After updating from kernel 6.15.0 to 6.15.7 my root partition, and the separate home btrfs partition can no longer be mounted due to a checksum error. I followed the steps from frayalabs page but that didn’t fix the issue. I tried to cachy-chroot from my other Linux OS on the same drive but can not perform any btrfs fixes due to not being able to mount the partition:
> **`shawd1`**`@`**`ROG-Flow-X16`**` `
> **` OS`**` Garuda Linux x86_64 `
> **`├ Kernel`**` Linux 6.15.9-zen1-1.1-zen `
> **`├ Packages`**` 1892 (pacman)[stable] `
> **`├ Shell`**` fish 4.0.2 `
> **`└ Age`**` 29 days `
> **` DE`**` KDE Plasma 6.4.4 `
> **`├ Window Manager`**` KWin (Wayland) `
> **`├ Login Manager`**` sddm-autologin 0.21.0 (Wayland) `
> **`├ WM Theme`**` CatppuccinMocha-Classic `
> **`├ Color Themes`**` Mokka (CatppuccinMochaMauve) [Qt] `
> **`├ System Icons`**` BeautyLine [Qt] `
> **`├ System Fonts`**` Inter (10pt) [Qt] `
> **`└ Terminal`**` konsole 25.4.3 `
> **` PC`**` Convertible (1.0) `
> **`├ CPU`**` 13th Gen Intel(R) Core(TM) i9-13900H (20) @ 5.40 GHz `
> **`├ GPU`**` NVIDIA GeForce RTX 4070 Max-Q / Mobile [Discrete] `
> **`├ GPU`**` Intel Iris Xe Graphics @ 1.50 GHz [Integrated] `
> **`├ Vulkan`**` 1.4.311 - Intel open-source Mesa driver [Mesa 25.1.7-arch1.1] `
> **`└ Display(s)`**` 2560x1600 @ 240 Hz (as 1462x914) in 16" [Built-in] `
> **`╭─shawd1`**`@`**`ROG`**` in ~ `
> **`╰─λ`**` garuda-inxi `
> **`System:`**` `
> **`Kernel:`**` 6.15.9-zen1-1.1-zen `**`arch:`**` x86_64 `**`bits:`**` 64 `**`compiler:`**` gcc `**`v:`**` 15.1.1 `
> **`clocksource:`**` tsc `**`avail:`**` acpi_pm `
> **`parameters:`**` BOOT_IMAGE=/@/boot/vmlinuz-linux-zen `
> `root=UUID=ffb624f5-fc23-45ad-a432-952737d296c8 rw rootflags=subvol=@ `
> `vt.default_red=30,243,166,249,137,245,148,186,88,243,166,249,137,245,148,166 `
> `vt.default_grn=30,139,227,226,180,194,226,194,91,139,227,226,180,194,226,173 `
> `vt.default_blu=46,168,161,175,250,231,213,222,112,168,161,175,250,231,213,200 `
> `loglevel=3 ibt=off `
> **`Desktop:`**` KDE Plasma `**`v:`**` 6.4.4 `**`tk:`**` Qt `**`v:`**` N/A `**`info:`**` frameworks `**`v:`**` 6.17.0 `
> **`wm:`**` kwin_wayland `**`vt:`**` 1 `**`dm:`**` `**`1:`**` LightDM `**`v:`**` 1.32.0 `**`note:`**` stopped `**`2:`**` SDDM `
> **`Distro:`**` Garuda `**`base:`**` Arch Linux `
> **`Machine:`**` `
> **`Type:`**` Convertible `**`System:`**` ASUSTeK `**`product:`**` ROG Flow X16 GV601VI_GV601VI `
> **`v:`**` 1.0 `**`serial:`**` <superuser required> `
> **`Mobo:`**` ASUSTeK `**`model:`**` GV601VI `**`v:`**` 1.0 `**`serial:`**` <superuser required> `
