Hey Everyone, (anyone?)
I hope I formatted this correctly, please forgive me if I did not. I have been trying to resolve this, and other issues for the past 30+ hours, and I am out of sorts. (other issues I was able to resolve from my autodidaction.)
I have installed this distro and desktop before without any issue, and yet now I have less than nothing . My brain is fried, so I know this post sounds really subpar.
*Does anyone know how I can fix the initialization failure of Calamares and what users@users module even means. I am disorientation I am frustrated.
misobasedir=garuda misolabel=GARUDA_DR460NIZED_TALON quiet
systemd.show_status=1 ibt=off driver=nonfree nouveau.modeset=0
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 info: latte-dock
Type: Laptop System: Alienware product: Alienware m15 Ryzen Ed. R5 v: 1.6.1
serial: <superuser required> Chassis: type: 10 v: 1.6.1
Mobo: Alienware model: 06W7NY v: A02 serial: <superuser required>
UEFI: Alienware v: 1.6.1 date: 05/31/2022
ID-1: BAT1 charge: 18.8 Wh (24.4%) condition: 77.2/86.0 Wh (89.8%)
volts: 11.9 min: 11.4 model: BYD 0x48,0x32,0x32,0x33,0x69,0x03,0x0000
type: Li-ion serial: <filter> status: charging
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22 process: TSMC n7
(7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1482 high: 3300 min/max: 1200/4679 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3300 2: 1200
3: 1198 4: 1200 5: 1200 6: 1397 7: 3300 8: 1200 9: 1200 10: 1317 11: 1200
12: 1200 13: 1200 14: 1200 15: 1200 16: 1200 bogomips: 105404
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24dd
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-4:5 chip-ID: 0c45:672c class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
Screen-1: 0 s-res: 4480x1440 s-dpi: 143 s-size: 796x254mm (31.34x10.00")
s-diag: 836mm (32.9")
Monitor-1: DP-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
Monitor-2: HDMI-0 pos: primary,right res: 2560x1440 dpi: 93
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3070 Laptop GPU/PCIe/SSE2 v: 4.6.0
NVIDIA 520.56.06 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 1-2.2:4 chip-ID: 1188:a301 pcie:
gen: 3 class-ID: 0102 serial: <filter> speed: 8 GT/s lanes: 8 link-max:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_sof_amd_renoir
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Bloomberg L.P. Keyboard Audio type: USB
Device-1: Realtek RTL8125 2.5GbE vendor: Dell driver: r8169 v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8125
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
bus-ID: 1-3:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 982.78 GiB used: 3.8 MiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC711 NVMe 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41001131
temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: PNY model: USB 2.0 FD
size: 28.91 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: swap-1 type: zram size: 15.47 GiB used: 1016.2 MiB (6.4%)
System Temperatures: cpu: 47.6 C mobo: N/A gpu: nvidia temp: 30 C
Processes: 354 Uptime: 1h 8m wakeups: 15 Memory: 15.47 GiB used: 7.25 GiB
(46.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1193 libs: 295
Garuda (2.6.9-1):
System install date: 2022-10-28
Last full system update: 2022-10-28 ↻
Failed units: snapper-boot.service snapper-cleanup.service
╭─garuda@garuda in ~ as 🧙 took 2s
forever grateful for any insight and patient direction.
