System: Kernel: 5.15.2-xanmod1-rog-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: pm_debug_messages amd_pmc.enable_stb=1 amd_pmc.dyndbg="+p" acpi.dyndbg="file
drivers/acpi/x86/s2idle.c +p"
BOOT_IMAGE=/@/.snapshots/154/snapshot/boot/vmlinuz-linux-xanmod-rog
root=UUID=ba2fb729-b4b9-49f0-8223-47f0378d19c9 quiet splash rd.udev.log_priority=3
rootflags=defaults,noatime,space_cache,autodefrag,compress=zstd,subvol=@/.snapshots/154/snapshot
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: ROG Strix G513QM_G513QM v: 1.0
Mobo: ASUSTeK model: G513QM v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC.
v: G513QM.314 date: 09/03/2021
Battery: ID-1: BAT0 charge: 44.1 Wh (53.0%) condition: 83.2/90.0 Wh (92.4%) volts: 14.9 min: 15.9
model: AS3GWAF3KC GA50358 type: Li-ion serial: <filter> status: Discharging
CPU: Info: 8-Core model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 50 (80) stepping: 0 microcode: A50000B cache: L1: 512 KiB L2: 4 MiB
L3: 16 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 105403
Speed: 3243 MHz min/max: 400/4890 MHz boost: enabled Core speeds (MHz): 1: 3243 2: 3244 3: 3244
4: 3241 5: 3244 6: 3244 7: 3244 8: 3245 9: 3244 10: 3244 11: 3243 12: 3243 13: 3244 14: 3243
15: 3243 16: 3240
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Graphics: Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK driver: N/A
alternate: nvidiafb, nouveau bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 06:00.0
chip-ID: 1002:1638 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting
failed: nvidia display-ID: :0 screens: 1
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.2-xanmod1-rog-1 LLVM 13.0.0) v: 4.6 Mesa 21.2.5
direct render: Yes
Audio: Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 06:00.1
Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-4: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-xanmod1-rog-1 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK vendor: AzureWave driver: mt7921e v: kernel port: N/A bus-ID: 03:00.0
chip-ID: 14c3:7961 class-ID: 0280
Bluetooth: Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8 bus-ID: 3-4:2
chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Drives: Local Storage: total: 1.4 TiB used: 97.05 GiB (6.8%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: SK Hynix model: HFM001TD3JX013N size: 953.87 GiB
rev: 41000C20 temp: 41.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW512G8 size: 476.94 GiB
rev: 004C temp: 42.9 C scheme: GPT
Partition: ID-1: / raw-size: 476.94 GiB size: 476.94 GiB (100.00%) used: 97.02 GiB (20.3%) fs: btrfs
dev: /dev/nvme1n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.5 MiB (26.6%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 476.94 GiB size: 476.94 GiB (100.00%) used: 97.02 GiB (20.3%) fs: btrfs
ID-4: /var/log raw-size: 476.94 GiB size: 476.94 GiB (100.00%) used: 97.02 GiB (20.3%)
fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:1
ID-5: /var/tmp raw-size: 476.94 GiB size: 476.94 GiB (100.00%) used: 97.02 GiB (20.3%)
Swap: Kernel: swappiness: 133 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: zram size: 15.13 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 60.0 C mobo: N/A gpu: amdgpu temp: 58.0 C
Fan Speeds (RPM): cpu: 2200
Info: Processes: 354 Uptime: 17m wakeups: 4 Memory: 15.13 GiB used: 4.7 GiB (31.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1799 lib: 546
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
I was in a Zoom meeting and attempted to swap my audio device from the built-in to my headset. After doing so the built-in microphone no longer shows as an available option.
I've:
- Rebooted
- Loaded snapshot before I installed Zoom
- Booted into Windows to make sure nothing broke on the Mic
- Booted into a different kernel