> **`uuid:`**` <superuser required> `**`UEFI:`**` American Megatrends LLC. `**`v:`**` GV601VI.314 `
> **`date:`**` 08/30/2024 `
> **`Battery:`**` `
> **`ID-1:`**` BAT0 `**`charge:`**` 46.2 Wh (64.1%) `**`condition:`**` 72.1/90.0 Wh (80.1%) `
> **`power:`**` 15.4 W `**`volts:`**` 15.9 `**`min:`**` 16.0 `**`model:`**` ASUSTeK ASUS Battery `**`type:`**` Li-ion `
> **`serial:`**` N/A `**`status:`**` charging `**`cycles:`**` 282 `
> **`CPU:`**` `
> **`Info:`**` `**`model:`**` 13th Gen Intel Core i9-13900H `**`bits:`**` 64 `**`type:`**` MST AMCP `
> **`arch:`**` Raptor Lake `**`gen:`**` core 13 `**`level:`**` v3 `**`note:`**` check `**`built:`**` 2022+ `
> **`process:`**` Intel 7 (10nm) `**`family:`**` 6 `**`model-id:`**` 0xBA (186) `**`stepping:`**` 2 `
> **`microcode:`**` 0x4129 `
> **`Topology:`**` `**`cpus:`**` 1x `**`dies:`**` 1 `**`clusters:`**` 8 `**`cores:`**` 14 `**`threads:`**` 20 `**`mt:`**` 6 `**`tpc:`**` 2 `
> **`st:`**` 8 `**`smt:`**` enabled `**`cache:`**` `**`L1:`**` 1.2 MiB `**`desc:`**` d-8x32 KiB, 6x48 KiB; i-6x32 `
> `KiB, 8x64 KiB `**`L2:`**` 11.5 MiB `**`desc:`**` 6x1.2 MiB, 2x2 MiB `**`L3:`**` 24 MiB `
> **`desc:`**` 1x24 MiB `
> **`Speed (MHz):`**` `**`avg:`**` 400 `**`min/max:`**` 400/5200:5400:4100 `**`scaling:`**` `
> **`driver:`**` intel_pstate `**`governor:`**` performance `**`cores:`**` `**`1:`**` 400 `**`2:`**` 400 `**`3:`**` 400 `
> **`4:`**` 400 `**`5:`**` 400 `**`6:`**` 400 `**`7:`**` 400 `**`8:`**` 400 `**`9:`**` 400 `**`10:`**` 400 `**`11:`**` 400 `**`12:`**` 400 `**`13:`**` 400 `
> **`14:`**` 400 `**`15:`**` 400 `**`16:`**` 400 `**`17:`**` 400 `**`18:`**` 400 `**`19:`**` 400 `**`20:`**` 400 `**`bogomips:`**` 119807 `
> **`Flags:`**` avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx `
> **`Vulnerabilities:`**` <filter> `
> **`Graphics:`**` `
> **`Device-1:`**` Intel Raptor Lake-P [Iris Xe Graphics] `**`vendor:`**` ASUSTeK `
> **`driver:`**` i915 `**`v:`**` kernel `**`alternate:`**` xe `**`arch:`**` Xe `**`process:`**` Intel 7 (10nm) `
> **`built:`**` 2022+ `**`ports:`**` `**`active:`**` eDP-1 `**`empty:`**` DP-1,DP-2,HDMI-A-1 `
> **`bus-ID:`**` 00:02.0 `**`chip-ID:`**` 8086:a7a0 `**`class-ID:`**` 0300 `
> **`Device-2:`**` NVIDIA AD106M [GeForce RTX 4070 Max-Q / Mobile] `**`vendor:`**` ASUSTeK `
> **`driver:`**` nvidia `**`v:`**` 575.64.05 `**`alternate:`**` nouveau,nvidia_drm `
> **`non-free:`**` 550-570.xx+ `**`status:`**` current (as of 2025-04) `**`arch:`**` Lovelace `
> **`code:`**` AD1xx `**`process:`**` TSMC n4 (5nm) `**`built:`**` 2022+ `**`pcie:`**` `**`gen:`**` 1 `
