Hello.
So Its been few days now I have been using Garuda Linux and have pretty much set it up as to me liking so thought of taking a backup just in case. But found out that my BTRFS assistant does'nt have the Snapper and Snapper settings tabs in it. Also when I try to open BTRFS assistant through Garuda welcome > BTRFS asst > It say s- Application must run as super user so I manually type it in krunner and open it but those tabs are missing.
root=UUID=0b3ee793-04a5-4396-a397-8dbad9c6feeb rw rootflags=subvol=@
resume=UUID=684fccb6-7d6a-4eda-8875-5b25dc60d985 loglevel=3 i8042.nokbd
Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC
v: 0884110000385910000610100 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 183E v: 56.32 serial: <superuser required>
UEFI: Insyde v: F.22 date: 11/22/2012
ID-1: BAT0 charge: 15.6 Wh (100.0%) condition: 15.6/15.6 Wh (100.0%)
volts: 12.3 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: full
Info: model: Intel Core i3-3110M bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1294 high: 1494 min/max: 1200/2400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1494 2: 1198 3: 1197
4: 1288 bogomips: 19156
Type: l1tf
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: AMD Thames [Radeon HD 7500M/7600M Series]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 1002:6840 class-ID: 0300
Device-3: Suyin HP TrueVision HD Integrated Webcam type: USB
driver: uvcvideo bus-ID: 2-1.5:3 chip-ID: 064e:e263 class-ID: 0e02
loaded: intel,radeon unloaded: modesetting alternate: fbdev,vesa gpu: i915
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS1 model: LG Display 0x034d built: 2012
res: 1366x768 hz: 60 dpi: 102 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 22.0.0 compat-v: 3.1 direct render: Yes
Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard
driver: rt2800pci v: 2.3.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 07:00.0 chip-ID: 1814:3290 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8136
Device-1: Ralink RT3290 Bluetooth vendor: Hewlett-Packard driver: N/A pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.1 chip-ID: 1814:3298
class-ID: 0d11
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 931.51 GiB used: 8.52 GiB (0.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0001
ID-1: / raw-size: 915.01 GiB size: 915.01 GiB (100.00%)
used: 8.52 GiB (0.9%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 915.01 GiB size: 915.01 GiB (100.00%)
ID-4: /var/log raw-size: 915.01 GiB size: 915.01 GiB (100.00%)
ID-5: /var/tmp raw-size: 915.01 GiB size: 915.01 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.66 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 62.0 C mobo: N/A gpu: radeon temp: 54.5 C
Processes: 230 Uptime: 25m wakeups: 1 Memory: 7.66 GiB
used: 2.74 GiB (35.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1349 lib: 349 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-04-01
Last full system update: 2022-04-01 ↻
Snapshots: Snapper (maybe)
So what I thought of reinstalling BTRFS assitant again through OCTOPI and here is the error
Installing selected packages...
warning: grub-btrfs-4.11-2 is up to date -- reinstalling
warning: btrfs-assistant-1.1-1 is up to date -- reinstalling
warning: btrfs-progs-5.16.2-1 is up to date -- reinstalling
warning: os-prober-btrfs-1.79-3 is up to date -- reinstalling
warning: btrfsmaintenance-0.5-2 is up to date -- reinstalling
resolving dependencies...
Packages (5) btrfs-assistant8;5;243m-1.1-1 btrfs-progs8;5;243m-5.16.2-1 btrfsmaintenance8;5;243m-0.5-2 grub-btrfs8;5;243m-4.11-2 os-prober-btrfs8;5;243m-1.79-3
Download Size: 0.97 MiB
Installed Size: 5.79 MiB
Net Upgrade Size: 0.00 MiB
:: Retrieving packages...
(1/5) btrfs-progs-5.16.2-1-x86_64
(2/5) grub-btrfs-4.11-2-any
(3/5) os-prober-btrfs-1.79-3-x86_64
checking keys in keyring
checking package integrity
checking for file conflicts
checking available disk space
(1/5) reinstalling btrfs-progs
(2/5) reinstalling grub-btrfs
(3/5) reinstalling btrfs-assistant
(4/5) reinstalling os-prober-btrfs
(5/5) reinstalling btrfsmaintenance
Enabling os-prober...
Reloading system manager configuration...
Reloading device manager configuration...
Arming ConditionNeedsUpdate...
Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img
==> Starting build: 5.17.1-zen1-1-zen
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: dconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: onsolefont]
-> Running build hook: [plymouth]
-> Running build hook: [resume]
-> Running build hook: [filesystems]
-> Running build hook: [grub-btrfs-overlayfs]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen-fallback.img
Refreshing PackageKit...
Foreign/AUR package notification
=> No foreign/AUR packages found.
Updating icon theme caches...
Orphaned package notification...
=> No orphans found.
Checking for .pacnew and .pacsave files...
m.pac* files found:
/etc/paru.conf.pacnew
mPlease check and merge
Updating the desktop file MIMtype cache...
Syncing all file systems...
Command finished OK!
has this has to something to do with the missing snapper tabs and settings.
Also below is the ss of the BTRFS assitant how it looks for me.
