Hello.
somehow, my btrfs partition with my operation system got corrupted.
I think it was caused by system freeze during the btrfs balancing operation.
As several users of this forum, I've experienced system freezes, forcing me to hard restart every time they occur. So I've decided to balance the file system and then switch to the lts kernel.
Unfortunately, a freeze occurred during the balancing procedure.
When I boot, the error "BTRF critical (device sda2(?)) corrupt leaf" quickly flashes on screen and then the garuda update screen (the one with the logo in an animated circle) comes up.
I've let it run for 10 hours without any changes.
I did search for the error online, yet did not find a conclusive answer.
When I try to access the partition via a live usb, I get the following error message:
An error occurred while accessing 'Home', the system responded: The requested operation has failed: Error mounting /dev/sda2 at /run/media/garuda/8b782b3f-9cd5-4d15-8596-8ef5e81954cf: can't read superblock on /dev/sda2
As I've looked for it, I found the
btrfs-select-super
command, which according to its man page appears to be exactly what I'm looking for.
Should I do it?
And do you need any extra information from my current state?
Here is my inxi which I receive when booting from a live usb:
inxi -Faz
System: Kernel: 5.14.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=garuda
misolabel=GARUDA_DR460NIZEDGAMING_HARPYEAG quiet systemd.show_status=1 driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: Micro-Star model: Z370 PC PRO (MS-7B49) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 1.00 date: 09/04/2017
CPU: Info: 6-Core model: Intel Core i5-8600K bits: 64 type: MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: A (10) microcode: EA cache: L2: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 43200
Speed: 4264 MHz min/max: 800/4300 MHz Core speeds (MHz): 1: 4264 2: 4276 3: 4281 4: 4203
5: 4200 6: 4254
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Micro-Star MSI driver: nouveau v: kernel
bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Monitor-1: DP-2 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
OpenGL: renderer: NV136 v: 4.3 Mesa 21.2.2 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-3: C-Media CM108 Audio Controller type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-4:3 chip-ID: 0d8c:013c class-ID: 0300
Sound Server-1: ALSA v: k5.14.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e v: kernel port: f000
bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k v: kernel port: e000
bus-ID: 04:00.0 chip-ID: 168c:0030 class-ID: 0280
Drives: Local Storage: total: 2.3 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 023 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA200 size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: ABB0
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Intenso model: Ultra Line size: 29.3 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> scheme: MBR
ID-1: swap-1 type: zram size: 31.31 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 43.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Info: Processes: 204 Uptime: 46m wakeups: 0 Memory: 31.31 GiB used: 3.26 GiB (10.4%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1706 lib: 500
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
