I cannot boot anymore. There is a BTRS failure on my LUKS container on boot.
I'm booted now on a USB disk with another arch based distro and would like to repair my disk.
Here is the message I get if I try to mount the LUKS volume ![]()
The disk in problem is on /dev/nvme0n1p2 and cryptomounted at /mnt/garuda.
Is there anything I can do to repair my btrfs filesystem ????
[madbox ~]# btrfsck --init-extent-tree /dev/mapper/garuda
WARNING:
Do not use --repair unless you are advised to do so by a developer
or an experienced user, and then only after having accepted that no
fsck can successfully repair all types of filesystem corruption. Eg.
some software or hardware bugs can fatally damage a volume.
The operation will start in 10 seconds.
Use Ctrl-C to stop it.
10 9 8 7 6 5 4 3 2 1
Starting repair.
Opening filesystem to check...
parent transid verify failed on 1608613888 wanted 131659 found 132173
Ignoring transid failure
ERROR: root [4 0] level 0 does not match 1
Couldn't setup device tree
ERROR: cannot open file system
I can't boot, so I cannot show inxi from garuda ... but here is what I get from the usb disk I booted ![]()
[madbox ~]# inxi -Faz
Kernel: 5.17.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.17-x86_64
root=UUID=8c2744e5-7802-4252-b6a2-05dea64b6e7d rw rootflags=subvol=@
quiet
cryptdevice=UUID=95bb221b-0c95-4f2d-9bf1-086d0a14acea:luks-95bb221b-0c95-4f2d-9bf1-086d0a14acea
root=/dev/mapper/luks-95bb221b-0c95-4f2d-9bf1-086d0a14acea
resume=/dev/mapper/luks-68a4eb59-cf64-411a-9acc-6fbd476a5ead
udev.log_priority=3 pcie_aspm=off
Desktop: Openbox v: 3.6.1 info: tint2 dm: LightDM v: 1.30.0
Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513UA_M513UA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X513UA v: 1.0 serial: <filter>
UEFI: American Megatrends LLC. v: X513UA.305 date: 03/12/2021
ID-1: BAT0 charge: 38.8 Wh (100.0%) condition: 38.8/42.1 Wh (92.2%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 22
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Info: model: AMD Ryzen 7 5700U with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1396 high: 1397 min/max: 400/4372 boost: enabled
base/boost: 1800/4350 scaling: driver: amd-pstate governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1397 2: 1397 3: 1397 4: 1397
5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397
13: 1397 14: 1397 15: 1397 16: 1396 bogomips: 57504
Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel pcie:
active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
Device-2: Quanta USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-3:3 chip-ID: 0408:30d4 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: Picom v: git-7e568
driver: X: loaded: amdgpu unloaded: fbdev,modesetting alternate: vesa
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0046 built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
snd_sof_amd_renoir
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.17.1-3-MANJARO running: yes
Sound Server-2: JACK v: 1.9.20 running: no
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
bus-ID: 3-2:5 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 1.05 TiB used: 7.06 GiB (0.7%)
model: PC SN530 SDBPNPZ-1T00-1002 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21106000 temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Samsung model: Flash Drive
size: 119.5 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1100 scheme: GPT
ID-1: / raw-size: 102.59 GiB size: 102.59 GiB (100.00%)
used: 7.06 GiB (6.9%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-95bb221b-0c95-4f2d-9bf1-086d0a14acea
used: 712 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 102.59 GiB size: 102.59 GiB (100.00%)
ID-4: /var/log raw-size: 102.59 GiB size: 102.59 GiB (100.00%)
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 16.61 GiB used: 0 KiB (0.0%)
mapped: luks-68a4eb59-cf64-411a-9acc-6fbd476a5ead
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
Fan Speeds (RPM): cpu: 0
Processes: 355 Uptime: 12h 14m wakeups: 13 Memory: 15.1 GiB
used: 2.14 GiB (14.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 904 lib: 198 Shell: Bash (sudo) v: 5.1.16
running-in: terminator inxi: 3.3.15
