I try to install Garuda Linux Hyprland but i cant. i can start Garuda hyprland on a live usb boot (only in the proprietary, whenever i try on opensource it wont open) it boots up the system but when i press on “install garuda linux” it will not start, i even tried typing “sudo calamares” in the terminal but it still wont work even if i use “xhost + local” all it says is;
Authorization required, but no authorization protocol specified
qt.qpa.xcb: could not connect to display :1
qt.qpa.plugin: Could not load the Qt platform plugin “xcb” in “” even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Aborted
i’ve tried reflashing and everything but nothing will work. i use terminal, used app, used the welcome screen to install and boot calamares and nothing.
i am using the proprietary drivers to launch on live usb
i have RTX 3060 mobile, intel ccore i9 11th gen.
Please i really want to install Garuda with Hyprland
