Buying new components and a small doubt
As soon as you receive an error, you can abort.
Remember to test all 4 banks with a fault-free RAM stick to rule out the possibility that the motherboard is broken.
So… the tests can be made with pairs without any problems.
When I mount all 4 banks, memtest86+ crashes and the PC restarts.
Same thing with stressapptest from CLI, after a couple of seconds the PC restarts.
Memtest says that, if the rams were tested individually, most of these problems are due to the BIOS and many BIOSes have these problems with 4 banks of DDR5, even disabling any overclock and enabling Memory Context Restore.
It’s really becoming Don Quixote’s battle against windmills :rofl:
I just tried an ffmpeg encoding from mp4 to avi and the PC restarted…
That’s completely absurd.
If the 4 RAM sticks are identical, then they should work without any problems.
Have you tried “MEMORY TRY IT” in the BIOS?
Does the mobo have a dual BIOS so that you can test a different BIOS version?
If the RAM sticks are OK, then it’s probably the BIOS or motherboard.
Do you have a friend with a suitable mobo that you can test the RAM sticks on (or vice versa, other RAM sticks in your mobo)?
no unfortunately I don’t have anyone to change the motherboard with. Now I reset the BIOS and ffmpeg works without problems, I’ll try memtest86+ again. I had seen MEMORY TRY IT but not knowing what it’s for I preferred not to touch it :rofl:
The RAM is seen at 4800.
# dmidecode 3.6
Getting SMBIOS data from sysfs.
SMBIOS 3.7.0 present.
Handle 0x0013, DMI type 17, 100 bytes
Memory Device
Array Handle: 0x0010
Error Information Handle: 0x0012
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMMA1
Bank Locator: P0 CHANNEL A
Type: DDR5
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 4800 MT/s
Manufacturer: Unknown
Serial Number: 00000000
Asset Tag: Not Specified
Part Number: CMK32GX5M2B6000Z30
Rank: 1
Configured Memory Speed: 3600 MT/s
Minimum Voltage: 1.1V
Maximum Voltage: 1.1 V
Configured Voltage: 1.1V
Memory Technology: DRAM
Memory Operating Mode Capability: Volatile memory
Firmware Version: Unknown
Module Manufacturer ID: Bank 3, Hex 0x9E
Module Product ID: Unknown
Memory Subsystem Controller Manufacturer ID: Unknown
Memory Subsystem Controller Product ID: Unknown
Non-Volatile Size: None
Volatile Size: 16 GB
Cache Size: None
Logical Size: None
PMIC0 Manufacturer ID: Bank 12, Hex 0x10
PMIC0 Device Type: Not Installed
RCD Manufacturer ID: Unknown
RCD Revision Number: Unknown
Handle 0x0016, DMI type 17, 100 bytes
Memory Device
Error Information Handle: 0x0015
Date Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMMA2
Type: DDR5
Speed: 4800 MT/s
Rank: 1
Maximum Voltage: 1.1V
Cache Size: None
Logical Size: None
PMIC0 Manufacturer ID: Bank 12, Hex 0x2A
Handle 0x0019, DMI type 17, 100 bytes
Memory Device
Error Information Handle: 0x0018
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMMB1
Bank Locator: P0 CHANNEL B
Type: DDR5
Speed: 4800 MT/s
Rank: 1
Cache Size: None
Logical Size: None
Handle 0x001C, DMI type 17, 100 bytes
Memory Device
Error Information Handle: 0x001B
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMMB2
Type: DDR5
Speed: 4800 MT/s
Rank: 1
Cache Size: None
Logical Size: None
I completely missed this option…head → table :grin:
I think I need a :coffee:
At 4800 they are working fine but I am tempted to return the 32GB. I would rather have 32GB at 6000 than 64GB at 4800.
Yeah…but even better is 16GB at 8000 or even even better 8GB at 12000. And the ultimate challenge is 4GB at 20000 with LN2 :rofl:
and cooled in nitrogen :joy:
@SGS hasn’t kicked me out of the forum yet as the discussion is turning into a massacre… sorry but that wasn’t my intention :pensive:
In all this I would like to point out that I haven’t reinstalled any operating system yet. I decided to return 32GB of RAM and continue testing with “only” 32GB.
So, after various benches and “normal” use (gaming, browsing, ffmpeg conversion, memtest86+, etc) I didn’t notice any major problems, either Linux or Windows side. So I’d say the hardware upgrade without reinstallation went well.
If anyone has any questions or tests about this, just ask!
(I hope this thread serves as a bit of a reference)
Only one, 20 days :wink:
ok, with broken hardware
…grats… :+1:
I also have a job and a family… :rofl:
Basically I think I should close the thread. Even if I digressed, I hope it can be of help to someone who has doubts.
Thanks to the staff for their patience :rofl:
