The inxi -Faz
Kernel: 5.16.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e7e27c36-1a2d-44f2-a91a-133cd96ac9a0 rw [email protected]
quiet
cryptdevice=UUID=cdec8ce4-ee6e-48c7-969c-b735ee912ac7:luks-cdec8ce4-ee6e-48c7-969c-b735ee912ac7
root=/dev/mapper/luks-cdec8ce4-ee6e-48c7-969c-b735ee912ac7 splash
resume=/dev/mapper/luks-8915ab05-25f9-424e-bcc5-6701ff3355d2 loglevel=3
Type: Desktop Mobo: Micro-Star model: X370 GAMING M7 ACK (MS-7A35) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.D0
date: 01/22/2019
Info: model: AMD Ryzen 7 1700X bits: 64 type: MT MCP arch: Zen
family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001137
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3350 high: 3499 min/max: 2200/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3398 2: 3457
3: 3481 4: 3497 5: 2836 6: 3492 7: 3282 8: 3082 9: 3253 10: 3418 11: 3491
12: 3499 13: 3160 14: 3434 15: 3466 16: 3359 bogomips: 108788
STIBP: disabled, RSB filling
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 26:00.0 chip-ID: 10de:1b06
Device-2: Anker PowerConf C300 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-9.1:15 chip-ID: 291a:3361 class-ID: 0e02 serial: <filter>
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 5120x1440 s-dpi: 108 s-size: 1204x342mm (47.4x13.5")
s-diag: 1252mm (49.3")
Monitor-1: DP-2 res: 2560x1440 dpi: 93 size: 697x393mm (27.4x15.5")
diag: 800mm (31.5")
Monitor-2: DP-4 res: 2560x1440 dpi: 109 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA GP102 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 26:00.1 chip-ID: 10de:10ef class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 28:00.3 chip-ID: 1022:1457
Device-3: Anker PowerConf C300 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.16.1-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: f000 bus-ID: 20:00.0
chip-ID: 1969:e0b1 class-ID: 0200
vendor: Rivet Networks Killer Wireless-n/a/ac 1535 driver: ath10k_pci
v: kernel bus-ID: 21:00.0 chip-ID: 168c:003e class-ID: 0280
IF: wlp33s0 state: down mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 2-1.4:3 chip-ID: 0bda:8153 class-ID: 0000
IF: enp3s0f0u1u4 state: down mac: <filter>
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 1-13:14 chip-ID: 0cf3:e300 class-ID: e001
address: <filter>
Local Storage: total: 3.64 TiB used: 77.04 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung model: SSD 960 EVO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B7QCXE7
temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P3CR020
temp: 44.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DX002-2DV162
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC41
model: WD10EADS-00L5B1 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1A01
scheme: MBR
ID-1: / raw-size: 914.02 GiB size: 914.02 GiB (100.00%)
used: 77.03 GiB (8.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-cdec8ce4-ee6e-48c7-969c-b735ee912ac7
used: 720 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 914.02 GiB size: 914.02 GiB (100.00%)
ID-4: /var/log raw-size: 914.02 GiB size: 914.02 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.02 GiB size: 914.02 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.63 GiB used: 1.57 GiB (10.0%)
ID-2: swap-2 type: partition size: 17.19 GiB used: 0 KiB (0.0%)
mapped: luks-8915ab05-25f9-424e-bcc5-6701ff3355d2
System Temperatures: cpu: 43.0 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 22%
Processes: 490 Uptime: 8h 8m wakeups: 0 Memory: 15.63 GiB
used: 8.08 GiB (51.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1918 lib: 537 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
When starting the BTRFS Assistant I get this picture:
Alt Text for Picture
Internal Filesystem Statistics
Data: 82%
Metadata: 60%
System: 0%
Balance recommended. Click here (arrow pointing right to the button) ----> Start Full balance
When pressing the button it tells me to check the service so I do:
systemctl status btrfs-balance.service
â—‹ btrfs-balance.service - Balance block groups on a btrfs filesystem
Loaded: loaded (/usr/lib/systemd/system/btrfs-balance.service; static)
Active: inactive (dead) since Fri 2022-01-21 17:38:26 CET; 2s ago
TriggeredBy: â—Ź btrfs-balance.timer
Docs: man:btrfs-balance
Process: 205555 ExecStart=/usr/share/btrfsmaintenance/btrfs-balance.sh (code=exited, status=0/SUCCESS)
Main PID: 205555 (code=exited, status=0/SUCCESS)
CPU: 881ms
Jan 21 17:38:25 eha-linux systemd[1]: Started Balance block groups on a btrfs filesystem.
Jan 21 17:38:26 eha-linux systemd[1]: btrfs-balance.service: Deactivated successfully.
journalctl -fu btrfs-balance.service
Hmm so I did not miss any logs.
What am I missing here?
(I did not test the old - reboot - solution yet..)
PS: You have lots of free space, did you overbuy?
Why are you mocking me! The system is quite fresh and I know I normally have around 500GB+ of Data after I have cloned all my repos for work.
