Bunch of python related stuff went haywire
Hey guys I’m gonna need some assistance with this one
( 8/17) Checking for package with missing dependencies...
File "/usr/lib/libkhotkeysprivate.so.5.27.9" from package "khotkeys" is missing dependency "libkworkspace5.so.5"
File "/usr/lib/qt/plugins/kcm_hotkeys.so" from package "khotkeys" is missing dependency "libkworkspace5.so.5"
File "/usr/lib/qt/plugins/kf5/kded/khotkeys.so" from package "khotkeys" is missing dependency "libkworkspace5.so.5"
File "/usr/lib/python3.11/site-packages/PySide2/QtDataVisualization.cpython-311-x86_64-linux-gnu.so" from package "pyside2" is missing dependency "libQt5DataVisualization.so.5"
File "/usr/lib/libqgpgme.so.15.5.1" from package "qgpgme-qt5" is missing dependency "libgpgmepp.so.6"
File "/usr/lib/libqgpgme.so.15.5.1" from package "qgpgme-qt5" is missing dependency "libgpgme.so.11"
File "/usr/lib/libqgpgme.so.15.5.1" from package "qgpgme-qt5" is missing dependency "libassuan.so.0"
Package "guiscrcpy" has files in directory "/usr/lib/python3.11" that are ignored by the current Python interpreter
Package "pyside2" has files in directory "/usr/lib/python3.11" that are ignored by the current Python interpreter
Package "python-shiboken2" has files in directory "/usr/lib/python3.11" that are ignored by the current Python interpreter
These packages went missing 1 or 2 days ago and I don’t know enough about them to fix it. I’ve tried reinstalling them but then on the next reboot my desktop environment was broken and I had to restore a snapshot.
I’ve been down this rabbithole of missing qt dependencies on a different distro before and I know I can’t handle it :smiley:
Garuda-inxi
Kernel: 6.15.8-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=009286cb-0285-4127-a549-89672838992b rw rootflags=subvol=@
quiet resume=UUID=58b306a5-086f-46bd-affd-6a1e60fb5244 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.4.3 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Desktop System: ASUS product: N/A v: N/A serial:
Mobo: ASUSTeK model: ROG STRIX B650E-E GAMING WIFI v: Rev 1.xx
serial: part-nu: SKU uuid:
UEFI: American Megatrends v: 1654 date: 08/25/2023
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120A
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 5349 min/max: 403/5576 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5349 2: 5349 3: 5349
4: 5349 5: 5349 6: 5349 7: 5349 8: 5349 9: 5349 10: 5349 11: 5349 12: 5349
13: 5349 14: 5349 15: 5349 16: 5349 bogomips: 144000
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
/ 6900 XT] vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1
empty: DP-1,DP-2,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73bf
gpu: amdgpu d-rect: 4480x1440 display-ID: 0
Monitor-1: DP-3 pos: primary,left model: Acer VG270U P serial:
built: 2021 res: mode: 2560x1440 hz: 120 scale: 100% (1) dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 pos: right model: ViewSonic VA2407 Series
serial: built: 2019 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 (radeonsi navi21
LLVM 20.1.8 DRM 3.63 6.15.8-zen1-2-zen) device-ID: 1002:73bf
API: Vulkan v: 1.4.321 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 (RADV NAVI21) driver: mesa radv v: 25.1.7-arch1.1
device-ID: 1002:73bf surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.7-arch1.1 (LLVM
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
API: ALSA v: k6.15.8-zen1-2-zen status: kernel-api with: aoss
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 08:00.0 chip-ID: 8086:15f3
IF: eno1 state: down mac:
lanes: 1 bus-ID: 09:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp9s0 state: up mac:
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:6
chip-ID: 0489:e0e2 class-ID: e001 serial:
Local Storage: total: 6.84 TiB used: 1.95 TiB (28.5%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: fw-rev: 5B2QGXA7 temp: 32.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Addlink
model: M.2 PCIE G3x4 NVMe RGB size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial:
fw-rev: ECFM12.3 temp: 30.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
tech: SSD serial: fw-rev: 2B6Q scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000DM001-1CH166
tech: HDD rpm: 7200 serial: fw-rev: CC27 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 2TB
tech: SSD serial: fw-rev: 3B6Q scheme: GPT
ID-1: / raw-size: 897.02 GiB size: 897.02 GiB (100.00%)
used: 810.33 GiB (90.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
used: 616 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 897.02 GiB size: 897.02 GiB (100.00%)
ID-4: /var/log raw-size: 897.02 GiB size: 897.02 GiB (100.00%)
ID-5: /var/tmp raw-size: 897.02 GiB size: 897.02 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.07 GiB used: 33.9 MiB (0.1%)
ID-2: swap-2 type: partition size: 34.19 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:8
System Temperatures: cpu: 48.5 C mobo: 34.0 C gpu: amdgpu temp: 40.0 C
mem: 44.0 C
Memory: total: 32 GiB note: est. available: 31.07 GiB used: 4.13 GiB (13.3%)
Processes: 446 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2208 libs: 597 tools: octopi,pamac,paru
Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: garuda-inxi default: fish
Garuda (2.7.3-2):
System install date: 2024-03-21
Last full system update: 2025-08-02
As far as I can see, khotkeysis no more in the AUR and no more maintained at all and should be definitely removed.
For the rest, remember to update also AUR packages with:
garuda-update -a
Package qgpgme-qt5 needs to be updated from the AUR.
Package khotkeys should be uninstalled.
Package pyside2 needs to be updated from the AUR.
Package guiscrcpy is unmaintained since 2023, should be uninstalled.
Package python-shiboken2 should be updated from the AUR.
In short:
sudo pacman -R khotkeys guiscrcpy
garuda-update -a
Oh.. I was not aware AUR was not included in
update
script. Ooops. Thank you for the rundown. This is taking a while
Everything is working now. Thank you! Lesson learned.
you can add UPDATE_AUR=1 to your garuda update config. As shown here Garuda Update | Garuda Linux wiki I do recommend it personally. This will also apply when you run update/upd.
Yup thank you I figured this was the go-to method. I’m going to do it eventually but first I’m on manual AUR updates for a while to get a feeling for all the dependencies I have there. A lot of them came through the install wizard back when I knew way less about Linux.