> **`speed:`**` 2.5 GT/s `**`lanes:`**` 8 `**`link-max:`**` `**`gen:`**` 4 `**`speed:`**` 16 GT/s `**`ports:`**` `
> **`active:`**` none `**`empty:`**` DP-3,HDMI-A-2,eDP-2 `**`bus-ID:`**` 01:00.0 `**`chip-ID:`**` 10de:2860 `
> **`Device-3:`**` Kingcome USB2.0 FHD UVC WebCam `**`driver:`**` uvcvideo `**`type:`**` USB `
> **`rev:`**` 2.0 `**`speed:`**` 480 Mb/s `**`lanes:`**` 1 `**`mode:`**` 2.0 `**`bus-ID:`**` 3-8:7 `**`chip-ID:`**` 2b7e:c705 `
> **`class-ID:`**` fe01 `**`serial:`**` <filter> `
> **`Display:`**` wayland `**`server:`**` ``X.org`` `**`v:`**` 1.21.1.18 `**`with:`**` Xwayland `**`v:`**` 24.1.8 `
> **`compositor:`**` kwin_wayland `**`driver:`**` `**`X:`**` `**`loaded:`**` modesetting,nvidia `
> **`unloaded:`**` nouveau `**`alternate:`**` fbdev,intel,nv,vesa `**`dri:`**` iris `**`gpu:`**` i915 `
> **`display-ID:`**` 0 `
> **`Monitor-1:`**` eDP-1 `**`model:`**` BOE Display NE160QDM-NM4 `**`built:`**` 2022 `**`res:`**` `
> **`mode:`**` 2560x1600 `**`hz:`**` 240 `**`scale:`**` 175% (1.75) `**`to:`**` 1463x914 `**`dpi:`**` 188 `**`gamma:`**` 1.2 `
> **`size:`**` 345x215mm (13.58x8.46") `**`diag:`**` 407mm (16") `**`ratio:`**` 16:10 `
> **`modes:`**` 2560x1600 `
> **`API:`**` EGL `**`v:`**` 1.5 `**`hw:`**` `**`drv:`**` intel iris `**`drv:`**` nvidia `**`platforms:`**` `**`device:`**` 0 `
> **`drv:`**` nvidia `**`device:`**` 2 `**`drv:`**` iris `**`device:`**` 3 `**`drv:`**` swrast `**`gbm:`**` `**`drv:`**` nvidia `
> **`surfaceless:`**` `**`drv:`**` nvidia `**`wayland:`**` `**`drv:`**` iris `**`x11:`**` `**`drv:`**` iris `
> **`inactive:`**` device-1 `
> **`API:`**` OpenGL `**`v:`**` 4.6.0 `**`compat-v:`**` 4.5 `**`vendor:`**` intel mesa `**`v:`**` 25.1.7-arch1.1 `
> **`glx-v:`**` 1.4 `**`direct-render:`**` yes `**`renderer:`**` Mesa Intel Iris Xe Graphics (RPL-P) `
> **`device-ID:`**` 8086:a7a0 `**`memory:`**` 30.24 GiB `**`unified:`**` yes `**`display-ID:`**` :0.0 `
> **`API:`**` Vulkan `**`v:`**` 1.4.321 `**`layers:`**` 11 `**`device:`**` 0 `**`type:`**` integrated-gpu `
> **`name:`**` Intel Iris Xe Graphics (RPL-P) `**`driver:`**` mesa intel `**`v:`**` 25.1.7-arch1.1 `
> **`device-ID:`**` 8086:a7a0 `**`surfaces:`**` N/A `**`device:`**` 1 `**`type:`**` discrete-gpu `
> **`name:`**` NVIDIA GeForce RTX 4070 Laptop GPU `**`driver:`**` nvidia `**`v:`**` 575.64.05 `
> **`device-ID:`**` 10de:2860 `**`surfaces:`**` N/A `**`device:`**` 2 `**`type:`**` cpu `**`name:`**` llvmpipe `
> `(LLVM 20.1.8 256 bits) `**`driver:`**` mesa llvmpipe `**`v:`**` 25.1.7-arch1.1 (LLVM `
> `20.1.8) `**`device-ID:`**` 10005:0000 `**`surfaces:`**` N/A `
> **`Info:`**` `**`Tools:`**` `**`api:`**` clinfo, eglinfo, glxinfo, vulkaninfo `
