I tried to install Converseen, but it wouldn’t run - I got the error:
qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vkkhrdisplay, vnc, xcb.
…after some digging around I found ubuntu - qt.qpa.plugin: Could not find the Qt platform plugin "wayland" - Stack Overflow and after going through the answers it seemed I was lacking qt6-wayland.
I checked Pamac and it wasn’t installed, so I installed it using…
sudo pacman -S qt6-wayland
I then gave Converseen another try and it worked ![]()
Can qt6-wayland be installed by default to save head scratching?
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: hpet
available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=3bc52a57-04f8-4ebb-a556-7ffb21fb3f9e rw rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: GNOME v: 45.3 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM v: 45.0.1
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513UA_M513UA v: 1.0
Mobo: ASUSTeK model: X513UA v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC.
v: X513UA.312 date: 04/26/2022
ID-1: BAT0 charge: 15.4 Wh (39.8%) condition: 38.7/42.1 Wh (92.0%) power: 9.9 W volts: 11.8
min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: discharging cycles: 673
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 981 high: 1397 min/max: 400/4056 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 1397 2: 1397 3: 400 4: 1397 5: 1397 6: 400 7: 400 8: 400 9: 1397
10: 1397 11: 400 12: 1397 bogomips: 50305
Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 37.0 C
Device-2: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 0408:30d4 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3 compositor: gnome-shell
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Samsung 0x4161 built: 2020 res: 1920x1080 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: Vulkan v: 1.3.274 layers: 3 device: 0 type: integrated-gpu name: AMD Radeon Graphics
(RADV RENOIR) driver: mesa radv v: 23.3.3-arch1.1 device-ID: 1002:164c
surfaces: xcb,xlib,wayland device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits)
driver: mesa llvmpipe v: 23.3.3-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.6.10-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
IF-ID-1: enp3s0f3u3 state: up speed: 150 Mbps duplex: half mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-2:2 chip-ID: 8087:0032 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12 status: discoverable: no
pairing: no
Local Storage: total: 476.94 GiB used: 16.65 GiB (3.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HALU-00000 size: 476.94 GiB
fw-rev: FXV7101Q temp: 32.9 C scheme: GPT
ID-1: / raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 6.22 GiB (4.2%) fs: btrfs
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 584 KiB (0.1%) fs: vfat
ID-3: /home raw-size: 321.45 GiB size: 321.45 GiB (100.00%) used: 10.43 GiB (3.2%) fs: btrfs
ID-4: /var/log raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 6.22 GiB (4.2%) fs: btrfs
ID-5: /var/tmp raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 6.22 GiB (4.2%) fs: btrfs
ID-1: swap-1 type: zram size: 7.15 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
maj-min: 259:3
System Temperatures: cpu: 38.9 C mobo: N/A gpu: amdgpu temp: 37.0 C
Fan Speeds (rpm): cpu: 0
Processes: 374 Uptime: 28m wakeups: 0 Memory: total: 8 GiB note: est. available: 7.15 GiB
used: 3.27 GiB (45.8%) Init: systemd v: 255 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: pm: pacman pkgs: 1198 libs: 401 tools: pamac,paru Client: shell wrapper
v: 5.2.21-release inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2024-01-14
Last full system update: 2024-01-14 ↻
