Been having a very smooth experience on Garuda for the past few days or so but just now I have noticed my system is very slow and unresponsive and laggy and it shows under the command "top" that btrfs-cleaner along with other btrfs services are eating up a lot of my CPU resources. Any clue why this is? I will reboot to see if that helps but would be good to know what causes this and if I can prevent this in the future. Thanks
λ inxi -Faz
Kernel: 5.16.2-3-cachyos x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=95b636ca-42a5-47b4-9b7a-038581af6cdf rw rootflags=subvol=@
resume=UUID=41193397-191d-45b5-8c2b-405cf71e73b2 loglevel=3
Type: Laptop System: ASUSTeK product: X510UA v: 1.0
Mobo: ASUSTeK model: X510UA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X510UA.312 date: 04/29/2020
ID-1: BAT0 charge: 13.1 Wh (46.8%) condition: 28.0/42.1 Wh (66.6%)
volts: 11.5 min: 11.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Charging cycles: 430
Info: model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 0x8E (142)
stepping: 9 microcode: 0xEA
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2996 high: 3080 min/max: 400/3500 scaling:
driver: intel_pstate governor: performance cores: 1: 2883 2: 3015 3: 3080
4: 3008 bogomips: 23220
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: IMC Networks VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:2 chip-ID: 13d3:5a07 class-ID: 0e02 serial: <filter>
loaded: i915 note: n/a (using device driver) display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
Sound Server-1: ALSA v: k5.16.2-3-cachyos running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-8:3 chip-ID: 8087:0a2b class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 7 state: down
address: <filter>
Local Storage: total: 704.24 GiB used: 318.27 GiB (45.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
ID-2: /dev/sdb maj-min: 8:16 vendor: Micron model: 1100 MTFDDAV256TBN
type: SSD serial: <filter> rev: A020 scheme: GPT
ID-1: / raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
used: 318.27 GiB (71.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
ID-4: /var/log raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.06 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.52 GiB used: 574.6 MiB (3.6%)
System Temperatures: cpu: 64.0 C pch: 49.5 C mobo: N/A
Fan Speeds (RPM): cpu: 4000
Processes: 236 Uptime: 8h 16m wakeups: 16 Memory: 15.52 GiB
used: 2.56 GiB (16.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1547 lib: 388 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.12