> **`de:`**` kscreen-console,kscreen-doctor `**`gpu:`**` corectrl, nvidia-settings, `
> `nvidia-smi `**`wl:`**` wayland-info `**`x11:`**` xdpyinfo, xprop, xrandr `
> **`Audio:`**` `
> **`Device-1:`**` Intel Raptor Lake-P/U/H cAVS `**`vendor:`**` ASUSTeK `**`driver:`**` snd_hda_intel `
> **`v:`**` kernel `**`alternate:`**` snd_soc_avs,snd_sof_pci_intel_tgl `**`bus-ID:`**` 00:1f.3 `
> **`chip-ID:`**` 8086:51ca `**`class-ID:`**` 0403 `
> **`Device-2:`**` NVIDIA AD106M High Definition Audio `**`vendor:`**` ASUSTeK `
> **`driver:`**` snd_hda_intel `**`v:`**` kernel `**`pcie:`**` `**`gen:`**` 4 `**`speed:`**` 16 GT/s `**`lanes:`**` 8 `
> **`bus-ID:`**` 01:00.1 `**`chip-ID:`**` 10de:22bd `**`class-ID:`**` 0403 `
> **`API:`**` ALSA `**`v:`**` k6.15.9-zen1-1.1-zen `**`status:`**` kernel-api `**`with:`**` aoss `
> **`type:`**` oss-emulator `**`tools:`**` N/A `
> **`Server-1:`**` sndiod `**`v:`**` N/A `**`status:`**` off `**`tools:`**` aucat,midicat,sndioctl `
> **`Server-2:`**` PipeWire `**`v:`**` 1.4.7 `**`status:`**` active `**`with:`**` `**`1:`**` pipewire-pulse `
> **`status:`**` active `**`2:`**` wireplumber `**`status:`**` active `**`3:`**` pipewire-alsa `**`type:`**` plugin `
> **`4:`**` pw-jack `**`type:`**` plugin `**`tools:`**` pactl,pw-cat,pw-cli,wpctl `
> **`Network:`**` `
> **`Device-1:`**` Intel Raptor Lake PCH CNVi WiFi `**`driver:`**` iwlwifi `**`v:`**` kernel `
> **`bus-ID:`**` 00:14.3 `**`chip-ID:`**` 8086:51f1 `**`class-ID:`**` 0280 `
> **`IF:`**` wlo1 `**`state:`**` up `**`mac:`**` <filter> `
> **`Info:`**` `**`services:`**` NetworkManager, systemd-timesyncd, wpa_supplicant `
> **`Bluetooth:`**` `
> **`Device-1:`**` Intel AX211 Bluetooth `**`driver:`**` btusb `**`v:`**` 0.8 `**`type:`**` USB `**`rev:`**` 2.0 `
> **`speed:`**` 12 Mb/s `**`lanes:`**` 1 `**`mode:`**` 1.1 `**`bus-ID:`**` 3-10:9 `**`chip-ID:`**` 8087:0033 `
> **`class-ID:`**` e001 `
> **`Report:`**` btmgmt `**`ID:`**` hci0 `**`rfk-id:`**` 3 `**`state:`**` up `**`address:`**` N/A `
> **`Drives:`**` `
> **`Local Storage:`**` `**`total:`**` 3.68 TiB `**`used:`**` 52.68 GiB (1.4%) `
> **`SMART Message:`**` Unable to run smartctl. Root privileges required. `
> **`ID-1:`**` /dev/nvme0n1 `**`maj-min:`**` 259:9 `**`vendor:`**` Micron `**`model:`**` 2400 MTFDKBA2T0QFM `
> **`size:`**` 1.86 TiB `**`block-size:`**` `**`physical:`**` 512 B `**`logical:`**` 512 B `**`speed:`**` 63.2 Gb/s `
> **`lanes:`**` 4 `**`tech:`**` SSD `**`serial:`**` <filter> `**`fw-rev:`**` V3MA003 `**`temp:`**` 34.9 C `
> **`scheme:`**` GPT `
