731/946731]
error: you cannot perform this operation unless you are root.
Are you sure? (y/n)
y
--2025-06-24 14:40:45--  https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
Saving to: ā€˜/tmp/tmp.8sioA2qS3Q’
/tmp/tmp.8sioA2qS3Q   100%[========================>]   4.39M  3.59MB/s    in 1.2s
2025-06-24 14:40:48 (3.59 MB/s) - ā€˜/tmp/tmp.8sioA2qS3Q’ saved [4606712/4606712]
--2025-06-24 14:40:48--  https://gitlab.com/garuda-linux/tools/garuda-tools/-/raw/master/data/pacman-default.conf
/etc/pacman.conf      100%[========================>]   2.44K  --.-KB/s    in 0s
2025-06-24 14:40:48 (31.5 MB/s) - ā€˜/etc/pacman.conf’ saved [2502/2502]
--2025-06-24 14:40:48--  https://archlinux.org/mirrorlist/all/
/etc/pacman.d/mirrorl 100%[========================>]  50.89K   183KB/s    in 0.3s
2025-06-24 14:40:49 (183 KB/s) - ā€˜/etc/pacman.d/mirrorlist’ saved [52116/52116]
--2025-06-24 14:40:49--  https://aur.chaotic.cx/mirrorlist.txt
Resolving aur.chaotic.cx (aur.chaotic.cx)... 172.67.71.42, 104.26.5.205, 104.26.4.205, ...
Connecting to aur.chaotic.cx (aur.chaotic.cx)|172.67.71.42|:443... connected.
/etc/pacman.d/chaotic     [ <=>                     ]   2.04K  --.-KB/s    in 0s
2025-06-24 14:40:50 (8.66 MB/s) - ā€˜/etc/pacman.d/chaotic-mirrorlist’ saved [2087]
garuda                   53.0 KiB  58.5 KiB/s 00:01 [---------------------------] 100%
core                    116.5 KiB   201 KiB/s 00:01 [---------------------------] 100%
extra                     7.8 MiB  7.23 MiB/s 00:01 [---------------------------] 100%
multilib                134.9 KiB   224 KiB/s 00:01 [---------------------------] 100%
chaotic-aur             629.9 KiB   920 KiB/s 00:01 [---------------------------] 100%
archlinux-keyring-...  1208.4 KiB  5.13 MiB/s 00:00 [---------------------------] 100%
chaotic-keyring-20...    20.1 KiB  47.1 KiB/s 00:00 [---------------------------] 100%
Total (2/2)            1228.5 KiB  1969 KiB/s 00:01 [---------------------------] 100%
(2/2) checking keys in keyring                       [---------------------------] 100%
Well, you forgot to run it as root. It seems like you’re just copying all the commands instead of looking at the output of each command individually…
sudo /tmp/pacman-static -U /tmp/pacman.pkg.tar.zst
Busy with work, thank you, still a considerable amount of errors though. Konsole is overwriting parts of the transaction again. Here are some of the errors.
