Hello Garuda Forum.
I maybe have a big Problem, or it is just my personal perception.
But first my grauda-inxi:
Kernel: 6.1.21-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=188e7b32-8e99-4142-a534-c5aa2ee178e8 rw [email protected]
quiet quiet nvidia-drm.modeset=1 rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: ASRock model: A520M-ITX/ac serial: <filter>
UEFI: American Megatrends LLC. v: P1.80 date: 08/09/2021
Info: model: AMD Ryzen 7 3700X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3600 min/max: 2200/4426 boost: enabled
base/boost: 3600/4400 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3600 2: 3600 3: 3600 4: 3600
5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600 12: 3600
13: 3600 14: 3600 15: 3600 16: 3600 bogomips: 115026
Device-1: NVIDIA AD103 [GeForce RTX 4080] driver: nvidia v: 530.41.03
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022-23+ pcie: gen: 3 speed: 8 GT/s
off: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 06:00.0 chip-ID: 10de:2704
Device-2: Logitech BRIO Ultra HD Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1.3.1.2:11 chip-ID: 046d:085e
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 23.1.0
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 4920x2160 s-dpi: 120 s-size: 1041x457mm (40.98x17.99")
s-diag: 1137mm (44.76")
Monitor-1: DP-3 mapped: DP-4 note: disabled pos: primary,top-right
model: Dell G3223Q serial: <filter> built: 2022 res: 3840x2160 dpi: 137
gamma: 1.2 size: 710x400mm (27.95x15.75") diag: 813mm (32") ratio: 16:9
modes: max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: bottom-l
model: Dell P2219H serial: <filter> built: 2019 res: 1080x1920 hz: 60
dpi: 103 gamma: 1.2 size: 267x476mm (10.51x18.74") diag: 546mm (21.5")
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
4080/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: bus-ID: 3-1.2:5
gen: 3 chip-ID: 1038:1216 speed: 8 GT/s class-ID: 0300 lanes: 16
serial: <filter> link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1
chip-ID: 10de:22bb class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS SC2 USB Headset type: USB
Device-4: Logitech BRIO Ultra HD Webcam type: USB
Sound API: ALSA v: k6.1.21-1-lts running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
bus-ID: 05:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp5s0 state: dormant mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
bus-ID: 4-1.4:5 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp8s0f3u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-9.3:7 chip-ID: 05ac:828d class-ID: fe01
Local Storage: total: 968.8 GiB used: 368.5 GiB (38.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Transcend model: TS1TMTE220S
lanes: 4 type: SSD serial: <filter> rev: 42A0S63A temp: 32.9 C scheme: GPT
SMART: yes health: PASSED on: 284d 17h cycles: 4,424
read-units: 49,589,408 [25.3 TB] written-units: 56,643,765 [29.0 TB]
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Patriot model: N/A
size: 7.46 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Lexar
model: USB Flash Drive size: 7.47 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 470.09 GiB size: 470.09 GiB (100.00%)
used: 368.49 GiB (78.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7
used: 14.6 MiB (2.9%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-3: /home raw-size: 470.09 GiB size: 470.09 GiB (100.00%)
maj-min: 259:7
ID-4: /var/log raw-size: 470.09 GiB size: 470.09 GiB (100.00%)
maj-min: 259:7
ID-5: /var/tmp raw-size: 470.09 GiB size: 470.09 GiB (100.00%)
maj-min: 259:7
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 31.28 GiB used: 1.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 48.4 C mobo: N/A gpu: nvidia temp: 38 C
Processes: 382 Uptime: 13m wakeups: 0 Memory: 31.28 GiB
used: 5.58 GiB (17.8%) Init: systemd v: 253 default: graphical
pkgs: 1753 libs: 537 tools: octopi,paru Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
System install date: 2023-03-24
Last full system update: 2023-03-27
I obviously searched here for help but i can not find a solution to my specific problem. Searched the wiki but nothing there also.
Maybe i'm just not experienced to Arch since im coming from Fedora in combination with Radeon cards. But:
I searched the Nvidia Page for the best and appropriate driver for my RTX 4080 FE since i have some Problems here and there using either Wayland with Gnome or KDE after standby (Just cursor and black screen). Xorg works fine. But Xorg is no option, need Wayland because of non global fractional scaling. Using one 4K and one 1080p Monitor. Scaling to 100% is not good on the 4K and 125% is too big on the 1080p.
Got there because i was curious and just wanted to install the driver directly provided by Nvidia. And here the problem begins.
As you can see now and automatically the driver version installed is 530.41.03 whereas my card is explicitly not mentioned on the Nvidia compatibility chart.
Nvidia says i should use either the NVIDIA-Linux-x86_64-525.89.02.run or NVIDIA-Linux-x86_64-530.30.02.run driver. As those are the only drivers directly mention my card.
But anyways, if i install one of those drivers i'm only greeted with the old but gold "loading initial ramdisk" and i only can revert what i had done. Use Snapper and go back or reinstall 530.41.03 with pacman -S nvidia-dkms.
After this everything is working.
There is only one thing that bothers me and i can think of be the problem and that is the screen-"photo" i would like to attach here (but as a new user i can not). It tells me during installation that the driver is already part of the Kernel i chose: "exactly matches what is already found in kernel 6.1.21-1-lts" multiple times. And of course it is already the LTS Kernel because i read somewhere that the zen Kernel can be problematic with Nvidia drivers.
So yes, even with the "wrong" drivers my card is working okayisch, but it bothers me that there is a better driver and i simply can not use it...
Would be great if someone can point out what i'm missing here.
