Btrfs heavy I/O performance issues
  Kernel: 5.18.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d rw rootflags=subvol=@
    sysrq_always_enabled=1 amdgpu.ppfeaturemask=0xffffffff nowatchdog
  Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
    wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
    UEFI: American Megatrends v: P4.86 date: 01/27/2022
  Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 2
    built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2
    microcode: 0x800820D
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 4108 high: 4125 min/max: 2200/3600 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 4108 2: 4101
    3: 4121 4: 4077 5: 4112 6: 4085 7: 4113 8: 4125 9: 4125 10: 4101 11: 4111
    12: 4120 bogomips: 86401
  Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
    vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA 2
    lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,HDMI-A-2
    bus-ID: 0f:00.0 chip-ID: 1002:73df class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
    unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
    d-rect: 5888x2160 display-ID: 0
  Monitor-1: DP-1 pos: primary,left res: 2048x864 size: N/A modes: N/A
  Monitor-2: HDMI-A-1 pos: right res: 3840x2160 size: N/A modes: N/A
  OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 14.0.6 DRM
    3.46 5.18.10-zen1-1-zen)
    v: 4.6 Mesa 22.1.3 direct render: Yes
  Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0f:00.1 chip-ID: 1002:ab28
  Sound Server-1: ALSA v: k5.18.10-zen1-1-zen running: yes
  Sound Server-4: PipeWire v: 0.3.54 running: yes
  Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 09:00.0
  IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Edimax Bluetooth Adapter type: USB driver: btusb v: 0.8
    bus-ID: 1-8:3 chip-ID: 7392:c611 class-ID: e001 serial: <filter>
  Local Storage: total: 4.22 TiB used: 3.57 TiB (84.5%)
    model: SSD 970 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
    rev: 2B2QEXE7 temp: 29.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 980 1TB
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
    temp: 38.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
    type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
    model: WD10EURX-63UY4Y0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B type: HDD rpm: 5400 serial: <filter> scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Generic
    model: STORAGE DEVICE size: 366.82 GiB block-size: physical: 512 B
    logical: 512 B type: N/A serial: <filter> rev: 1532 scheme: MBR
    used: 756.8 GiB (81.3%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7
    used: 16.3 MiB (5.5%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
  ID-1: swap-1 type: zram size: 31.27 GiB used: 3.89 GiB (12.4%)
  System Temperatures: cpu: 51.6 C mobo: 38.0 C gpu: amdgpu temp: 57.0 C
    mem: 60.0 C
  Fan Speeds (RPM): cpu: 2054 fan-1: 0 fan-3: 0 fan-4: 0 fan-5: 0
    gpu: amdgpu fan: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.25 vbat: 3.28 gpu: amdgpu watts: 31.00
  Processes: 446 Uptime: 2h 10m wakeups: 3 Memory: 31.27 GiB
  used: 11.04 GiB (35.3%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 2427
  pacman: 2409 lib: 590 flatpak: 18 Shell: fish v: 3.4.1 default: Bash
  v: 5.1.16 running-in: alacritty inxi: 3.3.19
Garuda (2.6.4-2):
  System install date:     2022-05-22
  Last full system update: 2022-07-10
So ever since I started using garuda I have noticed performance issues whenever there is high I/O usage such as downloading a game copying a big file etc..
Is this a limitation of btrfs? I didn't notice the same performance issue when I briefly installed ubuntu on this same disk to troubleshoot some other issues I was having.
Check with htop if baloo (or similar) is in action.
Most of the time I have heavy use from Dolphin.
baloo is always the first thing i disable whenever I install kde. yeah its usually dolphin that has heavy usage from some copy operation. I didn't really pay attention to this until i switched to ubuntu for a bit and noticed way better system responsiveness. Which is why i was wondering if btrfs is inherently less responsive the ext4 or something
Something I did try just now is changing the cpu scheduler from performance to schedutil which seems to help with responsiveness a bit?
Is this happening when performing copy operations to an external USB drive?
Does this happen when performing a copy operation from the terminal as well?
I would test different kernels and I/O schedulers for improvements.
wow did not expect schedutil to make such a difference from performance. it seems to be spreading out the load more rather than just push one core.
I'm testing with multiple I/O operations one in the terminal merging some split files I needed to merge and another copying some files to a usb . while also syncing my docs to a cloud backup. cpu load is high as expected on most cores but the responsiveness is butter smooth.
maybe the schedutil cpu governor should be made the default if its not?
