Btrfs vs ext4 for storing movies
i can't decide which format i should use for my external hard disk, "ext4" or "btrfs"
my external hard disk drive is of 1.5 GB.
I will create 3 partitions in it. I will give 500G to first partition and will use it for storing anime movies, anime series, anime musics, anime fan arts, Light Novels and AMVs. In second partion i will give it 10GB and store anime op's & ed's. In 3rd partition i will give it 10GB and store back ups file and some stuffs.
So, i wanna ask which file system is best suited for me.
  Kernel: 6.3.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=e6346f34-2492-4e39-aa4e-477b3bafe457 rw rootflags=subvol=@
    quiet rd.luks.uuid=82ca175a-cf5b-4ea1-b71c-ad9ad55eee67 quiet splash
    rd.luks.uuid=6940389d-48b4-4d0b-89c5-7adf0f042bbc
    resume=/dev/mapper/luks-6940389d-48b4-4d0b-89c5-7adf0f042bbc loglevel=3
  Desktop: Qtile v: 0.22.1 wm: LG3D vt: 1 dm: SDDM Distro: Garuda Linux
  Type: Desktop Mobo: INTEL model: H61 serial: <superuser required>
    UEFI: American Megatrends v: 4.6.5 date: 03/05/2019
  Info: model: Intel Core i3-2120 bits: 64 type: MT MCP arch: Sandy Bridge
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1674 high: 1692 min/max: 1600/3300 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1653 2: 1690 3: 1692
    4: 1661 bogomips: 26341
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Device-1: NVIDIA GF119 [GeForce GT 610] driver: nvidia v: 390.157
    alternate: nouveau,nvidia_drm non-free: series: 390.xx+ status: legacy-active
    (EOL~late 2022) arch: Fermi code: GF1xx process: 40/28nm built: 2010-16
    pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:104a class-ID: 0300
    compositor: Picom v: git-c4107 driver: X: loaded: nvidia gpu: nvidia
  Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x261mm (19.02x10.28")
    s-diag: 549mm (21.61")
  Monitor-1: HDMI-0 res: 1920x1080 dpi: 102 size: 480x260mm (18.9x10.24")
    diag: 546mm (21.49") modes: N/A
    missing.
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
  Device-2: NVIDIA GF119 HDMI Audio driver: snd_hda_intel v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:0e08 class-ID: 0403
  API: ALSA v: k6.3.1-zen1-1-zen status: kernel-api tools: alsamixer,amixer
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
    driver: btusb v: 0.8 bus-ID: 1-1.2:3 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 1.93 TiB used: 24.25 GiB (1.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: GALAX model: GAMER L TA1D0120A
    size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: SSD serial: <filter> rev: 61.3 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500418AS
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: HP35 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
    model: WD15SMRW-11YNDS1 size: 1.36 TiB block-size: physical: 512 B
    logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1020 scheme: GPT
  ID-1: / raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
    used: 24.25 GiB (23.6%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-82ca175a-cf5b-4ea1-b71c-ad9ad55eee67
    used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
  ID-4: /var/log raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
  ID-5: /var/tmp raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-6940389d-48b4-4d0b-89c5-7adf0f042bbc
  ID-2: swap-2 type: zram size: 7.71 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 53 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
  Processes: 204 Uptime: 2h 24m wakeups: 0 Memory: 7.71 GiB
  used: 1.95 GiB (25.3%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1339
  libs: 383 tools: gnome-software,pamac,paru pm: flatpak pkgs: 0 Shell: fish
  v: 3.6.1 default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.26
  System install date:     2023-05-05
  Last full system update: 2023-05-06
  Is partially upgraded:   Yes
I would format to ext4 in your situation
What are the advantages and disadvantages
ext4 can be read by any device. As you wish to use it as storage.
but i am gonna use it on my destop only it's external drive but i am using it as an internal one
so multidevice support doesn't matter
As your question was for use as an external drive ext4 is the most portable.
As you havn,t provided your
Its hard to fill in the blanks :rofl:
You maybe dual booting?
Well no I am not dual booting, but I feel a bit sour about giving my system information when it's not required. I don't know why, but I feel vulnerable.
Thread is solved.
No secrets in garuda-inxi.
Check the forum, it is full of hardware and software details needed to solve problems. It saves helpers from asking the same questions a thousand times over.
I store all of my data--movies, other videos, music, documents--all of my data, on an internal 7,200 RPM HDD, and none of it on my smaller, faster SSD.
Why? Because I keep my operating system on the faster SSD, because, hey, operating system speed matters! :slight_smile:
Data, not so much. The stuff--movies, whatnot--I keep on the larger, slower HDD, because data reads are fast enough--way faster than is necessary to watch, listen, or read--whatever I'm doing with those files. You could even compress all of he data on the HDD and reads would still be fast enough. :slight_smile:
In my experience, the filesystem--btrfs or ext4--doesn't matter.
regards
The main reason to choose Btrfs as a filesystem (for anything) is to use its many features for some kind of benefit. If you are not planning to take advantage of any Btrfs features for storing your movies, or you are not sure what those features even are, ext4 is most likely a better choice.
