Ok, thx, now, I guess I'll just have to backup and reinstall garuda, @ me when your machine is delivered :).
Also, do you know how I may troubleshoot this issue? I'm curious how brtfs work and why it may have malfunctionned (I already read the arch wiki but if you have further info...)
Probably. “Disk IO” errors tend to point towards an issue with hardware. You could always test it as suggested previously:
Yes.
So buying a new ssd may be the only final workaround? I buyed it 6 month ago... It's hard to believe it broke.
Test it and find out. We can't do that for you.
You should have a warranty to replace failed hardware so test it and if it's broken then let the retailer know you want a replacement.
How do you know it is failing? Have you used any utility to repair it?
I dont know but I believe because :
Also, I checked SMART status and no error was reported.
Then it must be in brand warranty.
But I would suggest performing some memory test (available on live boot) before concluding that disk is broken.
