After running Garuda on my laptop for approx. 2 years with no problems and not changing my NVMe, nor changing the partition-table or file-systems, I have lately been experiencing sudden massive system load spikes and lags (going so far, that even the cursor freezes when moving the mouse) → (smells like swapping, tastes like swapping, probably is swapping). This lasts for a few minutes (~1-5min) and then resolves itself and goes back to normal.
My investigations have shown that both btrfs-cleaner
AND updatedb
seem to get started in a way that leads to them running concurrently at the same time, causing high load and memory usage, in turn causing kswapd to kick in, in turn causing massive system-load and and overall laggy system.
top - 09:38:38 up 17:38, 4 users, load average: 8.28, 4.04, 1.90
Tasks: 473 total, 8 running, 465 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.8 us, 29.1 sy, 0.0 ni, 69.4 id, 0.3 wa, 0.3 hi, 0.1 si, 0.0 st
MiB Mem : 15730.2 total, 69.8 free, 9184.7 used, 8281.0 buff/cache
MiB Swap: 33037.5 total, 29876.2 free, 3161.2 used. 6545.5 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
3781 baccenf+ 20 0 22.9g 343464 132184 R 165.8 2.1 5:57.66 Isolated Web Co
164 root 20 0 0 0 0 R 99.7 0.0 3:30.53 kswapd0
32751 root 39 19 6396 4220 3840 R 99.0 0.0 3:10.82 updatedb
515 root 20 0 0 0 0 R 93.7 0.0 2:46.53 btrfs-cleaner
1097 root 20 0 1096880 108512 81464 R 85.0 0.7 9:19.66 Xorg
Kernel: 6.10.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=0e48fd2e-4aaa-4609-8fb8-c477f0f931b0 rw rootflags=subvol=@
quiet
cryptdevice=UUID=76870f8a-2a08-4382-8f37-97eaf4fb75fb:luks-76870f8a-2a08-4382-8f37-97eaf4fb75fb
root=/dev/mapper/luks-76870f8a-2a08-4382-8f37-97eaf4fb75fb quiet
resume=/dev/mapper/luks-cd774d59-4fcd-4ad6-94cc-5b22d8858918 loglevel=3
Desktop: i3 v: 4.23 with: i3bar tools: avail: i3lock,xautolock,xtrlock
Type: Laptop System: TUXEDO product: TUXEDO InfinityBook Pro Gen7 (MK1)
v: Standard serial: <filter>
Mobo: NB02 model: PHxARX1_PHxAQF1 v: Standard serial: <filter>
part-nu: IBP1XI07MK1 uuid: adf12380-0cbc-11ed-9a44-4bf7f0011b00
UEFI: American Megatrends LLC. v: N.1.05A07 date: 11/07/2022
ID-1: BAT0 charge: 66.6 Wh (100.0%) condition: 66.6/99.2 Wh (67.2%)
volts: 16.7 min: 15.5 model: standard type: Li-ion serial: <filter>
status: full
Info: model: 12th Gen Intel Core i7-12700H socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake gen: core 12 level: v3 note: check
built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154)
stepping: 3 microcode: 0x433
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 780 high: 2544 min/max: 400/4600:4700:3500
base/boost: 2178/4700 scaling: driver: intel_pstate governor: powersave
volts: 0.8 V ext-clock: 100 MHz cores: 1: 748 2: 400 3: 2544 4: 400
5: 1171 6: 400 7: 400 8: 400 9: 1152 10: 400 11: 400 12: 400 13: 1402
14: 1502 15: 400 16: 1232 17: 400 18: 400 19: 1064 20: 400
bogomips: 107520
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics]
vendor: Tongfang Hongkong driver: i915 v: kernel alternate: xe
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a6
Device-2: Chicony FHD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:4 chip-ID: 04f2:b75c
Display: unspecified server: X.Org v: 21.1.13 compositor: Picom
v: git-89c2c driver: X: loaded: modesetting alternate: fbdev,intel,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2880x1800 s-dpi: 96 s-size: 762x476mm (30.00x18.74")
s-diag: 898mm (35.37")
Monitor-1: eDP-1 model-id: CSO 0x1402 built: 2020 res: 2880x1800 hz: 90
dpi: 242 gamma: 1.2 size: 302x188mm (11.89x7.4") diag: 356mm (14")
ratio: 16:10 modes: 2880x1800
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 7.5 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 24.1.5-arch1.1
device-ID: 8086:46a6 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.5-arch1.1 (LLVM
vendor: Tongfang Hongkong driver: snd_hda_intel v: kernel
alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.10.3-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.2.2 status: n/a (root, process) with:
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0026
Local Storage: total: 465.76 GiB used: 309.84 GiB (66.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 32.9 C
ID-1: / raw-size: 448.56 GiB size: 448.56 GiB (100.00%)
used: 309.84 GiB (69.1%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-76870f8a-2a08-4382-8f37-97eaf4fb75fb
used: 728 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 448.56 GiB size: 448.56 GiB (100.00%)
ID-4: /var/log raw-size: 448.56 GiB size: 448.56 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.56 GiB size: 448.56 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.36 GiB used: 5.46 GiB (35.5%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20
ID-2: swap-2 type: partition size: 16.9 GiB used: 0 KiB (0.0%)
mapped: luks-cd774d59-4fcd-4ad6-94cc-5b22d8858918
System Temperatures: cpu: 55.0 C mobo: N/A
Memory: total: 16 GiB available: 15.36 GiB used: 7.53 GiB (49.0%)
igpu: 60 MiB
Processes: 463 Power: uptime: 18h 19m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 2 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.1 GiB services: upowerd
Packages: pm: pacman pkgs: 2143 libs: 507 tools: pacseek,pamac,paru
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Zsh
v: 5.9 running-in: zellij inxi: 3.3.35
System install date: 2023-02-01
Last full system update: 2024-08-06
Failed units: session-c1.scope