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/setlocalversion
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/show_delta
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/sign-file
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/sign-file.c
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/sorttable
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/sorttable.c
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/spdxcheck-test.sh
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/spdxcheck.py
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/spdxexclude
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/spelling.txt
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/sphinx-pre-install
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/split-man.pl
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/ssl-common.h
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/stackdelta
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/stackusage
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/subarch.include
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/syscall.tbl
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/syscallhdr.sh
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/syscallnr.sh
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/syscalltbl.sh
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/tags.sh
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/target.json
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/tools-support-relr.sh
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/tracing/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/tracing/draw_functrace.py
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/tracing/ftrace-bisect.sh
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/unifdef.c
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/ver_linux
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/verify_builtin_ranges.awk
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/xen-hypercalls.sh
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/scripts/xz_wrap.sh
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/Kconfig.hardening
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/apparmor/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/apparmor/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/integrity/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/integrity/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/integrity/evm/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/integrity/evm/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/integrity/ima/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/integrity/ima/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/ipe/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/ipe/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/keys/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/keys/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/keys/trusted-keys/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/keys/trusted-keys/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/landlock/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/landlock/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/loadpin/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/loadpin/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/lockdown/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/lockdown/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/safesetid/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/safesetid/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/selinux/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/selinux/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/smack/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/smack/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/tomoyo/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/tomoyo/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/yama/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/security/yama/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/ac97/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/ac97/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/aoa/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/aoa/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/aoa/codecs/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/aoa/codecs/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/aoa/fabrics/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/aoa/fabrics/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/aoa/soundbus/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/aoa/soundbus/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/arm/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/arm/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/atmel/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/atmel/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/core/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/core/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/core/seq/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/core/seq/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/drivers/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/drivers/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/firewire/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/firewire/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/hda/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/hda/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/isa/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/isa/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/mips/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/mips/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/oss/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/oss/dmasound/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/oss/dmasound/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/parisc/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/parisc/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/pci/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/pci/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/pci/hda/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/pci/hda/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/pcmcia/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/pcmcia/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/ppc/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/ppc/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/sh/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/sh/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/adi/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/adi/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/amd/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/amd/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/amd/acp/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/amd/acp/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/apple/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/apple/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/atmel/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/atmel/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/au1x/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/au1x/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/bcm/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/bcm/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/cirrus/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/cirrus/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/codecs/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/codecs/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/dwc/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/dwc/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/fsl/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/fsl/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/generic/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/generic/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/google/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/google/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/hisilicon/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/hisilicon/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/img/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/img/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/intel/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/intel/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/intel/avs/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/intel/avs/boards/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/intel/avs/boards/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/intel/boards/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/intel/boards/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/jz4740/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/jz4740/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/kirkwood/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/kirkwood/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/loongson/
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/loongson/Kconfig
warning: could not get file information for usr/lib/modules/6.14.9-zen1-1-zen/build/sound/soc/mediatek/
(parts removed of this section of errors due to character limits continues with similar output)
(1/5) Rejecting pacman transaction if running in snapshot...
(2/5) Performing snapper pre snapshots for the following configurations...
==> root: 254
(3/5) Saving Linux kernel modules...
(4/5) Removing initramfs...
/usr/share/libalpm/scripts/dracut-remove: line 5: /usr/lib/modules/6.15.0-1-mainline/pkgbase: No such file or directory
(318/318) upgrading vulkan-swrast                    [---------------------------] 100%
ldconfig: /usr/lib/libQt6WebEngineQuick.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libQt6WebEngineQuick.so.6 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libQt6WebEngineQuick.so.6.9.1 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libQt6WebEngineQuickDelegatesQml.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libQt6WebEngineQuickDelegatesQml.so.6 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libQt6WebEngineQuickDelegatesQml.so.6.9.1 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libQt6WebEngineWidgets.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libQt6WebEngineWidgets.so.6 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libQt6WebEngineWidgets.so.6.9.1 is not an ELF file - it has the wrong magic bytes at the start.
( 1/33) Restoring Linux kernel modules...
++ uname -r
+ KVER=6.14.9-hardened1-1-hardened
+ test -e /usr/lib/modules/backup/6.14.9-hardened1-1-hardened
+ rsync -AHXal --ignore-existing /usr/lib/modules/backup/6.14.9-hardened1-1-hardened /usr/lib/modules/
+ rm -rf /usr/lib/modules/backup
( 2/33) Creating system user accounts...
( 3/33) Updating journal message catalog...
( 4/33) Reloading system manager configuration...
( 5/33) Reloading user manager configuration...
( 6/33) Updating udev hardware database...
( 7/33) Restarting marked services...
( 8/33) Creating temporary files...
( 9/33) Reloading device manager configuration...
(10/33) Arming ConditionNeedsUpdate...
(11/33) Updating the MIME type database...
(12/33) Rebuilding certificate stores...
(13/33) Updating module dependencies...
(14/33) Checking for package with missing dependencies...
(15/33) Updating initramfs...
