Vapoursynth and Avisynth are video frame server that allows running scripts to edit videos. I was having this discussion on the Vapoursynth forum; and bringing distro builders into the discussion could be useful.
Vapoursynth and Avisynth have a whole list of plugins that they can use, which are listed at vsdb.top. On Windows, you can use vsrepo
to automatically download and install a plugin and its dependencies.
On Linux, we got the AUR. Most of the plugins are there. There are a few downsides. First, it can make the system unstable. Second, it only works on Arch-based distros. Third, compiling BM3DCUDA requires a 3GB dependency that remains there after. AUR should always be a last-resort solution.
Ideally, vsrepo should be made cross-platform, for both Vapoursynth and Avisynth.
Most projects are on GitHub. The question is: how to obtain binaries for all Linux distros + MacOS? They'd need a custom build server, and a generic solution to build new projects in a few clicks. GitHub Actions have the ability to build Linux binaries, but I don't know whether it can build from other repositories, and whether it can be implemented in a generic way.
Ideas?
