Hello people, I hope you are well
I have this problem when trying to install Garuda Dragonized with the ISOs of the last 3 days.
When booting and trying to start Calamares, it starts but instantly shuts itself down. This is the output of sudo -E calamares -d:
calamares: error while loading shared libraries: libyaml-cpp.so.0.7: cannot open shared object file: No such file or directory
This is the output of garuda-inxi:
Kernel: 6.6.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
misobasedir=garuda root=miso:LABEL=GARUDA_DR460NIZED_SPIZAETUS quiet
systemd.show_status=1 ibt=off driver=free nouveau.modeset=1
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/10/2021
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2374 high: 3600 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3600 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2196 11: 2200
12: 2200 13: 2200 14: 2200 15: 3600 16: 2200 bogomips: 114985
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI
driver: nouveau v: kernel non-free: 545.xx+ status: current (as of 2023-10;
EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s ports: active: DP-1 empty: HDMI-A-1 bus-ID: 07:00.0
chip-ID: 10de:1d01 class-ID: 0300 temp: 43.0 C
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_x11 driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: :0
Monitor-1: DP-1 model: HP E243 serial: <filter> built: 2019 res: 1920x1080
hz: 60 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 23.3.2-arch1.2 glx-v: 1.4
direct-render: yes renderer: NV138 device-ID: 10de:1d01 memory: 1.93 GiB
unified: no
API: Vulkan v: 1.3.274 layers: 3 device: 0 type: cpu name: llvmpipe (LLVM
16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM 16.0.6)
Device-1: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 07:00.1 chip-ID: 10de:0fb8
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.6.9-zen1-1-zen status: kernel-api tools: N/A
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0029
Supported mdraid levels: raid1
Device-1: md127 maj-min: 9:127 type: mdraid level: mirror status: active
Info: report: 2/2 UU blocks: 1953381376 chunk-size: N/A super-blocks: 1.2
Components: Online:
0: sda1 maj-min: 8:1 size: 1.82 TiB
1: sdb1 maj-min: 8:17 size: 1.82 TiB
Local Storage: total: raw: 4.56 TiB usable: 2.74 TiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup
model: T-FORCE TM8FP7001T size: 931.51 GiB block-size: physical: 512 B
fw-rev: EGFM13.0 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM005-2CW102
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM005-2CW102
ID-4: /dev/sdc maj-min: 8:32 model: SCSI size: 7.52 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00 scheme: MBR
System Temperatures: cpu: 54.5 C mobo: N/A gpu: nouveau temp: 43.0 C
Processes: 377 Uptime: 10m wakeups: 0 Memory: total: 32 GiB
available: 31.25 GiB used: 2.9 GiB (9.3%) Init: systemd v: 255
pm: pacman pkgs: 1235 libs: 355 tools: octopi,paru Shell: fish v: 3.7.0
Garuda (2.6.22-1):
System install date: 2024-01-05
Last full system update: 2024-01-05 ↻
Failed units: mdmonitor.service snapper-cleanup.service
