BTRFS as the default filesystem with zstd compression?
Very newbie here - and Linux!
FWIW, I chose this distro after testing many others (27+) and still learning my way around.
Here’s my 1st question.
Checking → /etc/fastab, shows:
btrfs subvol=/@root,defaults,noatime,compress=zstd 0 0
So, what is the compression level value?
I’ve learned (lots of lots of google’ng!) that the value should be 1 ~ 15.
What’s wrong with the garuda-inxi you failed to submit, as required by the template. You just failed your first Linux newbie test. Congratulations.
@mapefal
Your post was reported as inappropriate and deleted.
In addition, since the required data, the garuda-inxi, was not posted, this thread is locked until it is submitted. You can edit your first post and resubmit the data.
If you become abusive again, we will ban you from the forum.
@mapefal I believe when you join any community you should atleast be respectful to it’s rules and guidelines. They are there for a reason and every community not just open source or linux related, every single one that exists has a set of guidelines or is in the process of creating them.
