Hi all
I have installed garuda linux multimedia couple days ago. I am trying to connect to my wifi but after entering the correct password , it asks me password again and again and can not connect to it.
Welcome, @elns ![]()
We encourage forum searches here, I found this (solved) one with the same symptoms - have a read through and see if it helps ![]()
Yes, I have read it and it solved using refreshing the mirror list but i not works in my case.
The particular part I referred was Post 3 from @Naman (Mirror refresh wasn’t the solution, btw)
Have you rebooted your machine?
Refreshing the mirror list is mentioned nowhere in the linked thread. Perhaps you might want to read it again?
