Made the mistake of formatting my swap partition in windows when mistaking it for another drive. Looking into restoring it since I takes a lot longer to log in now and I am unsure what else if affected. Should i be more focused on a fresh install or is this salvageable?
For generation a new swap file, would involve just making a subvolume and ensure it is non-snapshotted? Btrfs - ArchWiki
Here is drive structure and my install is on /dev/nvme1n1 where /dev/nvme1n1p1 is my btrfs volume and /dev/nvme1n2 was where my swap used to be.
Disk /dev/sda: 476.94 GiB, 512110190592 bytes, 1000215216 sectors
Disk model: Samsung SSD 850
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xe88560ef
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 206847 204800 100M 7 HPFS/NTFS/exFAT
/dev/sda2 206848 1000212479 1000005632 476.8G 7 HPFS/NTFS/exFAT
Disk /dev/sdb: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk model: WDC WD4000FYYZ-0
Disklabel type: dos
Disk identifier: 0x292b151f
/dev/sdb1 2048 4294965247 4294963200 2T 7 HPFS/NTFS/exFAT
Disk /dev/nvme0n1: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: Samsung SSD 970 EVO Plus 2TB
Disklabel type: gpt
Disk identifier: 8EEF171A-98C3-4B47-B69C-AC553034F95C
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 1085439 1083392 529M Windows recovery environment
/dev/nvme0n1p2 1085440 1288191 202752 99M EFI System
/dev/nvme0n1p3 1288192 1320959 32768 16M Microsoft reserved
/dev/nvme0n1p4 1320960 3907026943 3905705984 1.8T Microsoft basic data
Disk /dev/nvme1n1: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 970 EVO 500GB
Disklabel type: dos
Disk identifier: 0x96cbb0ea
/dev/nvme1n1p1 * 2048 904424855 904422808 431.3G 83 Linux
Disk /dev/zram0: 31.3 GiB, 33603715072 bytes, 8204032 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Are there anythings that i am missing or routes that would make more sense in repairing this such as a tool from the live environment? Here is additional information for my setup:
Kernel: 5.18.15-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=052b08b6-4b04-4770-b2cb-31b98943efb3 rw [email protected]
resume=UUID=dc95f6f1-c463-4373-8178-702b16ab719e loglevel=3 ibt=off
Desktop: N/A wm: LG3D vt: 1 dm: SDDM Distro: Garuda Linux
Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37) v: 2.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: A.40
date: 09/10/2019
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3807 high: 4073 min/max: N/A cores: 1: 3800 2: 3800
3: 3800 4: 3800 5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 4073
12: 3622 bogomips: 91202
protection
always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 2f:00.0 chip-ID: 1002:73bf
compositor: Picom v: git-c4107 driver: X: loaded: amdgpu gpu: amdgpu
s-diag: 1245mm (49.01")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,left model: LG
(GoldStar) 27GL850 serial: <filter> built: 2020 res: 2560x1440 hz: 144
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: LG (GoldStar)
23EA63 built: 2012 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 510x290mm (20.08x11.42") diag: 587mm (23.1") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon RX 6800 (sienna_cichlid LLVM 14.0.6 DRM 3.46
5.18.15-zen1-1-zen) v: 4.6 Mesa 22.1.4 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab28
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.18.15-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
IF: enp39s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 6.38 TiB used: 384.17 GiB (5.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 49.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 970 EVO
500GB size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7
temp: 41.9 C scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 512GB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
model: WD4000FYYZ-01UL1B2 size: 3.64 TiB block-size: physical: 512 B
rev: 1K03 scheme: MBR
ID-1: / raw-size: 431.26 GiB size: 431.26 GiB (100.00%) used: 384.17 GiB
(89.1%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:6
ID-2: /home raw-size: 431.26 GiB size: 431.26 GiB (100.00%) used: 384.17
GiB (89.1%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:6
ID-3: /var/log raw-size: 431.26 GiB size: 431.26 GiB (100.00%) used: 384.17
ID-4: /var/tmp raw-size: 431.26 GiB size: 431.26 GiB (100.00%) used: 384.17
ID-1: swap-1 type: zram size: 31.3 GiB used: 768 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.2 C mobo: N/A gpu: amdgpu temp: 66.0 C
mem: 64.0 C
Processes: 336 Uptime: 13m wakeups: 0 Memory: 31.3 GiB used: 3.35 GiB
(10.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.0 Packages: pacman: 2007 lib: 480 flatpak: 0
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: alacritty
inxi: 3.3.20
Garuda (2.6.5-1):
System install date: 2022-01-01
Last full system update: 2022-07-30
Snapshots: Timeshift (maybe)