> **`ID-2:`**` /dev/nvme1n1 `**`maj-min:`**` 259:0 `**`vendor:`**` Smart Modular Tech. `
> **`model:`**` SHPP41-2000GM `**`size:`**` 1.82 TiB `**`block-size:`**` `**`physical:`**` 512 B `
> **`logical:`**` 512 B `**`speed:`**` 63.2 Gb/s `**`lanes:`**` 4 `**`tech:`**` SSD `**`serial:`**` <filter> `
> **`fw-rev:`**` 51060A20 `**`temp:`**` 41.9 C `**`scheme:`**` GPT `
> **`Partition:`**` `
> **`ID-1:`**` / `**`raw-size:`**` 99.96 GiB `**`size:`**` 99.96 GiB (100.00%) `
> **`used:`**` 52.66 GiB (52.7%) `**`fs:`**` btrfs `**`dev:`**` /dev/nvme0n1p9 `**`maj-min:`**` 259:18 `
> **`ID-2:`**` /boot/efi `**`raw-size:`**` 600 MiB `**`size:`**` 598.8 MiB (99.80%) `
> **`used:`**` 22.7 MiB (3.8%) `**`fs:`**` vfat `**`dev:`**` /dev/nvme0n1p1 `**`maj-min:`**` 259:10 `
> **`ID-3:`**` /home `**`raw-size:`**` 99.96 GiB `**`size:`**` 99.96 GiB (100.00%) `
> **`ID-4:`**` /var/log `**`raw-size:`**` 99.96 GiB `**`size:`**` 99.96 GiB (100.00%) `
> **`ID-5:`**` /var/tmp `**`raw-size:`**` 99.96 GiB `**`size:`**` 99.96 GiB (100.00%) `
> **`Swap:`**` `
> **`Kernel:`**` `**`swappiness:`**` 133 (default 60) `**`cache-pressure:`**` 100 (default) `**`zswap:`**` no `
> **`ID-1:`**` swap-1 `**`type:`**` zram `**`size:`**` 30.97 GiB `**`used:`**` 0 KiB (0.0%) `**`priority:`**` 100 `
> **`comp:`**` zstd `**`avail:`**` lzo-rle,lzo,lz4,lz4hc,deflate,842 `**`dev:`**` /dev/zram0 `
> **`ID-2:`**` swap-2 `**`type:`**` partition `**`size:`**` 34.07 GiB `**`used:`**` 0 KiB (0.0%) `
> **`priority:`**` -2 `**`dev:`**` /dev/nvme0n1p6 `**`maj-min:`**` 259:15 `
> **`Sensors:`**` `
> **`System Temperatures:`**` `**`cpu:`**` 47.0 C `**`mobo:`**` N/A `
> **`Fan Speeds (rpm):`**` `**`cpu:`**` 3400 `
> **`Info:`**` `
> **`Memory:`**` `**`total:`**` 32 GiB `**`note:`**` est. `**`available:`**` 30.97 GiB `**`used:`**` 5.69 GiB (18.4%) `
> **`Processes:`**` 472 `**`Power:`**` `**`uptime:`**` 4m `**`states:`**` freeze,mem,disk `**`suspend:`**` s2idle `
> **`avail:`**` deep `**`wakeups:`**` 0 `**`hibernate:`**` platform `**`avail:`**` shutdown, reboot, `
> `suspend, test_resume `**`image:`**` 12.28 GiB `**`services:`**` org_kde_powerdevil,upowerd `
> **`Init:`**` systemd `**`v:`**` 257 `**`default:`**` graphical `**`tool:`**` systemctl `
> **`Packages:`**` `**`pm:`**` pacman `**`pkgs:`**` 1892 `**`libs:`**` 557 `**`tools:`**` octopi,paru `**`Compilers:`**` `
> **`clang:`**` 20.1.8 `**`gcc:`**` 15.1.1 `**`Shell:`**` Bash `**`v:`**` 5.3.3 `**`default:`**` fish `**`v:`**` 4.0.2 `
> **`running-in:`**` konsole `**`inxi:`**` 3.3.38 `
> **`Garuda (2.7.5-1):`**` `
> **`System install date:`**` 2025-07-15 `
> **`Last full system update:`**` 2025-08-14 `
