Cairo-Dock Doesn't Work
I’ve successfully installed cairo dock and plugins but it wont open
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=372d7ab7-37c2-4e59-885d-d24aaadfa1db rw rootflags=subvol=@
quiet resume=UUID=d064b337-0007-46a7-a941-6812cdb8c4a2 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: Acer product: Aspire A315-56 v: V1.27
Mobo: IL model: Sleepy_IL v: V1.27 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.27
date: 07/07/2022
ID-1: BAT1 charge: 22.9 Wh (100.0%) condition: 22.9/36.7 Wh (62.3%)
volts: 12.2 min: 11.3 model: LGC AC14B18 type: Li-ion serial: N/A
status: full
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xC4
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 400 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
Device-2: Quanta VGA WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:2 chip-ID: 0408:a031
Monitor-1: eDP-1 res: 1301x731 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
device-ID: 8086:8a56 memory: 3.53 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: Intel
UHD Graphics (ICL GT1) driver: mesa intel v: 24.0.3-arch1.2
device-ID: 8086:8a56 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
vendor: Acer Incorporated ALI RTL8111/8168/8411 driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3
chip-ID: 04ca:3015 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 238.47 GiB used: 59.87 GiB (25.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: SSD 256GB size: 238.47 GiB
tech: SSD serial: <filter> fw-rev: V1013A0 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 78.12 GiB size: 78.12 GiB (100.00%)
used: 18.21 GiB (23.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 78.12 GiB size: 78.12 GiB (100.00%)
ID-4: /var/log raw-size: 78.12 GiB size: 78.12 GiB (100.00%)
ID-5: /var/tmp raw-size: 78.12 GiB size: 78.12 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.62 GiB used: 563.2 MiB (15.2%)
ID-2: swap-2 type: partition size: 7.96 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 71.0 C mobo: N/A
Memory: total: 4 GiB available: 3.62 GiB used: 2.3 GiB (63.5%)
Processes: 218 Power: uptime: 22m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.43 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1997 libs: 580 tools: octopi,pamac,paru,yay
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-03-22
Last full system update: 2024-03-24
╭─tenuka22@tenuka in ~ took 1s
╰─λ
Run it from command line and post the output.
Quite old stuff, with Plasma 6 it may well not work as intended!
https://aur.archlinux.org/packages/cairo-dock-git
Forums are closed for a very long time.
https://glx-dock.org/bg_forumlist.php
EDIT: But hey, there’s some movement on github 2 weeks ago. Cairo-Dock / Glx-Dock · GitHub
If you have issues with Cairo-Dock, you should open one at their github.
I have never used Cairo-dock on wayland :eyes:
Anyway,
Start it from the terminal and maybe copy paste the error here…
Sometimes it maybe as simple as toggling opengl in there settings
╰─λ cairo-dock &
╭─tenuka22@tenuka in ~ took 1ms
✦  ╰─λ
fish: Job 1, 'cairo-dock &' terminated by signal SIGSEGV (Address boundary error)
╰─λ cairo-dock
fish: Job 1, 'cairo-dock' terminated by signal SIGSEGV (Address boundary error)
╭─tenuka22@tenuka in ~ took 371ms
This is the terminal result
I am not sure, best bet is you could be missing some GTK libs :woozy_face::
Considering it ran on mine (poorly) and the only gtk thing I could find is
kde-gtk-config,
Maybe you could try installing that…
No promises though, but you could try figure out what GTK thing you missin,
also maybe try to run with sudo too and see if its a permission error…
Other wise you could dive into SIGSEV, and try debugging it yourself…
Probably you could also try downgrading cairo-dock
This may or may not work for you but i had that same error in spectacle for me i had to install libva-nvidia-driver. Since your on intel you might need to remove libva-vdpau-driver or add it since this was something to do with how arch packaged kde6. If you want a link to the bug post i can edit it in. It’s a shot in the dark kinda thing though. Just note most all docs other then the upcoming elementary OS one dont work in wayland.