:: Building initramfs for linux-hardened (6.14.11-hardened1-1-hardened)
/gpg.conf: line 1: no-greeting: command not found
/gpg.conf: line 2: no-permission-warning: command not found
/gpg.conf: line 3: keyserver-options: command not found
/gpg.conf: line 4: keyserver-options: command not found
/gpg.conf: line 5: keyserver-options: command not found
/gpg-agent.conf: line 1: disable-scdaemon: command not found
:: Building fallback initramfs for linux-hardened (6.14.11-hardened1-1-hardened)
:: Building initramfs for linux-zen (6.15.3-zen1-1-zen)
:: Building fallback initramfs for linux-zen (6.15.3-zen1-1-zen)
:: Building initramfs for linux-mainline (6.16.0-rc3-1-mainline)
:: Building fallback initramfs for linux-mainline (6.16.0-rc3-1-mainline)
(16/33) Updating linux initcpios...
(17/33) Foreign/AUR package notification
kitemmodels5 5.116.0-1
reiserfsprogs 3.6.27-5
xwaylandvideobridge 0.4.0-2
(18/33) Orphaned package notification...
=> No orphans found.
(19/33) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/hosts.pacnew
/etc/issue.pacnew
/etc/locale.gen.pacnew
/etc/pacman.conf.pacnew
/etc/makepkg.conf.d/rust.conf.pacnew
/etc/updatedb.conf.pacsave
Please check and merge
(20/33) GRUB update after transactions...
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot:  initramfs-linux-zen-fallback.img
Found linux image: /boot/vmlinuz-linux-mainline
Found initrd image: /boot/initramfs-linux-mainline.img
Found fallback initrd image(s) in /boot:  initramfs-linux-mainline-fallback.img
Found linux image: /boot/vmlinuz-linux-hardened
Found initrd image: /boot/initramfs-linux-hardened.img
Found fallback initrd image(s) in /boot:  initramfs-linux-hardened-fallback.img
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2025-06-25 10:48:22 | @/.snapshots/254/snapshot | pre  | /tmp/tmp.OPXzURQtMU -Su                                                  |
Found snapshot: 2025-06-25 10:46:36 | @/.snapshots/253/snapshot | post | pacman        |
Found snapshot: 2025-06-25 10:46:35 | @/.snapshots/252/snapshot | pre  | /tmp/pacman-static -U /tmp/pacman.pkg.tar.zst                            |
Found snapshot: 2025-06-06 14:41:29 | @/.snapshots/251/snapshot | pre  | pacman -Su --overwrite *                                                 |
Found snapshot: 2025-06-05 11:56:13 | @/.snapshots/250/snapshot | post | alsa-card-profiles audit automake gnupg gst-plugin-pipewire lib32-audit  |
Found snapshot: 2025-06-05 11:56:08 | @/.snapshots/249/snapshot | pre  | pacman -Su --overwrite *                                                 |
Found snapshot: 2025-06-04 10:08:16 | @/.snapshots/248/snapshot | post | c-ares minizipqt6-webchannel re2                                        |
Found snapshot: 2025-06-04 10:08:16 | @/.snapshots/247/snapshot | pre  | pacman -Rns c-ares minizip qt6-webchannel re2                            |
Found snapshot: 2025-06-04 10:07:21 | @/.snapshots/246/snapshot | post | qt6-websocketsqt6-webview                                               |
Found snapshot: 2025-06-04 10:07:19 | @/.snapshots/245/snapshot | pre  | pacman -Su --overwrite *                                                 |
Found snapshot: 2025-06-04 10:01:06 | @/.snapshots/244/snapshot | pre  | pacman -Su --overwrite *                                                 |
Found snapshot: 2025-06-04 09:58:24 | @/.snapshots/243/snapshot | pre  | pacman -Su    |
Found snapshot: 2025-06-03 20:43:43 | @/.snapshots/242/snapshot | post | plasma5-themes-sweet-full-git                                            |
Found snapshot: 2025-06-03 20:43:42 | @/.snapshots/241/snapshot | pre  | pacman -Su    |
Found 14 snapshot(s)
Unmount /tmp/grub-btrfs.Xi6RQVge1s .. Success
done
(21/33) Reloading system bus configuration...