> **`Is partially upgraded:`** ` No `
> **`Relevant software:`** ` snapper tlp NetworkManager dracut nvidia-dkms `
> **`Windows dual boot:`** ` Probably (Run as root to verify) `
> **`Failed units:`**` `
> `--- System Health Check Report --- `
> `20/21 checks run in 0.50 seconds ⌛ `
> `Powered by garuda-health 🦅e `
> `✅ System health check passed. No issues found. `
> **`╭─shawd1`**`@`**`ROG`**` in ~ took `**`3s`**` `
> **`╰─λ`**` sudo cachy-chroot `
> `[sudo] password for shawd1: `
> `Info: Found 14 block devices `
> `Info: Found partition: Partition: /dev/nvme1n1p1: FS: vfat UUID: 9AC5-B4A4 `
> `Info: Found partition: Partition: /dev/nvme1n1p3: FS: ntfs UUID: 1A28C76428C73E0F `
> `Info: Found partition: Partition: /dev/nvme1n1p5: FS: ntfs UUID: 66F2D299F2D26CB5 `
> `Info: Found partition: Partition: /dev/nvme1n1p6: FS: ntfs UUID: DCE280A1E280818E `
> `Info: Found partition: Partition: /dev/nvme1n1p7: FS: vfat UUID: 9E80-B600 `
> `Info: Found partition: Partition: /dev/nvme1n1p8: FS: btrfs UUID: 019f135f-eb5a-4d95-b465-ca990f29749a `
> `Info: Found partition: Partition: /dev/nvme0n1p1: FS: vfat UUID: 4B53-544B `
> `Info: Found partition: Partition: /dev/nvme0n1p2: FS: ext4 UUID: 4a02d63a-a6a2-410e-964d-4358d43dea73 `
> `Info: Found partition: Partition: /dev/nvme0n1p3: FS: btrfs UUID: dbe2f43d-a021-4410-ae9a-6b5eacff1118 `
> `Info: Found partition: Partition: /dev/nvme0n1p4: FS: ntfs UUID: 16FE11FC41E64621 `
> `Info: Found partition: Partition: /dev/nvme0n1p5: FS: ext4 UUID: 9fdecfba-b6c7-417a-ae98-0a3cad2aaa27 `
> `Info: Found partition: Partition: /dev/nvme0n1p7: FS: ext4 UUID: 46df87c0-5656-4331-90bf-603f4741c8c6 `
> `Info: Found partition: Partition: /dev/nvme0n1p8: FS: btrfs UUID: 0c2a9ca4-9d6e-4d77-9f4d-e2ef022ffa1e `
> `Info: Found partition: Partition: /dev/nvme0n1p9: FS: btrfs UUID: ffb624f5-fc23-45ad-a432-952737d296c8 `
> `✔ `**`Select the block device for the root`**` partition (use arrow keys): · Partition: /dev/nvme0n1p3: FS: btrfs UUID: dbe2f43d-a021-4410-ae9a-6b5eacf`
> `f1118 `
> `Info: Selected BTRFS partition, mounting and listing subvolumes... `
> `Info: Mounting partition /dev/nvme0n1p3 at /tmp/cachyos-chroot-temp-mount-dbe2f43d-a021-4410-ae9a-6b5eacff1118-2Ui0I1 with options: [] `
> `mount: /tmp/cachyos-chroot-temp-mount-dbe2f43d-a021-4410-ae9a-6b5eacff1118-2Ui0I1: can't read superblock on /dev/nvme0n1p3. `
> `dmesg(1) may have more information after failed mount system call. `
> `Error: Failed to mount partition /dev/nvme0n1p3 at /tmp/cachyos-chroot-temp-mount-dbe2f43d-a021-4410-ae9a-6b5eacff1118-2Ui0I1`
