Hello ![]()
I am very happy with Garuda Linux, but, I have one Issue with BTFRS. If the task BTFRS-transaction starts, the PC freeze. It is installed on a SATA SSD and I have set Balance, Scrub and Defrag to, weekly, weekly, monthly.
Garuda-inxi:
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9bdc1bb8-710e-4a2b-a1fc-d771d79d9fb1 rw rootflags=subvol=@
quiet resume=UUID=3de67b4e-0081-4321-8b87-d6348302d4da loglevel=3 ibt=off
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
avail: cinnamon-screensaver,xautolock dm: LightDM v: 1.32.0 Distro: Garuda
Type: Desktop Mobo: ASUSTeK model: CROSSHAIR VI HERO v: Rev 1.xx
serial: <filter> part-nu: SKU UEFI: American Megatrends v: 7704
date: 12/16/2019
Info: model: AMD Ryzen 9 3900X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2333 high: 3800 min/max: 2200/4672 boost: enabled
base/boost: 3800/4650 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
13: 2200 14: 3800 15: 2200 16: 2200 17: 3800 18: 2200 19: 2200 20: 2200
21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 182408
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia
v: 550.76 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-04; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DVI-D-1,HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2
bus-ID: 0b:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6 driver: X:
loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 92 s-size: 1590x301mm (62.60x11.85")
s-diag: 1618mm (63.71")
Monitor-1: DVI-D-1 mapped: DVI-D-0 note: disabled pos: primary,center
model: BenQ GL2450H serial: <filter> built: 2015 res: 1920x1080 hz: 60
dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
model: Dell SE2422H serial: <filter> built: 2022 res: 1920x1080 hz: 60
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
Monitor-3: HDMI-A-2 mapped: HDMI-1 note: disabled pos: left
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.76
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 550.76 device-ID: 10de:1b81
surfaces: xcb,xlib
Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
bus-ID: 0b:00.1 chip-ID: 10de:10f0 class-ID: 0403
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: n/a (root, process) with:
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
Local Storage: total: 7.28 TiB used: 723.63 GiB (9.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
Heatsink 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QGXA7
temp: 37.9 C scheme: GPT
SMART: yes health: PASSED on: 19d 1h cycles: 435
read-units: 31,299,635 [16.0 TB] written-units: 26,712,026 [13.6 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 2B6Q temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 235d 18h cycles: 809
written: 14.95 TiB
ID-3: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUA723020ALA641
family: Ultrastar 7K3000 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: A840 temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 96d 18h cycles: 1647
model: WD10EFRX-68PJCN0 family: Red size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: 0A82 temp: 32 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 28d 17h cycles: 2865
Old-Age: UDMA CRC errors: 38136 alert: Bad cable/connection?
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD10EADS-00M2B0 family: Caviar Green size: 931.51 GiB block-size:
physical: 512 B logical: 512 B sata: 2.6 speed: 3.0 Gb/s tech: N/A
serial: <filter> fw-rev: 0A01 temp: 35 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 286d 3h cycles: 4276
ID-6: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 860 EVO 1TB
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1B6Q temp: 31 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 307d 18h cycles: 2294
written: 63.47 TiB
ID-7: /dev/sdf maj-min: 8:80 vendor: SanDisk model: SSD PLUS 1000GB
family: Marvell based SSDs size: 931.52 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 00RL temp: 35 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 218d 9h cycles: 792
ID-1: / raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
used: 723.63 GiB (80.7%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
maj-min: 8:2
ID-4: /var/log raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
maj-min: 8:2
ID-5: /var/tmp raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
maj-min: 8:2
ID-1: swap-1 type: zram size: 31.26 GiB used: 8.61 GiB (27.6%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
System Temperatures: cpu: 55.0 C mobo: 29.0 C gpu: nvidia temp: 55 C
Fan Speeds (rpm): cpu: 1394 case-1: 0 case-2: 1169 case-3: 0 gpu: nvidia
fan: 0%
Power: 12v: 12.29 5v: N/A 3.3v: N/A vbat: 3.16
Memory: total: 32 GiB available: 31.27 GiB used: 13.75 GiB (44.0%)
Processes: 614 Power: uptime: 12h 10m states: freeze,mem,disk
reboot, suspend, test_resume image: 12.46 GiB services: csd-power,upowerd
Packages: pm: pacman pkgs: 2073 libs: 615 tools: paru,yay Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
running-in: gnome-terminal inxi: 3.3.34
System install date: 2024-01-20
Last full system update: 2024-04-23
Windows dual boot: Yes
Failed units: vmware.service
How can I configure BTFRS, that the Transaction is only weekly or something like that. Or better, it doesn’t freeze at all. Today, after the BTFRS transaction after start (Is 20–30 minutes) Where I can’t use the PC, I have it three times after that, that BTFRS-Transaction freeze my PC. I can see it on the Info at my Cinnemon environment. It could be BTFRS-Cleaner with the freeze, too.
Is that anything I could do?
Thanks for the Answer.