(22/33) Checking for old perl modules...
(23/33) Copy FireDragon Distribution Settings
(24/33) Updating fontconfig cache...
(25/33) Updating 32-bit fontconfig cache...
(26/33) Compiling GSettings XML schema files...
(27/33) Updating icon theme caches...
(28/33) Updating GTK4 module cache...
(29/33) Updating the info directory file...
(30/33) Updating the desktop file MIME type cache...
(31/33) Updating the vlc plugin cache...
(32/33) Performing snapper post snapshots for the following configurations...
==> root: 255
(33/33) Syncing all file systems...
Kernel: 6.14.11-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
Speed (MHz): avg: 2843 min/max: 400/5177 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2843 2: 2843 3: 2843
4: 2843 5: 2843 6: 2843 7: 2843 8: 2843 9: 2843 10: 2843 11: 2843 12: 2843
13: 2843 14: 2843 15: 2843 16: 2843 bogomips: 134156
ports: active: DP-1 off: DP-3 empty: DP-2,HDMI-A-1,Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:747e class-ID: 0300
chip-ID: 1002:15bf class-ID: 0300 temp: 42.0 C
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: Samsung S34CG50 serial: <filter> built: 2024 res:
mode: 3440x1440 hz: 100 scale: 114% (1.15) to: 2991x1252 dpi: 109 gamma: 1.2
size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: max: 3440x1440
min: 720x400
Monitor-2: DP-3 model: Samsung S34CG50 serial: <filter> built: 2024
res: 3440x1440 dpi: 109 gamma: 1.2 size: 798x334mm (31.42x13.15")
diag: 869mm (34.2") modes: max: 3440x1440 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.1
navi32 LLVM 20.1.6 DRM 3.61 6.14.11-hardened1-1-hardened)
Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 25.1.4-arch1.1
Radeon Graphics (RADV PHOENIX) driver: mesa radv v: 25.1.4-arch1.1
API: ALSA v: k6.14.11-hardened1-1-hardened status: kernel-api tools: N/A
Local Storage: total: 1.82 TiB used: 36.31 GiB (1.9%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 40.9 C
used: 36.28 GiB (50.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
System Temperatures: cpu: 56.9 C mobo: 36.0 C
GPU: device: amdgpu temp: 40.0 C watts: 31.06 device: amdgpu temp: 49.0 C
mem: 48.0 C fan: 8 watts: 41.00
Memory: total: 64 GiB note: est. available: 60.48 GiB used: 5.78 GiB (9.5%)
Processes: 435 Power: uptime: 0m states: freeze,mem suspend: deep
Packages: pm: pacman pkgs: 1476 libs: 459 tools: octopi,paru Compilers:
inxi: 3.3.38
Last full system update: 2025-06-25
I mean, it’s not perfect, but seems like your system updated just fine. There are some abnormalities where I’d say ā€œis your disk okayā€, but honestly, I have no idea how this system got this bad in the first place, so I’d say it’s just another delayed symptom of that haha. Whatever the case may be, you’re all up to date now! Enjoy!
Started with strange disk issues; was able to delete kwallet on one system that fixed the issues that seemed to be originating from that; or hitting escape instead of setting it up or deleting it.
There should be a way to disable kwallet or delete it if not needed because it causes problems for Second Life / Firestorm Viewer etc or behaves in ways that it should not generally which ends up in system instability even if it not being used.
It recently reinstalled itself on a system that was working with bitlocker & linux encryption.
Browser security was initially compromised with hundreds of tabs it was difficult to figure out where it was coming from.
Kwallet was accessed without being used through FireDragon, Librewolf, Brave; then Dolphin became unstable and crashed after a kwallet update then cycle crashed even after restart; some sort of memory leak corruption that can come in through a browser and use kwallet to cause havoc or spy etc.
